Go to Post Some said the aluminum foil gave the robot a NASA-like quality, but others pointed out that blanketing components with a highly-conductive material that blocked air flow was probably not going to help get us to Einstein. - beerobber [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 30-04-2010, 11:13
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Re: CANJaguar code with synchronization
Originally Posted by taichichuan View Post
Hi Gang,
I have a version of the CANJaguar code that does all of the control modes (position, speed, voltage and current) as well as adding the synchronization option to send messages to all of the Jaguars and then activate them all at once. Where should I send this code? I don't have commit privileges on FirstForge to add them to the repository.
I've also set the CANJaguar code up as a library that can simply be linked rather than included as source into your project. Anyone interested in the Makefile I wrote to create the library?
TIA,
Mike
Hi Mike,
That's great work.
The easiest way to contribute at the moment is to create a tracker with the patch attached. I'll evaluate it and apply it. If there are minor things to change to match style or something, I'll do that as part of the merge, or if there is anything major, I'll ask you to make the changes and resubmit.
Thanks!
-Joe
CANJaguar vi's RoboGuy Programming 15 18-04-2010 02:23
Potential Issue with the C++ CANJaguar Implementation mattbutts C/C++ 2 19-02-2010 13:26
CAN, LabView, and Synchronization duane CAN 0 18-02-2010 19:36
Assigning synchronization groups? taichichuan CAN 0 16-02-2010 18:56
CANJaguar + BlackJagBridge plugin errors Shinigami2057 CAN 1 06-02-2010 11:20
