Go to Post FIRST is supposed to prepare you for a focused career in your subject of interst, and help you manage your time and resources effectively. - Eugenia Gabrielov [more]
Unread 01-05-2010, 13:29
pic: Sheetmetal 8wd
Unread 01-05-2010, 13:32
RMS11's Avatar
RMS11 RMS11 is offline
Safety!!!!
AKA: Rick
FRC #2415 (WiredCats)
Team Role: Driver
RMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to behold
Send a message via AIM to RMS11
Re: pic: Sheetmetal 8wd
Looks really cool! A few questions:
Why did you decide to do 4 gearboxes instead of 2, as 2 would probably save weight.
I cant tell from the pic, but how are those crossbeams attached? Are they made of bent aluminum? Was there a structural reason to put the front cross beam at an angle?
Also, what was the weight as it?
Again, looks great!
2009 Peachtree Regional Champs
2009 Palmetto Regional Champs
2008 Peachtree Rookie All Star and Rookie Highest Seed
Unread 01-05-2010, 13:46
Chris is me's Avatar
AKA: Pinecone
More importantly, when's this showing up on Shaker's doorstep? We need it before July...
Oh, it's a render. Silly me.
Unread 01-05-2010, 13:48
Jstack14 Jstack14 is offline
Team Role: CAD
Jstack14 is infamous around these parts
Seems very complex considering how simple it could be...BUT...it looks awesome and 4 toughboxs with 4 cims is very powerful! If only i could have that drive i would enjoy playing with it.
Unread 01-05-2010, 14:43
There's nothing complex about it. I'm kinda curious about what you mean. The drive itself is very simple direct drive and then the corners are dead axle chained to the direct driven wheels. If you mean the lightening pattern, then yes, I made it a bit too random. I will be changing it to be a bit more structurally sound.
I chose 4 nanos because it made for the shortest runs of chain. I've also been playing around with the versatility of the nano a lot lately. (We also have some laying around).
Total weight was 26lb. with everything and some parts being .125" along with .09" thick.
Oh and no the angle of the crossmembers was just aesthetics. They are also bent sheetmetal.
Unread 01-05-2010, 17:07
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
If you have a sponsor shop where all they do is make this kind of stuff all day, and you have the proficiency to design this kind of stuff well (I do not), then this is REALLY the way to build an FRC robot in a short amount of time. It is so fast and easy to burn (or jet) all this out because the actual amount of material removed is so small, compared to milling. The amount of time saved over milling and welding more solid-type parts can be tremendous.
Unread 01-05-2010, 17:52
I'm thinking that with 4" wheels I can rework the geometry a little and place the CIMs inside the modules and save some space while still keeping it direct drive.
http://s656.photobucket.com/albums/u...l_Assembly.jpg
The blue and white are 2791 colors.
Unread 01-05-2010, 18:25
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
One thing I would be worried about with this design: It looks like the crossmembers are only attached on their ends. Being c-channels, you would probably see a lot of flex in the whole chassis. It would likely survive through competition, but I would be hesitant to use it.
Since you are designing it with sheet metal, you have the unique ability to make very large structural members that are still very light. Monocoque style construction is something that can be employed fairly easily and will result in a very stiff, very strong chassis.
Unread 01-05-2010, 18:40
Dave McLaughlin's Avatar
Happy Birthday! Dave McLaughlin Dave McLaughlin is offline
Dave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond repute
I know that 233 had a similar drive set up as you do hear this year, but ended up chaining the two gearboxes on each side together. I'm not sure exactly, but I think it was due to torque problems when the front 4 wheels lifted off the ground when crossing the bump. Just something to consider.
Unread 01-05-2010, 18:48
O'Sancheski O'Sancheski is offline
O'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond repute
What program did you use?
Can I have the CAD files... I would love to show this to my team... Looks really nice btw...
Unread 01-05-2010, 19:44
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Sheet metal chassis like look HUGE, but in reality are a lot of empty space. I've really appreciated the look of the 217 / 148 / 1114 robots the last couple of years - they simply look physically imposing because of the lack of open space: they look massive.
One question though on this type of constructive. I imagine one of the trickiest parts of making a sheet-metal frame of this sort is doing the force modeling to understand where you can and cannot remove material.
How are you going about that?
Unread 01-05-2010, 20:24
The entire pattern on this was done incorrectly and very hastily, I did not look at the loads that well. I am redoing the pocketing right now. Obviously I made all mounting holes like JVN said and then carefully pocketed leaving .75" in between everything in the second iteration. Mostly I've been studying the CAD from 148's 07-09 bots along with a few others and just working off of that.
I also redid the assembly to make it monocoque. I'll post it up later tonight.
Unread 01-05-2010, 22:14
Ok so I redid a lot of the suggested stuff and restructured the trussing.
http://s656.photobucket.com/albums/u..._sheet_8wd.jpg
http://s656.photobucket.com/albums/u...heet_8wd_2.jpg
http://s656.photobucket.com/albums/u...AssemblyV2.jpg
Unread 01-05-2010, 22:20
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
It seems to me that you could easily cut the height in half and save a bunch of weight that way. Also you need to think about some type of belly pan both to mount electronics and to greatly increase the strength of the whole assembly.
Also the cutout in the middle could be decreased a bunch. It looks to me like the limit to ground clearance will be the area between the middle and outer wheels and not the area between the middle wheels. There no need in having the middle have way more clearance. It just weakens things and makes it more difficult to run chains, plus raises the area where you can mount electronics, thus raising the center of gravity of the whole thing.
Mentor 2415
Unread 01-05-2010, 22:31
I'll have to change it tomorrow, haha, been spending too much time with CAD instead of studying for APs. The height for right now was just set to make the GDC and their 2010 bumper rules happy.
Thanks for the suggestions and changes everyone.
pic: 8WD 'Suspension' Chassis Concept JesseK Extra Discussion 8 09-12-2008 22:00
pic: FRC 1771 East (West) Coast 8wd drivetrain sdcantrell56 Extra Discussion 10 09-12-2008 17:40
pic: Concept 8wd Drivetrain sdcantrell56 Technical Discussion 77 25-11-2008 23:05
pic: Sheetmetal Pig by JVN petek Extra Discussion 1 22-04-2006 23:25
8WD drivetrain? David Sherman Technical Discussion 16 09-04-2006 17:32
