Go to Post To ANY Robowrangler students reading this thread: If any of you ask me about the game hint, at any time, you will be assigned 4 hours of shop cleaning duty during week 1. No exceptions. - JVN [more]
View Poll Results: How do you make your robot?
Just kit of parts 4 2.96%
Kit and 8020 21 15.56%
Welded square stock 38 28.15%
Sheet metal (outside manufacture) 20 14.81%
Sheet metal (we cut the parts) 13 9.63%
Other 39 28.89%
Voters: 135. You may not vote on this poll
Unread 02-05-2010, 23:31
1086VEX's Avatar
1086VEX 1086VEX is offline
VA FIRST Alumni
AKA: Alex Curfman
FRC #0384 (Sparky)
1086VEX is a glorious beacon of light1086VEX is a glorious beacon of light1086VEX is a glorious beacon of light1086VEX is a glorious beacon of light1086VEX is a glorious beacon of light
Re: How Do You Make Your Robot?
the past 4 years team 1086 has used a bent sheet metal frame, this year using our sponsors new CNC laser cutter to cut the hole pattern. in years before we hand punched the holes.
Unread 03-05-2010, 11:05
Jon Stratis's Avatar
Jon Stratis Jon Stratis is online now
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
We start with the kitbot frame (it may be heavier that some other solutions, but it's the quickest thing we can get going, and it have everything you want in a frame). From there, it's pretty much all sheet metal and angle stock. We usually end up having the machine shop at our primary sponsor do a few small things for us (lightening holes or complicated patterns), but 99% of the work is done in house, by the kids.
Unread 03-05-2010, 11:32
Joining the 900 Meme Team
FRC #0079
This year 397's robot was quite literally 2 KOP frames stacked on top of each other. We used 80/20 in between them. This made our frame quite heavy but incredibly rigid. It also gave us the benefit of letting us play with the mounting height of our kicker until we liked it by sliding it up and down.
In the past we have used the KOP frame and 1" square tube to build the robot. We bend the tube in house using a standard pipe bender. This can then be bolted together (or welded). The only time this method was a problem was in 2008 when the force of the launcher changed the shape of our frame as we fired. I'm sure someone has a picture of 397 hitting their frame with a hammer to make it go back square. I personally like the bent tube construction method. But as always, you work with the resources you have.
http://www.chiefdelphi.com/media/photos/27139 2007
http://www.chiefdelphi.com/media/photos/23321 2006
http://www.chiefdelphi.com/media/photos/30277 2008
http://farm4.static.flickr.com/3348/...cd2aa38f_b.jpg The fun bent parts in 2009. That PVC ring was a prototype, the final one was made of aluminum round tubing and bent by hand.
Unread 03-05-2010, 12:59
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
In years 2005-2009 we used the kit frame and aluminum angle and box for the other assemblies. In 2008 we used a smaller version of 80-20 on the speed racer robot and had some 1x1 80-20 in the upper frame work for our 2009 robot. This year we decided to use 80-20 for our robot frame as it was great for prototyping, moving stuff around, and very, very strong. However like many teams it ate up weight, parts shifted (a lot), and was a hassle when we ran out of sliders and brackets. Team 234 said in their swerve drive implementation conference that 80-20 is a great prototype, but aluminum box is better for the final as it is lighter and parts don't slide around.
I hope our team uses more aluminum box in our construction to help save on weight and parts moving, but a strong rigid frame was desired in our first meetings of the season which 80-20 accomplishes until parts move around.
1058 PVC Pirates 2016 - xxxx
Unread 03-05-2010, 13:08
Chris is me's Avatar
AKA: Pinecone
Did you guys drill through the extrusion when you finalized part locations? That basically keeps all the advantages of 80-20 and takes away the sliding problem.
Unread 03-05-2010, 13:32
AKA: Brendan Browne
Yes, that was one of the solutions we had. Specifically with the wheels we took angle supports and bolted them to the frame to keep the wheels from sliding if they came loose. Loctite was another useful tool, but we also had problems with vertical frame members moving horizontally which we fixed by placing bolts vertically from one frame member to another. But adding more bolts just increases one of its disadvantages: weight.
Unread 03-05-2010, 13:44
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
95 has used plywood frames with angle aluminum brackets frequently, and with great success. Recently we've started welded the kit chassis together which makes it both lighter and stiffer than using the bolted connections. Every year we've used the kit frame we've always dropped a sheet of something in the middle of the kit frame to strengthen it up.
If you have easy access to welding, a welded frame could work out very well for you because it is such a flexible fabrication technique. Be careful with welded aluminum frames because if you weld 6061 it loses its temper, 50xx series (that the kit frame is made out of) has no temper and so does not lose strength with welding.
Unread 03-05-2010, 17:23
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
We have a mixture of square tubing sub frames, machined plates and small parts, sheetmetal/sheet plastic fabricated brackets made using our shear and brakes, round tube, COTS, purchased sheetmetal shapes from IFI (now called VEXPro), welding, and whatever else we can think off. We pretty much do whatever we can to make what we need.
Thank-you 294 & 67
www.bobcatrobotics.org
Unread 03-05-2010, 19:36
hallk's Avatar
hallk hallk is offline
A member of many teams...
AKA: Katie Hall
FRC #0537
hallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud ofhallk has much to be proud of
Send a message via AIM to hallk
Most of the teams I work use a press fit Aluminium tube system like this one http://www.mcmaster.com/#press-fit-f...ystems/=5bymjz
Systems like this are light-weight, fast to assemble, easy to modify, strong, and relatively cheap. I wish all my teams would use something like this.
I think welding is a great and fun skill for kids to use but it can be prohibitive to use during the build season if the welders don't have much experience.
Unread 03-05-2010, 22:26
gorrilla's Avatar
gorrilla gorrilla is offline
1557 alumni, 4639 mentor
AKA: adam spears
FRC #4639 (RoboSpartans)
gorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant future
We have used the kit frame and 1' square tube or 1/2'-1.5' angle for nearly everything on our robots, from 05'-10'.
We have been very successful with this method.
Each year we have built the fram in two pieces(a drivebase and an upper structure for everything on top) then either welded, bolted, or welded and bolted(07') the two pieces together.
It's easy, cheap, reliable, quick, light, and very strong, plus we dont really need any machine other than a saw and drill to build everything*
*welding was done by a parent or mentor
Adam Spears
Team 1557 2007-2011 student-Lake County FL
Current Team 4639 mentor- Houston TX
Unread 04-05-2010, 08:42
Durza16's Avatar
Durza16 Durza16 is offline
FRC #2062 (C.O.R.E.)
Team Role: Electrical
Durza16 is on a distinguished road
Team 2062 uses item normally, its a strong, lightweight, and durable aluminum. This last year though we used kit of parts for our frame.
www.core2062.com
Unread 04-05-2010, 12:16
AKA: Pinecone
Did you guys use ITEM for the rest of your frame, or 80-20 extrusion? It seemed very strong in preship videos when you guys had mentors doing pullups on the sides; I didn't think 80-20 could do that.
Unread 04-05-2010, 16:42
Tom Bishop's Avatar
Tom Bishop Tom Bishop is offline
FRC #0832 (Oscar)
Tom Bishop has a brilliant futureTom Bishop has a brilliant futureTom Bishop has a brilliant futureTom Bishop has a brilliant futureTom Bishop has a brilliant futureTom Bishop has a brilliant futureTom Bishop has a brilliant futureTom Bishop has a brilliant futureTom Bishop has a brilliant futureTom Bishop has a brilliant futureTom Bishop has a brilliant future
We have used water-jetted aluminum plate for our frames, with other assorted aluminum and polycarbonate machined pieces for mountings and other parts.
Before that we used 1" welded aluminum box. We stopped using that system because it tended to be heavy and it's hard to modify if you need to change something.
The water-jetted parts are perfect and light but do put a lot of pressure on the CAD operator not to screw things up.
Unread 04-05-2010, 17:56
lil'est lavery's Avatar
lil'est lavery lil'est lavery is offline
AKA: Megan Lavery
FRC #0116 (Epsilon Delta)
lil'est lavery has a brilliant futurelil'est lavery has a brilliant futurelil'est lavery has a brilliant futurelil'est lavery has a brilliant futurelil'est lavery has a brilliant futurelil'est lavery has a brilliant futurelil'est lavery has a brilliant futurelil'est lavery has a brilliant futurelil'est lavery has a brilliant futurelil'est lavery has a brilliant futurelil'est lavery has a brilliant future
The structure of the robot varies every year depending on how we decide to approach the game. We generally have an aluminum frame made from square stock that can be drilled through so additions can be attached. Team 116 also uses sheet metal, plexiglass, carbon fiber and other materials all depending on the purpose. This past season we made a rectangular bot with a kicker, vacuum, and hook attached (frame made from square stock). Last year we used a rectangular frame from aluminum square stock with a large cylinder on top made from plexiglass and aluminum that was used to guide orbit balls up to our shooter.
Who Team 116?
Unread 04-05-2010, 20:12
jamie_1930's Avatar
jamie_1930 jamie_1930 is offline
FRC #2228 (Cougartech)
Team Role: Student
jamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to behold
You mentioned some of the pros of this material can you list, if any, it's cons? Also what version do you typically use? For instance with 8020, 1010 is the most commonly used, to my knowledge.
Team 2228(FRC) - Drive Team Lead, Drive Coach, Mechanical Team
Team 3750(FTC) - Team Lead
2009
Team 2228(FRC) - Mechanical Team, Driver at RIT, and Hartford Regionals, and Drive coach at Ruckus
*Second Place at Ruckus
Team 3750(FTC) - Team Lead, and Drive coach at Clarkson Regional
*Second Place at Clarkson Regional
2008
Team 1930(FRC) - Worked on Mechanical, Electrical, and Programming.
How would you have built your team's robot differently if the robot could expand? Chris is me General Forum 23 23-04-2009 06:50
How do you make the robot turn a perfect 90 eccmaster Programming 2 16-01-2008 20:54
How did you make your team insignia? vivek16 General Forum 8 24-02-2007 00:20
How do you make your compressorless system work, when all valves "bleed" air slowly? kmcclary Pneumatics 9 17-02-2007 21:01
How did you control your Robot? 1? 2? Wheel? How? ChrisCook Control System 9 17-05-2005 21:41
