Go to Post You know you've been in FIRST way too long when you can remember all those hints... even down to exact wording... and only have to look up the most recent. - EricH [more]
Unread 02-05-2010, 19:38
pic: Rastogi 8wd Iteration 1.2
Unread 02-05-2010, 19:44
Dkt01's Avatar
Dkt01 Dkt01 is offline
Programming Mentor
AKA: David
FRC #1756 (Argos)
Dkt01 will become famous soon enough
Re: pic: Rastogi 8wd Iteration 1.2
Looks great. If I didn't know better, I'd think you had built it already and this was a picture of it.
Unread 02-05-2010, 19:49
gyaniv's Avatar
gyaniv gyaniv is offline
AKA: Gutman Yaniv
FRC #2230 (General Angels)
gyaniv has a spectacular aura aboutgyaniv has a spectacular aura about
Looks great!!!
I have couple of questions for you:...
Does the 4 outer wheels raised?
If the wheels are raised why not going for 8WD instead of 4WD?
Why did you decide to use 4 dual-nano (have no idea what it is but i figured it is a gearbox) instead of 2 gearboxes and using chain/belt to convert the power? might save some weight over there.
I don't know much about sheet-metal drive-train but wouldn't it be wiser to bent the sheet-metal towards the robot instead outwards? My opinion is that it will be much safer, more easy to work with, and stronger. But as i said, i don't know much about sheet-metal drive-train, so i also want to hear an expert on that question...
Thank you
FRC Team 2230 - Student - 2009-2011
FRC Team 2230 & 4406 - Mentor - 2012
FRC Team 2230 - Mentor - 2013-present
"A mentor's job is to understand what the students are trying to make, and bend the laws of physics to make that happen"
Unread 02-05-2010, 19:58
Brandon Holley's Avatar
Why are the hex shafts so long? Just curious, I'm sure its just something you haven't gotten to yet.
Looks good. Designing in sheet metal is a very good thing to learn if your planning on becoming a mechanical engineer of some sorts. I cannot tell you how many sheet metal parts I've designed for my various jobs I've had. It comes in handy for other parts too that aren't necessarily made of "metal" (ie: polycarb, other such plastics) which may be created using the same techniques as standard sheet metal parts.
Also very handy with sheet metal are PEM fasteners. If you can master their usage, you can create really sleek sheet metal designs.
Have you done any FEA on the frame? Its sometimes difficult to gauge the "strength" of a design from sheet metal, especially when first starting to design in sheet. My only comment would be to add a cross member lower on the frame to add another axis of stability, however it may be unnecessary, thats what analysis is for!
Brando
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 02-05-2010, 20:04
jamie_1930's Avatar
jamie_1930 jamie_1930 is offline
FRC #2228 (Cougartech)
Team Role: Student
jamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to behold
Originally Posted by gyaniv View Post
Looks great!!!
Thank you
I immediately questioned why the metal was bent out and all though I don't have his answer to it in my opinion it is better to bend out because when you bolt things to the top it allows easier access to the nuts than reaching your hand around to the inside.
Team 2228(FRC) - Drive Team Lead, Drive Coach, Mechanical Team
Team 3750(FTC) - Team Lead
2009
Team 2228(FRC) - Mechanical Team, Driver at RIT, and Hartford Regionals, and Drive coach at Ruckus
*Second Place at Ruckus
Team 3750(FTC) - Team Lead, and Drive coach at Clarkson Regional
*Second Place at Clarkson Regional
2008
Team 1930(FRC) - Worked on Mechanical, Electrical, and Programming.
Unread 02-05-2010, 20:12
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
With little experience designing sheet metal chassis, I will share my opinions anway.
1. Any reason for folding out instead of in? Without that pesky bolt heads frame perimeter rule, there should be no reason to cover the bolt heads.
2. What material is the dead axle? I assume a 3/8" pipe, taped at the end, with a bolt holding it in.
3. Again, why the dual-nano?
3a. You could alternatively make the distance between the two side plates exactly the width of an AM Shifter, then put an AM Shifter inside (with the chassis sides as the side plates). Or, you could just use an SuperShifter or Toughbox as you do now, with a live axle, then chain the other side.
4. Why the bump-climbing notch? Assuming there is less terrain then this game...
5. I like the render. Looks very real.
Kettering Motorsports
Unread 02-05-2010, 20:18
Yup, just didn't get to that yet, its just the standard AM model length.
I haven't learned proper testing, that's a big part of CAD I plan to learn shortly.
I'm not sure what you mean. The center 4 wheels are lowered 3/16" for barely a rock.
I'm just trying out new nano configurations and it decreases chain usage. I haven't calculated how much power I'm getting to the wheels as apposed to using a single gearbox with dual CIMs per side.
This is a question I have for the experts too. Right now I'm just creating "shells" for the main structures as I've seen done with team 1902's 2008 and 2010 frames. I assume it is actually easier to work with the frame pieces this way because you have more access to the open surfaces of the material.
I definitely like this idea. Right now I was just going for something that is direct drive, but I'm liking the built in SuperShifter idea a lot.
Thanks for the questions. More suggestions and advice are welcome and appreciated.
Chris is me's Avatar
AKA: Pinecone
edit: akash is a ninja delete plz
Unread 02-05-2010, 20:25
sgreco's Avatar
sgreco sgreco is offline
AKA: Steven Greco
FRC #2079
sgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond repute
I would say you're fine for powering from four separate locations as opposed to one central spot on each side. If it shortens the chain runs and makes maintenance easier, it's a good trade-off.
I can't see the stress tests for this, but as a typical rule of design you want the most support in the middle, as that's where it'll break first. I would take out some of the pocketing in the middle, it'll likely only add fractions of a pound anyway.
Overall it looks great though. Your rendering and designing skills have gotten really good, great job.
Unread 02-05-2010, 21:01
Jamie Kalb Jamie Kalb is offline
Jamie Kalb is a name known to allJamie Kalb is a name known to allJamie Kalb is a name known to allJamie Kalb is a name known to allJamie Kalb is a name known to allJamie Kalb is a name known to all
If you've got PEM nuts inserted in the flanges to bolt things to the top, you never need to reach under the flange to hold a nut...
*hint - Akash, PEM nuts are good - hint*
Looks really good, though. Really imposing. Keep it up!
Team 3129 Green MacHHHHine Founder, Captain (2009-10), Alumnus, and Mentor (2011-14)
2011-13 VEX World Championship...
Unread 02-05-2010, 21:14
AKA: Pinecone
I'm of the opinion it would be faster to stress test a prototype then it would be to run complete and thorough FEAs on stuff like this anyway. We should just build one.
Unread 02-05-2010, 21:15
RMS11's Avatar
RMS11 RMS11 is offline
Safety!!!!
AKA: Rick
FRC #2415 (WiredCats)
Team Role: Driver
RMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to behold
Send a message via AIM to RMS11
Where here would you attempt to use PEM nuts. I was looking at them on mcmaster, and they look cool, but pressing all of them seems time consuming when you could just use rivets or a nut and bolt instead. In the long run it might save a bit of time though... Any other big advantages of them? thanks!
2009 Peachtree Regional Champs
2009 Palmetto Regional Champs
2008 Peachtree Rookie All Star and Rookie Highest Seed
Unread 02-05-2010, 21:17
rulesall2 rulesall2 is offline
Team Role: Tactician
rulesall2 has much to be proud ofrulesall2 has much to be proud ofrulesall2 has much to be proud ofrulesall2 has much to be proud ofrulesall2 has much to be proud ofrulesall2 has much to be proud ofrulesall2 has much to be proud ofrulesall2 has much to be proud ofrulesall2 has much to be proud of
Something I've noticed, only because we ran into the same problem this year, is that you have effectively created a giant piece of C-channel. Moving those cross-braces down to form an I-beam shape or adding ones near the bottom should strengthen the design a bit. Just some thoughts, but I like where this is heading.
Unread 02-05-2010, 21:22
Andrew Remmers's Avatar
Andrew Remmers Andrew Remmers is offline
AKA: Andrew Remmers
Andrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond repute
Send a message via AIM to Andrew Remmers
Being on 1902 I can say that when the flanges are facing outward it is significantly easier to run maintenance on the drive train. Considering that the space you are working with is already very small it is difficult to get to all the components even on the robot we have this year. I can only imagine what it would have been like if it were the other way around, having that "obstacle" in the way would have made some points of repair for us very difficult especially when we had a master link failure at Florida.
Also what I think with the flanges facing inward towards each other means you would have to design enough space for your chain/belt to run depending on your configuration. Which means you might have less space elsewhere for another mechanism or something like that.
BTW very nice render It has inspired me to get finished with my school work faster so i can finally get around to designing my own sheet metal drive train!
Exploding Bacon 2007-2011
Built and Dangerous (B.A.D) 2011-2012
Community Mentor / School Break 2012-2014
North American Robotics: The MooseEagles Founding Member 2012-Present (VEX U)
Last edited by Andrew Remmers : 02-05-2010 at 21:24. Reason: Forgot some information.
Unread 02-05-2010, 22:17
Ah thanks for the insight Andrew.
You might also like this. I tried to copy it from one of the pictures that was posted of your 2010 bot.
pic: Sheetmetal 8wd Akash Rastogi Extra Discussion 16 02-05-2010 15:38
pic: Prototype Iteration 1 JesseK Extra Discussion 5 17-01-2010 12:40
pic: 8WD 'Suspension' Chassis Concept JesseK Extra Discussion 8 09-12-2008 22:00
pic: Concept 8wd Drivetrain sdcantrell56 Technical Discussion 77 25-11-2008 23:05
