Go to Post If I find a student on my team who came through FIRST having learned nothing more then he wanted to go to MIT, I'll give my self a pat on the back and start counting down to kickoff. - Andy A. [more]
Unread 02-05-2010, 17:16
Wendy Holladay's Avatar
Wendy Holladay Wendy Holladay is offline
FRC #1912 (Team Combustion)
Wendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond repute
How to Start an Off-Season Event
Our team is trying to have an off-season scrimmage with a full field, but on the FIRST website it appears that you have to pick up the rental field in New Hampshire, which is pretty far away from Louisiana. We were wondering how everyone else does these off-season events. Do you rent a field, or use your own?
Unread 02-05-2010, 17:18
M.Wong's Avatar
M.Wong M.Wong is offline
FRC #0503 (Frog Force)
M.Wong is a jewel in the roughM.Wong is a jewel in the roughM.Wong is a jewel in the rough
Re: How to Start an Off-Season Event
I would recommend building your own. At our practice facility, we constructed a playing field with mostly 2x4s and plywood and chicken wire fencing.
Unread 02-05-2010, 17:33
RoboMom RoboMom is offline
people expediter on Team Kluge
AKA: Jenny Beatty, no relation
no team (they are all my teams)
RoboMom has a reputation beyond reputeRoboMom has a reputation beyond reputeRoboMom has a reputation beyond reputeRoboMom has a reputation beyond reputeRoboMom has a reputation beyond reputeRoboMom has a reputation beyond reputeRoboMom has a reputation beyond reputeRoboMom has a reputation beyond reputeRoboMom has a reputation beyond reputeRoboMom has a reputation beyond reputeRoboMom has a reputation beyond repute
We are blessed with the support of NASA's Goddard Space Flight Center through the legacy of the late Mike Wade (and continued to be supported by Rob Thate.) This field travels up and down the coast from VA to NY. But it takes loyal volunteers and cooperation among all parties to make it work.
One suggestion is you reach out to others in the south to see if you can coordinate with one of the already traveling fields to cut costs. See if your Regional Director has any advice.
Planning and implementing an off-season is a huge amount of work, but can be a really satisfying experience.
Co-Founder of NEMO (Non-Engineering Mentor Organization) www.firstnemo.org
Volunteer Director, STEMaction, Inc. www.stemaction.org
FIRST Senior Mentor: Nov. 2004 to June 2009: "Experience is that marvelous thing that enables you to recognize a mistake when you make it again"
This is How I Work: http://www.chiefdelphi.com/media/papers/2862
Unread 02-05-2010, 17:43
Phil Ross's Avatar
Phil Ross Phil Ross is offline
Constantly Inspired
FRC #1712 (Dawgma)
Phil Ross is a splendid one to beholdPhil Ross is a splendid one to beholdPhil Ross is a splendid one to beholdPhil Ross is a splendid one to beholdPhil Ross is a splendid one to beholdPhil Ross is a splendid one to beholdPhil Ross is a splendid one to behold
Send a message via AIM to Phil Ross
Check this out. When they say "pick up the rental field" they mean hire a truck to go pick it up in NH. Also, NASA has a field that they build and bring around to off season events. I assume that field is separate from the ones you can borrow from FIRST.
You can also use your own field (I wouldn't go out of the way to build one just for the event, it would likely drive your registration costs through the roof).
If you look here you can find the schedule of off-season events. If you can avoid it, don't make it on the same day(s) that another off-season in your area is occurring. Since you are in Louisiana I don't think that anything scheduled so far will conflict.
Hope this helps and Good Luck!
FIRST Americorps VISTA, Philadelphia
DAWGMA TEAM 1712: Alumni (2006-2009)
A MN off-season event. vivek16 General Forum 8 16-06-2008 22:39
Planning an Off-Season Event Chris Fultz Off-Season Events 0 21-01-2008 09:49
Rochester Off Season Event andyhoyt911 General Forum 3 21-08-2007 16:27
CANADIAN off-season event?? shyra1353 Off-Season Events 2 30-10-2003 22:40
How do you organize and run an off-season event? Mike Henry Off-Season Events 4 20-06-2002 08:05
