Go to Post Kids don't just decide they want to build robots then build the next Einstein champion the next year. - kjolana1124 [more]
Unread 01-05-2010, 20:31
akeisic's Avatar
akeisic akeisic is offline
Systems and Strategy Mentor
AKA: Andrew Keisic
FRC #4201 (The Vitruvian Bots)
akeisic is a name known to allakeisic is a name known to allakeisic is a name known to allakeisic is a name known to allakeisic is a name known to allakeisic is a name known to all
Re: Drivetrain Basics
Originally Posted by Jared341 View Post
In general, limiting yourself to 40A before you lose traction is overkill. You almost never need to push against a "wall" for more than a few seconds at a time, in which case you can use a much higher figure (easily 2x as much) before worrying about tripping the breaker.
While it may seem overkill, we definitely we're spinning our wheels pushing for nearly 10 seconds strait this year.
We had a 4 CIM base with 7" diameter wheels and use the AndyMark Super Shifter with the optional gear package.
Low Gear: 30.1:1
High Gear: 7.5:1
I just posted the latest version of our analysis file as it is significantly better then the previous ones. We used it to determine all of our gear ratios: http://www.chiefdelphi.com/media/papers/2292
I also have posted a Drive Train Fundamentals presentation: http://www.chiefdelphi.com/media/papers/2294
Another design consideration is your operating voltage. Your motor power is proportional to the square of your operating voltage. We've started to monitor our voltage during the matches and found it can easily drop below 11V under load (in some cases 7V! [bad battery] ). Hence - much to my dislike as a mechanical guy - we've started to design with a nominal voltage of 11V.
Mentor: FRC 4201 - The Vitruvian Bots
Awards with FRC 294 - Beach Cities Robotics
2014: LA FRC Champions
2012: LA FRC Finalists
2011: San Diego FRC Finalists
2010: San Diego FTC Finalists, San Diego FRC Champions, LA FRC Finalist, FRC World Champions
2009: LA FRC Finalist
2008: San Diego FRC Champions, LA FRC Finalist, LA FTC Champions, LA VCR Champions,
2007: San Diego FRC Finalist, San Diego FTC Champions, FTC World Champions
Bread board basics Da Kid Kit & Additional Hardware 1 26-01-2010 19:49
Limit Switch Basics JWSnedden Programming 6 30-11-2006 19:48
Fantasy FIRST Basics Koko Ed Fantasy FIRST 21 17-01-2005 06:33
Oscilloscope Basics Al Skierkiewicz Technical Discussion 1 16-08-2004 08:48
