Go to Post When you and your friend consider dressing up as a Potentiometer and “magic smoke” for Halloween! - BX MARK [more]
View Poll Results: How do you make your robot?
Just kit of parts 4 2.96%
Kit and 8020 21 15.56%
Welded square stock 38 28.15%
Sheet metal (outside manufacture) 20 14.81%
Sheet metal (we cut the parts) 13 9.63%
Other 39 28.89%
Voters: 135. You may not vote on this poll
Unread 02-05-2010, 19:30
jamie_1930's Avatar
jamie_1930 jamie_1930 is offline
FRC #2228 (Cougartech)
Team Role: Student
jamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to behold
How Do You Make Your Robot?
Since the start of 2228 we've been relying mostly on the kit parts and 8020 (a prototyping building material) to build our robots, and I'm starting to see more and more problems with building this way. 8020 is a prototyping material and it allows you to make quick changes and to guesstemate a lot of things and still be able to get it right. Which at first sounds good, but I've noticed more and more that because we can do those things we've become reliant on them and we don't design as thoroughly as we should be.
So my question to the FIRST community is how do you guys build your robot, do you do what we do and use 8020 (or a similar material), do you make it out of sheet metal, if make it out of sheet metal do you send the designs out and get parts back, do you make the parts yourself, do you weld your frames out of square stock, what?
I'm trying to figure out what are some of the things we can change to improve ourselves and get an idea of what other teams are doing. The only other solution I have in mind right now is to do something similar to the Thunderchickens (217) and Robowranglers (148).
There's a poll included in this thread, but I don't think it will be able to grasp the scope of the differences between teams.
Team 2228(FRC) - Drive Team Lead, Drive Coach, Mechanical Team
Team 3750(FTC) - Team Lead
2009
Team 2228(FRC) - Mechanical Team, Driver at RIT, and Hartford Regionals, and Drive coach at Ruckus
*Second Place at Ruckus
Team 3750(FTC) - Team Lead, and Drive coach at Clarkson Regional
*Second Place at Clarkson Regional
2008
Team 1930(FRC) - Worked on Mechanical, Electrical, and Programming.
Unread 02-05-2010, 19:37
BX MARK's Avatar
BX MARK BX MARK is offline
AKA: Mark
FRC #3542 (S.P.E.E.D.)
BX MARK will become famous soon enoughBX MARK will become famous soon enough
Re: How Do You Make Your Robot?
It all depends on the year/game...1023 useually uses 8020 but last year we needed something lighter, so we used sheet metal (welded togeather).
2011-2012 Team 3542 S.P.E.E.D.
2010/2011Bedford Express Captain
Unread 02-05-2010, 19:51
big1boom big1boom is offline
Chains=Fun
FRC #2022 (Titan Robotics)
big1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of lightbig1boom is a glorious beacon of light
2022 for the past two years has been almost entirely angle aluminum and bolted connections. This allows us to build quickly with our very limited machine shop. (2 saws and couple drills)
Unread 02-05-2010, 19:53
Jared Russell's Avatar
Taking a year (mostly) off
We generally use Bosch-Rexroth aluminum extrusion (very similar to 8020). We use the 20mm cross section profile for just about everything, but we have been known to use 30mm where we need the added strength.
We bolt (or rivet) everything - we seldom use welding if we can help it, since we don't have the equipment at our main shop.
Unread 02-05-2010, 19:54
mikelowry mikelowry is offline
FRC #1771 (N.G.R.)
mikelowry is a name known to allmikelowry is a name known to allmikelowry is a name known to allmikelowry is a name known to allmikelowry is a name known to allmikelowry is a name known to all
For the past 2 years, we have used lasercut plywood. We have a special tabbed design where all the pieces interlock like a 3d puzzle.
2008 Xerox Creativity Award - Championships
2009 Rockwell Automation Innovation in Control award - Peachtree
2009 GM Industrial Design Award - Palmetto
2009 Palmetto Champions <1771 2415 21>
Unread 02-05-2010, 20:04
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
Team 2410 has been using a square tubing frame since it's beggining. We ussualy have a polycarbonate electronics board to go along with it. We have been known to use a bit of al plate when needed aswell. (this year was for parts of the kicker and ball magnet complex, last year was supports for shooter and spiral)
Metal Mustang Robotics 2410 (2008-2011)
2008 STL Rookie All-Star
2010 GKC Finalists
2010 OKC Champions
Alpine Robotics 159 (2012-)
2012 CO Finalists
700 miles from home, 2 miles from FRC. Life is good.
Unread 02-05-2010, 20:29
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
I will have to admit, this is a very kewl way of building chassis. I came by their pits in 09 and man it was a very slick way of making a wood chassis.
1323 uses 2x1 box tubing and we weld everything.
-RC
R.C.
MadTown Robotics Team 1323
Unread 02-05-2010, 20:34
ttldomination's Avatar
Sunny
We use 80-20. It's nice, and it lets us make major changes fairly easily.
But we feel that 80-20s holding us back. It might be, it might not. But we're going to try something new next year. Of course whether it's wood, sheet metal, some of the sort of hybrid, will depend on many factors.
- Sunny
1648: 2013-2014
5283: 2015
Unread 02-05-2010, 21:02
AcesJames's Avatar
AcesJames AcesJames is offline
Mentor, still learning
AKA: James Temple
FRC #2170 (Titanium Tomahawks)(EWCP)
AcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond repute
Send a message via AIM to AcesJames Send a message via MSN to AcesJames
Our team has used welded box and angle aluminum for our frames for every year we've competed, as far as I remember. Our primary sponsor (UTC) usually does the welding for us, as well as some CNC work on the robot, and powdercoating. The CNC is usually used just to create complex designs in the aluminum. For example, our mascots are the 4 Aces, so we usually have the 4 suits (Spade, Heart, Diamond, Club) cut into our aluminum.
Here you can see some of the CNC work, as well as the welding on our 2004 robot, which used mostly angle aluminum
http://www.aceshigh176.org/gallery2/...serialNumber=2
FRC 176 - Aces High - 09-12 - Student
FRC 229 - Division By Zero - 13-14 - "Mentor"
FRC 2170 - Titanium Tomahawks - 17-Now - Mentor
Unread 02-05-2010, 21:19
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
A quick little history on 1726's robot materials:
2006: Almost completely fiberglass pultrusion, jigsawed to shape and bolted together. Weighed a ton.
2007: Beefy pultruded fiberglass drivetrain. Arm constructed with aluminum tube, with second limb constructed from polycarbonate tube. Sheet aluminum ramp.
2008: Fiberglass/Aluminum plate chassis. All upper structures built with aluminum angle/square stock and rivets.
2009: Almost completely plywood and plumbing supplies.
2010: Almost completely welded steel tubing. Plywood electronics board.
Our most successful year: 2009, by far. (yes, the wood and plumbing one)
The biggest thing I've learned through these variations is that there is no universal best material to use for building a robot. Our material selection was based heavily on what the robot had to deal with for each year's particular game.
The other big factor that comes into play is the short time you have to build and test your robot over the 6 week build period. It is crucial to get things built as fast as possible. We were so successful in 2009 because our sponsor's shop (IEWTD) is loaded with heavy duty woodworking tools and we were able to get things built quickly. Build to your strengths!
That said, my favorite materials to work with are plywood and steel. Both are relatively easy to deal with, cheap, and fast to work with. I would never use 80-20 style extrusion for structural robot parts since it's the wrong material for the job. Use what works for you.
Unread 02-05-2010, 21:24
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
We use nuts and bolts and c-channel, aluminium angle, square tubing, windsurfer booms, and whatever else we can get our hands on.
Unread 02-05-2010, 21:54
qzrrbz qzrrbz is offline
FRC #0469
qzrrbz is a splendid one to beholdqzrrbz is a splendid one to beholdqzrrbz is a splendid one to beholdqzrrbz is a splendid one to beholdqzrrbz is a splendid one to beholdqzrrbz is a splendid one to beholdqzrrbz is a splendid one to behold
We use a lot of box and angle aluminum, lots and lots of rivets, and our "signature" .035 half inch aluminum tubing...
Unread 02-05-2010, 21:58
Billfred's Avatar
Billfred Billfred is offline
It's been sheet metal since day one for 2815 (and, this season, 1398).
1618, for my three years with them, met with the most success using the kit frame and angle aluminum construction. (There was the PVC pipe structure in 2008, but that was ultimately mostly for holding up the side panels and flag holder.)
1293 has been mostly sheetmetal over the years, with 80/20 in a supporting role where it made sense. (They've been known to bolt their two drive pods together with it, then attach their superstructure to it, or for a lift mechanism.)
Unread 02-05-2010, 22:12
330 uses the KOP frame... for prototyping and code testing.
For the competition robot, it's always been either box or angle aluminum for the drive frame, and then angle aluminum/box aluminum for the superstructure, with the occasional dose of PVC or fiberglass pultrusion in the manipulator area.
Unread 02-05-2010, 23:21
Chris is me's Avatar
AKA: Pinecone
I'll let someone else from 1714 talk about the robot. I tried to figure out what they made the 2010 one out of but I couldn't see it.
If all goes to plan, Shaker will have built 3 robots with 3 completely different materials. In 2009 the robot's frame was made of pultruded fiberglass. I-beams with cutouts for wheels made up the drivetrain, c-channel all around for bumper mounts. Some aluminum channel and box tubing for the tower, a fiberglass intake, and then lexan for the rest. Pretty cool.
The 2010 frame was made up of 4 1/4" aluminium sheet as side rails, assembled with standoffs. Some 80-20 connected the sides together and formed the rest of the frame. The bumper mounts were a bolted on rectangle of pultruded fiberglass.
Sheet metal is the way of the future...
How would you have built your team's robot differently if the robot could expand? Chris is me General Forum 23 23-04-2009 06:50
How do you make the robot turn a perfect 90 eccmaster Programming 2 16-01-2008 20:54
How did you make your team insignia? vivek16 General Forum 8 24-02-2007 00:20
How do you make your compressorless system work, when all valves "bleed" air slowly? kmcclary Pneumatics 9 17-02-2007 21:01
How did you control your Robot? 1? 2? Wheel? How? ChrisCook Control System 9 17-05-2005 21:41
