| View Poll Results: How do you make your robot? | |||
| Just kit of parts |
4 | 2.96% |
| Kit and 8020 |
21 | 15.56% |
| Welded square stock |
38 | 28.15% |
| Sheet metal (outside manufacture) |
20 | 14.81% |
| Sheet metal (we cut the parts) |
13 | 9.63% |
| Other |
39 | 28.89% |
| Voters: 135. You may not vote on this poll | |||
#19
Re: How Do You Make Your Robot?
330 uses the KOP frame... for prototyping and code testing.
For the competition robot, it's always been either box or angle aluminum for the drive frame, and then angle aluminum/box aluminum for the superstructure, with the occasional dose of PVC or fiberglass pultrusion in the manipulator area. |
| How would you have built your team's robot differently if the robot could expand? | Chris is me | General Forum | 23 | 23-04-2009 06:50 |
| How do you make the robot turn a perfect 90 | eccmaster | Programming | 2 | 16-01-2008 20:54 |
| How did you make your team insignia? | vivek16 | General Forum | 8 | 24-02-2007 00:20 |
| How do you make your compressorless system work, when all valves "bleed" air slowly? | kmcclary | Pneumatics | 9 | 17-02-2007 21:01 |
| How did you control your Robot? 1? 2? Wheel? How? | ChrisCook | Control System | 9 | 17-05-2005 21:41 |
