Go to Post Another lesson is don't post on Chief Delphi disappointed, stop and evaluate first. Emotions suck sometimes. :-) - sircedric4 [more]
Unread 29-04-2010, 17:08
davidc10 davidc10 is offline
FRC #0423
davidc10 will become famous soon enough
Do you have an NI-RIO connection in MAX?
When I connect to our cRIO using MAX, the NI-RIO connection shows an error (-60040). I've tried several different laptops and all show the same error.
NI-RIO server is running on the laptops with firewall disabled (I tried a static port first).
Is this by NI design or am I missing something?
Thank you,
David
Unread 29-04-2010, 21:02
Re: Do you have an NI-RIO connection in MAX?
I'm not sure where the error is showing up. Try looking up the error code using Help>>Explain Error. My installation doesn't show the error code as registered, so I can't offer much help.
Can you clarify where the error is showing up and under what circumstances?
Greg McKaskle
Unread 29-04-2010, 21:57
FRC #0423
Greg,
Thanks for the reply. Unfortunately, there was a typo on the error code, it should be -63040, not -60040.
Here is a zip of two screenshots that show the situation.
David
Unread 29-04-2010, 22:45
I think error -63040 usually means there's a networking problem. In addition to making sure there isn't a firewall active, you need to disable all the network connections except the one that's actually going to the cRIO. If you're using wired Ethernet, that means turn off the wireless (we also had a FireWire network connection showing that had to be disabled).
Unread 30-04-2010, 00:15
FRC #0423
Alan,
Yes, -63040 is a network connection problem - kRIOStatusRPCConnectionError. I have read all I could find on this error, and tried all the suggested fixes - both from NI's site and the MAX help; and yet it persists.
Since even with this error I am able to deploy code and use the cRIO generally as intended (it runs the code, dashboard comm is good, ftp works), my question is this: Is this really an error, or is this just the way the system has been set up for FRC? When you connect to your cRIO thru MAX do you get the error too - or is it only me?
Thanks for your suggestion on disabling the wireless - I tried it right away, but without success.
David
Unread 30-04-2010, 22:00
I get the same error in MAX.
It might be because our FRC cRIO doesn't provide traditional RIO device services.
Unread 01-05-2010, 15:58
FRC #0423
Mark,
Thank you for checking. When certain features don't work - (as they would on a standard system) - it's hard to tell if it's a problem or by FRC design.
Another example is Debugging a Stand-Alone Real-Time Application. I've never been able to get a connection to the cRIO to debug our code once it's been deployed as a start-up application. The connection is refused on the cRIO side.
I can do this on a PC that's set up as a Real-Time PC target, but not on the FRC cRIO. If this is by design also, (NI FRC support couldn't tell me at the time), it would be helpful to have documentation about it so as not to waste time trying to troubleshoot it.
Have you been able to get the Web Server up on the cRIO?
David
Unread 01-05-2010, 17:01
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
This is probably due to one of the several services we removed to free up resources that were being used on the controller that are typically unused in the FRC environment. For FRC, we essentially ignore the existance of MAX... you should too.
We intended for this to work, but a bug crept in somewhere late in the game and we were unable to address it in time for Kickoff. I belive we intend to make it work for next year.
We had this installed and enabled on the controller during beta, but it was removed due to the resources it consumed. It was decided that there should be more available to the team code and libraries they might use. It did work well, though.
-Joe
Unread 02-05-2010, 21:31
FRC #0423
I understand. Thank you Joe.
David
c-RIO connection troubles Sev C/C++ 30 08-12-2010 00:41
How do you download a program and have it saved to the c-rio 2560DawgDM NI LabVIEW 12 03-02-2010 20:58
Have You Attended Multiple High Schools? Do They Have FIRST Teams? KathieK General Forum 25 08-01-2009 02:16
I have questions! Do you have answers? c-squared_2006 Off-Season Events 2 07-04-2005 16:10
Do we have to use 3D studio max? archiver 2001 5 24-06-2002 02:16
