Go to Post Purpose over pimpness is a policy that we are trying to adhere to. - santosh [more]
Unread 02-05-2010, 18:39
TEE's Avatar
TEE TEE is offline
FRC #0201
TEE has a spectacular aura aboutTEE has a spectacular aura aboutTEE has a spectacular aura about
What does it take 6WD/8WD to be successful?
Basically what the title says... what does it take to make a great 6 or 8 wheel tank drive?
Unread 02-05-2010, 18:40
keehun's Avatar
keehun keehun is offline
Team Captain
AKA: Keehun Nam
FRC #2502 (EP Robotics)
keehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond repute
Send a message via AIM to keehun
Re: What does it take 6WD/8WD to be successful?
Driver Practice.
For by grace you have been saved through faith, and that not of yourselves; it is the gift of God, not of works, lest anyone should boast. -- Ephesians 2:8-9
2010: Quarter Finalist (MN 10,000 Lakes)
2010: Website Award (MN 10,000 Lakes)
2009: Quarter Finalist (MN 10,000 Lakes)
2009: GM Industrial Award (MN 10,000 Lakes)
Unread 02-05-2010, 18:45
TEE's Avatar
TEE TEE is offline
FRC #0201
Any robot takes driver practice to be successful... some more than others...
I was asking in reference to the the construction of such a drive, and not just any 6 or 8 wheel drive, one that really gets the job done.
Unread 02-05-2010, 18:47
Specifically what type of 6 or 8wd? Drop center? Omni + traction? direct driven?
Its a bit too vague of a question and not really one that has a real answer to it.
I've seen teams with kit drives that "get the job done." As long as it doesn't fall apart on the field you're basically good.
Unread 02-05-2010, 18:58
TEE's Avatar
TEE TEE is offline
FRC #0201
Sorry for the ambiguity...
I've seen teems with tank drives that are relatively slow and don't turn well. With direct reference to a 6WD/8WD, I meant one without omni's that still turns quickly, and that has a 2-speed transmission to be able to push well in low gear and move quickly in high gear.
Is drop center better? Would Omni's in front and back be better? What gear ratios would work best? Is it worth it to use FP motors?
EricH EricH is online now
What is "the job" that needs to be done?
What is your definition of successful?
Chris is me's Avatar
AKA: Pinecone
Not much. You want a dropped center, a good transmission (shifting usually so you can get 9fps safely, more or less depends on the game), and practice.
Dropped center is better than omnis because when you get pushed, you'll "rock" onto that side and won't be spun nearly as easily as an omni based drivetrain. I personally like 8wd because the rock has less of an effect on driving, but it's probably not worth the added weight and complexity for most flat games.
Unread 02-05-2010, 19:09
Joining the 900 Meme Team
FRC #0079
The KOP Frame, KOP Transmissions. Read the instructions. No, I am not kidding. You can save a bit of weight by doing it all custom but since you already have an effective solution why not use it?
Build it week 1 and get people practicing. Work your kinks out early.
Fail Faster
Learn More
Focus and Execute
Unread 02-05-2010, 19:35
Alex Cormier's Avatar
Alex Cormier Alex Cormier is online now
www.TwoPencilDesigns.com
AKA: Grizz, Twinkletoes, PitBull1126
FRC #1405
Alex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond repute
It's mostly based on the game for the year.
There is also this thread too.
Two Pencil Designs - Vinyl Graphics, Bumper Numbers, and Strategy Items!
Like us on Facebook & follow us on Twitter
Facebook.com/TwoPencilDesigns & TwoPencilDesign
Unread 02-05-2010, 19:38
TEE's Avatar
TEE TEE is offline
FRC #0201
which thread?
Unread 02-05-2010, 20:43
ttldomination's Avatar
ttldomination ttldomination is online now
Sunny
A 6 WD with a dropped center does its job. We made a 6 WD with a dropped center using a standard toughbox, and that thing was crazy. It was quick, zippy, and the torque was crazy. As per a 8WD, I think that the were dominant this year because teams didn't want to bottom out on top of the bump. But usually, you'll see 6 WD.
As for gear ratios, read this post before you think of something crazy. I personally agree with this logic. One can always find a nice balance.
1648: 2013-2014
5283: 2015
Unread 02-05-2010, 20:49
Jamie Kalb Jamie Kalb is offline
Jamie Kalb is a name known to allJamie Kalb is a name known to allJamie Kalb is a name known to allJamie Kalb is a name known to allJamie Kalb is a name known to allJamie Kalb is a name known to all
Fail Faster
Learn More
Focus and Execute
This method worked really well for my team this year. The kit base is highly underrated. It's not perfect, but it's a lot better than people seem to think. Having a working chassis with almost zero design time was huge for us. There was only one major thing I felt was missing, and that was chain tension. Maybe we were doing something wrong, but we never could seem to make the chains happy; they were always too loose or too tight. One of our freshmen got really good with the chain breaker, because he had to use it daily . If only the kit chassis had an integrated tensioner system, I'd try to use it every year.
Edit: The kit chassis does have a tensioner system, but I feel it's not implemented well. The mount bracket for the Toughboxes has slotted mounting holes, so you can pull it one way or another to tension chain. The problem is that if you do everything by the manual (standard 4WD), you'll have two chain runs coming from the Toughbox output shaft in opposite directions, so when you tighten one, you'll be loosening the other. You can get around that with some creative chain routing, but my point is that there isn't a really good tensioning system already integrated.
If I was trying to design the ultimate skid-steer drive, I'd make it somewhat like 254/968/27 style (West-coast drive), like 221's Universal Chassis. If my aim was anything less than "the ultimate skid-steer drive" (if I had limited resources, etc.), I'd go with the kit chassis, 6WD, dropped center (there's already a lowered hole for this in the kit chassis's side rails), and spend my design time creating a great tensioner system.
My $0.02
Team 3129 Green MacHHHHine Founder, Captain (2009-10), Alumnus, and Mentor (2011-14)
2011-13 VEX World Championship...
Unread 03-05-2010, 13:13
Wayne TenBrink's Avatar
Wayne TenBrink Wayne TenBrink is offline
<< (2008 Game Piece)
FRC #1918 (NC Gears)
Wayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond repute
A few items to consider for a good 6 or 8 wheel tank drive (or any other chassis, for that matter):
1) For better turning, keep the track width (side/side spacing) large relative to the wheelbase (front/back spacing). For a long aspect ratio chassis, this requires either lowering the center wheels or using omni wheels at one (6WD) or both (8WD) ends.
2) For better stability, keep the wheelbase long relative to the track width.
3) Ideally you want a good balance between turning ability and stability. A wide aspect with wheels at the corners, or a 6WD with dropped center wheels is about right. If you can fit more traction wheels between the other rigid (non-omni) wheels, that is good and can be done without lowering them.
4) Keep the wheels as close to the frame perimeter as possible.
5) You will spend a lot more time turning, lining up on a game piece, accelerating, and pushing than you will going fast. A "slow/strong" single-speed is usually better suited than a "fast" single-speed, and simpler (to build and drive) than a two-speed.
6) Develop and test chassis designs during the fall/off-season. Try to develop a "system" (chassis structural modules, gearbox mounting, chain tensioners, axle mounts, maintenance & repair accomodation, etc.) that can be adapted to a wide variey of final configurations (wide/narrow, # drive wheels, wheel
size & type, ground clearance, etc.). After kickoff, it is relatively quick to finalize the design and get started on building the "bottom end" while you are still figuring out the "top end" (manipulator). We build our own chassis's and are usually driving by the end of week 2.
NC Gears (Newaygo County Geeks Engineering Awesome Robotic Solutions)
FRC 1918 (Competing at St. Joseph and West MI in 2017)
FTC 6043 & 7911
Unread 03-05-2010, 13:50
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
Step 1: Figure out what you want it to do.
Step 2: Figure out what it takes to get it to do what you want.
Step 3: Figure out how to make what it takes.
Step 4: Adjust your strategy if you can't make what it takes.
Most successful designs follow this process. One of the most successful strategies/designs ever was drive fast, drive straight, have amazing pushing ability, hold position.
So Tee? What would you like your 6x6 or 8x8 to do?
I would give you drastically different advice depending on the game. While our chassis from 2006-2008 look very similar, they have very specific attributes that were very specific to the games those years.
Unread 03-05-2010, 14:16
dtengineering's Avatar
AKA: Jason Brett
Its more than just hardware... it's also in the software.
Put a gyro on your robot and you can make sure that it drives straight, even when you've got unequal drag on each side... or when you're being bumped. A gyro can respond more quickly and accurately than a driver.
We've also found that using seperate control sticks for Forward/Reverse and Left/Right can help tracking. That way, when using "arcade" style driving (rather than tank style, where you control each side or the robot with a seperate stick) when you want to go straight forward you just lift your thumb off the "turning" stick, and you will always get a perfectly straight forward/reverse input to the robot. When you want to stay still and turn, you take your thumb off the forward/reverse, and all you get is turn. Sure... you can tune your deadbands and all that, but this is what we've found to work best.
Jason
What does it take to run an off season? keehun Off-Season Events 12 28-04-2009 08:50
What does it take to brick an RCX (no pun intended)? Billfred Lego Mindstorm Discussion 11 11-06-2007 12:25
what does it take to start a qualifier Dantvman27 FIRST Lego League 3 17-04-2007 14:59
What does it take to be considered and elite team? Jim Schaddelee General Forum 20 24-06-2005 10:59
