Go to Post When we find bugs at work, we don't ask "who wrote that section of code?" We ask "Who is the best, most knowledgeable person to work on fixing this bug?" - Jon Stratis [more]
Unread 30-04-2010, 21:38
johncap100 johncap100 is offline
FTC #0658
johncap100 is an unknown quantity at this point
Re: Older FRC autonomous code
Well Mark i typed in the code above in red, and yes the black code is there.
It built fine, and i downloaded it , but the autonomous did not work, all that is working is the teleop, one joystick operates one motor and the other joystick the other one.
i have the motor controllers plugged into pwm ports 1 and 2. There seems that there should be someway to let the program that this is autonomous and not teleop. is it set up to go to autononmous if there is code there?
how many times will it go through the autononmous code?
thanks
Unread 30-04-2010, 22:11
You do have to put the robot into Autonomous mode before it'll take effect.
Normally, we use a special switch constructed for the purpose. (You can ignore switch 3 on that schematic. It's for earlier versions of the IFI control system.)
The disable button is handy to have in any case for emergency stops.
You can also setup an auto routine to run while you push a joystick button.
If you only want to run autonomous and don't care about Teleop, there is a way to set the team number most-significant-bit so the robot runs Auto mode all the time.
P.S.
Since you're using PWM 1 and 2 only, the auto code needs to be adjusted to reflect this, rather than pwm01/pwm02 and pwm03/pwm04
E.g.,
pwm01 = 200;
pwm02 = 54;
Unread 01-05-2010, 08:09
FTC #0658
Where does the switch plug in? on the robot controller?
How would one go about adding the routine into the code?
if you would be so kind as to helpme on these two things
thanks
Unread 01-05-2010, 09:14
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
The switch plugs into the "competition" port on the Operator Interface. You only need sw1 and sw2, Disabled and Autonomous. If you would rather use a joystick button to indicate autonomous mode, you could say something like "autonomous_mode = pw_trig;" right after Getdata, for both Process_Data_From_Master_uP and User_Autonomous_Code.
Kettering Motorsports
Unread 01-05-2010, 16:03
Yes, it connects to the Operator Interface at the driver controls.
I've attached a photo of a Disable/Auto switch on our '08 robot controls.
It happens to be out in my van for an appearance at the Special Olympics tomorrow.
If you want to use one of the joystick buttons to trigger it as well, the Autonomous routine can be rewritten slightly to accommodate being called two different ways. I'd prefer not to flat-out clobber the autonomous mode flag, but to structure the code such that either way will trigger the auto routine.
Had one team fail year after year on the playing field whenever a particular mentor would return every-other year to help them. Always turned out he would overwrite the autonomous mode flag with a joystick switch so the real flag would never work. It's a bad habit to start.
Maybe something along the lines of (in User_Autonomous_Code and main.c):
while (autonomous_mode || (p1_sw_trig == 1) )   /* DO NOT CHANGE! */
You'd also need to modify main.c with the same statement modification to get it to start and the joystick button would act as a dead-man switch. You'd have to hold it to keep autonomous running. Letting go would stop it.
What might be simpler for you right now is to just call an auto routine like that in post #14 directly from user_routines.c whenever the button is held down. a la,
void Process_Data_From_Master_uP(void)
  static unsigned char i;
  Getdata(&rxdata);   /* Get fresh data from the master microprocessor. */
    if (p1_sw_trig == 1)
       Autonomous();
    else
        Default_Routine();  /* Optional.  See below. */
You don't have to be in Autonomous Mode to run some autonomous routine in teleop.
P.S. If you add a new routine like Autonomous(), depending on where you add it you may need to declare it in one of the header files (.h) so the compiler knows where to find it.
Unread 01-05-2010, 17:32
FTC #0658
Ok great with all the info, sounds like it is best to have a dongle mostly as a kill switch, and then do the simple code in autonomous_user.c using a button trigger. i will try it this afternoon
thanks a bunch and will post how it goes
Unread 02-05-2010, 13:08
FTC #0658
well i went to the users_routines.c and right after the"Getdata (&rxdata);" i typed in the code from post 20 (the second code). When i ran the build all i get back the following 2 errors:
pl_sw_trig has not been defined
and
"call of function without prototype" referring to the Autonomous (); line.
any help is appreciated.
also just a quick check, i am doing this i the users_routines.c and not in the users_routines_fast.c. I understand that the latter one is for autonomous code editing only.
Unread 02-05-2010, 13:24
apalrd's Avatar
More Torque!
VRC #3333
Where is your Autonomous() function? It (or a prototype to it) should be before the routine that gets the error, Process_Data_From_Master_uP(). If the routine is in a separate file, then the prototype needs to go in a header. If Autonomous() is in the same file, then put it before Process_Data_From_Master_uP().
If you build the box, then you don't need the joystick trigger. One or the other. If you don't build the box, then it is easier to just use a joystick trigger.
p1_sw_trig should be valid..... it is.
http://ifirobotics.com/docs/legacy/2...2-apr-2004.pdf has a list of the IO definitions, you can find everything there. If you look at ifi_aliases.h it will tell you what the definition for everything is. If you created a C file for your code, you have to include ifi_aliases.h to use... anything (OI data, PWM outs, Analog, Digital inputs).
Unread 02-05-2010, 13:58
Kevin Watson's Avatar
La Cañada High School
FRC #2429
Originally Posted by johncap100 View Post
...any help is appreciated.
If you get stuck, feel free to send me your code and I'll have a look. Use kevin at kevin period org if you send me anything.
-Kevin
Kevin Watson
http://kevin.org
Unread 02-05-2010, 15:21
"p1_" not "pl_"
I think you might not have used the numeral one.
It stands for port 1 on the Operator Interface. You can also use a joystick connected to any of the four ports available and refer to the buttons by the prefixes "p1_" "p2_" "p3_" or "p4_"
The compiler needs to be told a little bit about how the Autonomous() function is supposed to be called.
Up at the top of user_routines.c after the "#include" lines add the statement:
void Autonomous(void);
This'll tell the compiler that the routine doesn't have any calling arguments.
Doing this in users_routines.c is fine.
Unread 02-05-2010, 21:05
FTC #0658
Hey mark well i did cure the p1 issue, thanks
But when i try to build all i get an error as follows:
'could not find definition of symbol "Autonomous" in file 'C:\FRC Miller-2006 Codeopt b\user_routines.o' the file is where i have the workspace.
I suspect i need to add a line in an .h extension according to the bottom of your post #20, not sure what or where to put it.
thanks
Unread 02-05-2010, 21:09
apalrd's Avatar
More Torque!
VRC #3333
If Autonomous() is in the same file (user_routines.c) then you do not need the .h.
Put the following after the #includes at the top of user_routines.c:
Unread 02-05-2010, 22:08
thanks
I suspect this is caused by something different.
I'd guess you have a new file containing the Autonomous routine?
It's in the directory of your workspace?
If none of this guesswork is true, then describe more about which files your new code is in.
If that's how you did it, that's all okay.
There is one more step though. Any new file has to be added to the workspace in MPLAB, otherwise, it doesn't get pulled in by the compiler.
In MPLAB go to Project -> Add Files to Project...
and find your new files in include as part of the compile workspace.
Unread 02-05-2010, 22:29
FTC #0658
sorry but i am not following the reasoning of what you said in the last post. I can go to the add files in mplab but when there what do i add?
you seem to be asking about a new file? not sure what you are saying.
thanks
Unread 03-05-2010, 10:44
Sorry, I just guessed wrong about how you've put your code together looking over your virtual shoulder...
The error you got meant the compiler couldn't find your Autonomous routine-"void Autonomous(void) {".
It'll be something simple, like my leaving out the keyword "void".
There are lots of different ways to do this, so here's a template for one way.
I assume you are doing all your work in the file user_routines.c
This is only one way to integrate the code from posts 20 and 14.
* FILE NAME: user_routines.c <FRC VERSION>
* DESCRIPTION:
*  This file contains the default mappings of inputs
*  (like switches, joysticks, and buttons) to outputs on the RC.
* USAGE:
*  You can either modify this file to fit your needs, or remove it from your
*  project and replace it with a modified copy.
#include <stdio.h>
#include "ifi_aliases.h"
#include "ifi_default.h"
#include "ifi_utilities.h"
#include "user_routines.h"
#include "user_Serialdrv.h"
extern unsigned char aBreakerWasTripped;
// Drive forward, turn, return, and stop
  static int counter=0; //keep track of loops to use as a crude timer - static keeps it around from call to call
  static int autostate=1;   //keep track of what step we're supposed to be doing
  switch (autostate)
      case 1:   // Drive forward
                   pwm01 = 200;
                   pwm02 = 54;  //motor is reversed
                   if (counter>38)  //1 second
                       autostate = 2;  // move on to the next step
                       counter = 0;    // reset our timer for the next step
                   break;
      case 2:   // Turnaround
                   pwm01 = 200;
                   pwm02 = 200;  //motor is reversed
                   if (counter>76)  //2 seconds
                       autostate = 3;
                       counter = 0;
                   break;
      case 3:   // Drive forward (returning now)
                   pwm01 = 200;
                       autostate = 4;
                       counter = 0;
                   break;
      case 4:   // Stop - What to do when everything else is done
      default:  // also what to do if an invalid autostate occurs
                   pwm01 = pwm02 = 127;   // Make sure the last thing you do is always stop
   counter++;
* FUNCTION NAME: Limit_Switch_Max
* PURPOSE:       Sets a PWM value...
... (etc)
      Autonomous();
   else
... (etc.)
You can also put the Autonomous routine way down at the bottom of the user_routines.c file, and then you'd need that prototype statement up at the top to warn and prepare the compiler about what any calls must look like (if the call comes before the compiler has seen the routine) .
Autonomous 2010 FRC Drucifur Java 10 14-02-2010 08:06
FRC...autonomous or driver-controlled competition? tribotec_ca88 General Forum 28 10-03-2005 14:47
Autonomous code PBoss Programming 7 14-01-2003 15:29
Autonomous Code Adrian Wong Robotics Education and Curriculum 1 18-11-2002 22:34
