Go to Post Only time will tell for sure, but it seems that the current software providers are hatching up a pretty good solution to the problem. - dlavery [more]
Unread 02-05-2010, 16:34
vamfun vamfun is offline
Mentor :Contol System Engineer
AKA: Chris
FRC #0599 (Robodox)
vamfun is a glorious beacon of lightvamfun is a glorious beacon of lightvamfun is a glorious beacon of lightvamfun is a glorious beacon of lightvamfun is a glorious beacon of lightvamfun is a glorious beacon of light
Send a message via AIM to vamfun
Re: Unexpected results from Encoder::GetRate()
Originally Posted by jhersh View Post
Yes... if you did it that way, you would have a small window for the register to change. However, that is why I put both in the same register. Same thing goes for the period, the count, and the stall information. All related; all in the same register.
If instead you did:
INT32 Counter::Chris_Get()
	//Now all the information is read in one register access!
	tCounter::tOutput output = m_counter->readOutput(&status);
	// dir = 0 decrements count
	if (output.Direction)
		// if we haven't reversed then update count
		return output.Value;
	else
		// else keep the count at last value
		return output.Value + 1;
Cheers!
-Joe
Thanks, that's what I was looking for. Duh, I finally found the tcounter.h files in Windriver Chipobject directory that describes the output data structure. Had I found those earlier, I could have figured a few more things out for myself.
I still would like to know the details of your GetRate() algorithm that keeps the rate from reporting on a same edge. Its not obvious where you do this.
Also, could you describe the 4x algorithm equations (like your description of the 1x and 2x earlier).
[BB] An unexpected change in plans yodameister General Forum 22 01-12-2009 21:26
Inconsistent reading from encoder get rate rwood359 National Instruments LabVIEW and Data Acquisition 5 13-01-2009 19:10
Results from Drexel, thanks from 365. archiver 2001 1 24-06-2002 02:44
Results from GLR? archiver 2001 0 24-06-2002 02:44
results from regionals archiver 2000 0 23-06-2002 22:31
