Go to Post Hurricane season would be torture, at least in snow you can lock the doors and know the robot is safe. - ATannahill [more]
Unread 24-04-2010, 11:06
Jstack14 Jstack14 is offline
Team Role: CAD
Jstack14 is infamous around these parts
Re: Tank Tread Help
We actually looked at those and our considering getting them. This is what we currently have.
This is our drive system with shocks...we still need a dynamic tensioner so currently we are just trying to get it working with the shocks locked and static.
This is the tread but we will be putting something over the lexan pieces so they grip the ground better.
This is a close up of the sprocket. If you look to the right of the sprocket you can see where we cut off the teeth so we could rivet the lexan pieces to the chain.
Unread 24-04-2010, 11:14
Isaac501 Isaac501 is offline
FRC #0501 (The PowerKnights)
Rookie Year: 1995
Isaac501 is just really niceIsaac501 is just really niceIsaac501 is just really niceIsaac501 is just really nice
Re: Tank Tread Help
Originally Posted by Jstack14 View Post
Well honestly i do not think we need tank treads, however our team is set on tank treads. This is really unfortunate because you can have just as good if not better handling and off road capability without it.
We used tank treads exclusively in the mid-late 90s. Given, this was for carpet with FRC, but your pushing ability is absolutely unmatched, but your speed tends to be slower, and your maneuverability is arc and circle limited.
We used something similar to the brecoflex treads with very high levels of success. We never slipped a tread after our ~first year using them. You need to be very careful how you design your tensioner and idler and where you place your bogies.
Team 501 Academic Advisor, Systems Build Mentor
Unread 27-04-2010, 08:33
yarudl yarudl is offline
FRC #0578
yarudl is an unknown quantity at this point
Re: Tank Tread Help
Team 578 this year, my team, was considering the same thing when we found triple starnd chain. its the same Idea but you bolt the lexan to the outer stands and run a regular sprocket on the inner strand. it will work exactly as you want it to. it can be bought from any specialty chain store online. alas it is expensive.
Thanks,
Yarudl
Unread 27-04-2010, 13:32
CraigHickman
Posts: n/a
Re: Tank Tread Help
Might be above your cost range, but we've been very happy with the Outback track systems. Effectively it's a Brecoflex self centering belt riding on pulleys between milled aluminum, but it could probably be simplified down to a brecoflex belt on pulleys with some cheaper structure. If you're interested, Outback MFG is a Brecoflex reseller, so you can get some FIRST legal belts through them. (You'll need to contact them for details... I'm not current on what belts they carry in stock, or costs, or even availability...)
If we had more information about your application, I'm sure we could help you out with more accurate information....
Unread 27-04-2010, 16:09
JohnFogarty's Avatar
AKA: @doctorfogarty
Re: Tank Tread Help
The outback systems from what I heard didn't work out well. I only saw 2-3 Robots at Worlds with Treads, the both had belt treads. http://maikenmagic.com/?ref=showphot...%20Build&num=8
We handmade our using Kevlar belting, ABS plastic, and Rivets....lots of rivets.
John Fogarty
Former Student & Mentor FLL 1102, FTC 1102 & FTC 3864, FRC 1772, FRC 5632, FRC 4901
Unread 27-04-2010, 17:56
CraigHickman
Posts: n/a
Re: Tank Tread Help
We never had a single mechanical failure. Neither did any of the other track bots at our regional. I'm not going to say that it was an instant win due to treads, that would be lying. But we were never outpushed, and we never broke down due to mechanical reasons. A testament to their power can be found in our haywire autonomous, when we flipped another robot with a full speed hit, and proceeded to drive entirely over their underside.
Unread 27-04-2010, 18:57
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
Re: Tank Tread Help
Once again, flipping a robot this year is not a testament to your power but rather a testament to the bumper rules creating a situation where a large moment can be present.
Until they give us a game with sand or some soft surface, teams should really shy away from tank treads as they don't provide any competitive advantage and a whole slew of potential downfalls.
Mentor 2415
Unread 27-04-2010, 19:37
Team Role: CAD
Re: Tank Tread Help
Agreed, our robot was simple...6 in. wheels with two cims per side going into andymark gear boxes. Nothing complicated and we could push everyone we wanted, we even bent a tracked bot's drive system some...oops.
Anyway, we are not using this for an actual FIRST competition it is for something else.
Unread 02-05-2010, 17:57
Team Role: CAD
Re: Tank Tread Help
gonna try this mesage again the links didn't work last time
Tank tread chs1368 Technical Discussion 27 07-01-2007 15:54
tank tread inventor file SgtMillhouse648 FIRST Tech Challenge 0 14-09-2006 11:12
Tank Tread Wheel Joe_Widen Technical Discussion 8 29-05-2006 23:28
Tank Tread suppliers? Rombus Technical Discussion 2 22-02-2005 11:01
Semi-Tank Tread/Half Tank Treads thoughtful Technical Discussion 4 11-01-2005 08:33
