Go to Post The robot uprising has begun. - SpoonMechanic [more]
Unread 02-05-2010, 22:41
Andrew Remmers's Avatar
Andrew Remmers Andrew Remmers is offline
AKA: Andrew Remmers
Andrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond repute
Send a message via AIM to Andrew Remmers
Re: pic: Rastogi 8wd Iteration 1.2
Originally Posted by Akash Rastogi View Post
Ah thanks for the insight Andrew.
You might also like this. I tried to copy it from one of the pictures that was posted of your 2010 bot.
:O that looks strangely familiar! you did this in solid works right? (i need to find a copy of that...) I'm still using inventor and a little bit of Pro-E.
Exploding Bacon 2007-2011
Built and Dangerous (B.A.D) 2011-2012
Community Mentor / School Break 2012-2014
North American Robotics: The MooseEagles Founding Member 2012-Present (VEX U)
Unread 02-05-2010, 22:57
Jamie Kalb Jamie Kalb is offline
Jamie Kalb is a name known to allJamie Kalb is a name known to allJamie Kalb is a name known to allJamie Kalb is a name known to allJamie Kalb is a name known to allJamie Kalb is a name known to all
Originally Posted by RMS11 View Post
Where here would you attempt to use PEM nuts. I was looking at them on mcmaster, and they look cool, but pressing all of them seems time consuming when you could just use rivets or a nut and bolt instead. In the long run it might save a bit of time though... Any other big advantages of them? thanks!
I'm not good at judging measurements from pictures, but it looks to me like the current flanges aren't big enough. But if the flanges bent off the main body of those enormous side plates were wider (or is that longer?), you could punch holes in them and press the PEM nuts in. As far as I know, many sheet metal shops can do this in-shop. Check out the 217/148 Sheet Metal video. It shows them pressing PEM nuts at about 5:05 in the video. Not time-consuming at all. Compare the ~1 second per insert to all the time you'd spend fumbling for a nut ... total. For a season.
Whenever possible, I like to add threads to a part (tapping or threaded insert) rather than using a nut. One less piece to worry about, one less piece to come loose, one less point you have to reach for assembly/maintenance. Plus installation and removal now only takes one hand!
But Andrew's 100% right about this:
Originally Posted by Joyride_67_1902 View Post
Being on 1902 I can say that when the flanges are facing outward it is significantly easier to run maintenance on the drive train. Considering that the space you are working with is already very small it is difficult to get to all the components even on the robot we have this year. I can only imagine what it would have been like if it were the other way around, having that "obstacle" in the way would have made some points of repair for us very difficult especially when we had a master link failure at Florida.
Having the flanges bent in rather than out definitely does make drivetrain maintenance harder. It's possible to make the plates modular enough to justify this, but you're probably better off just keeping them facing outwards.
Team 3129 Green MacHHHHine Founder, Captain (2009-10), Alumnus, and Mentor (2011-14)
2011-13 VEX World Championship...
Unread 03-05-2010, 02:18
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Nice Render,
Slightly curious what's the weight?
-RC
R.C.
MadTown Robotics Team 1323
Unread 03-05-2010, 03:33
CraigHickman
Posts: n/a
Looking good.
Also, I'll second (third?) the recommendation for using PEM nuts. We use them at my work on our sheet metal chassis, and they're wonderful to deal with. Out of 75 robots, we had one PEM nut pop loose, and the shop that pressed them fixed it for us in less than 6 hours. PEM nuts are the way to go.
How many parts in there are standardized? It's always easier for a sheet metal shop to punch out and break more similar parts than differing ones.
Unread 03-05-2010, 15:47
Originally Posted by CraigHickman View Post
Looking good.
I'll definitely check out PEM nuts.
There are only 3 different parts here. All sideplates at the same, all cross members are the same, and brackets in between plates are the same.
Unread 03-05-2010, 17:31
CraigHickman
Posts: n/a
Wonderful! Keep up the awesome work!
Unread 03-05-2010, 17:32
AdamHeard's Avatar
Lead Mentor
Why not connect the two side assemblies along the bottom?
Unread 03-05-2010, 19:34
Can't see it, but there's one along the bottom on the other side. The near side is open because I was working on a 148/217 style cam kicker for fun.
Unread 03-05-2010, 21:51
DonRotolo's Avatar
Back to humble
FRC #0832
I disagree. The sideplate will tend to be pushed inward by any contact from other robots or field elements. In such a case, your flange will tend to be in compression. Such a small flange will buckle. If the flange was on the inside, it would be in tension, a mode that is far stronger than the compression mode. Try it yourself with a piece of angle.
Second, you might consider putting flanges on some of those inside cutouts. Yes, it ends up a little heavier, but because the outer flange is not continuous you will suffer from low rigidity (and low resistance to bending) at certain points; use flanges to compensate.
Akash, when you're doing your analysis, be sure to model loading from another robot hitting you from the side at several locations.
Unread 03-05-2010, 21:55
I was thinking about this for a while, but I am not familiar with capabilities of sheetmetal manufacturing.
Could you, or anyone else, elaborate on what types of places flanges can be made on a part like this? I wanted to add flanges on some of the inside pockets but wasn't sure if that was easily possible. Like I said, I'm looking to learn about this as much as possible.
Thanks.
Unread 03-05-2010, 22:05
You're right; I didn't think about that. You definitely want flanges like that in tension.
And,
How would you bend a flange out from an inside cutout? Would you just use a really small (short) set of jaws on a brake, or is there another tool to do that?
Thanks!
Last edited by Jamie Kalb : 03-05-2010 at 22:14. Reason: didn't get it the first time
Unread 03-05-2010, 22:19
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
The same as they would with an outside bend; they just move the bending dies around and leave gaps where there is material that should not be bent.
This past year, 228 used a bunch of these inside bends on our GUSwerve modules to mount the lower bearing plate on. Here's a photo:
Art Dutra IV
世上无难事,只怕有心人.
Unread 03-05-2010, 22:23
Excellent, I'll definitely be changing things around a lot then.
Unread 03-05-2010, 22:26
Lightbulb Re: pic: Rastogi 8wd Iteration 1.2
Ohhhh! Gaps in the die! Duhhhh! Now I get it. Thanks. (the picture helped)
Hey, Akash, you can bend flanges from an inside cutout!
Unread 04-05-2010, 07:22
sgreco's Avatar
sgreco sgreco is offline
AKA: Steven Greco
FRC #2079
sgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond repute
I'm sort of in the process of leanring about the techniques of sheetmetal fabrication so I don't really know, but right now this is a fairly straightforward part to make, especially if you have a laser cutter. What I don't know is will adding those inner flanges add significantly to the fabrication time? I would imagine if in fact more strength was needed it would be easier and more robust to just add more cross supports between the inner and outer plate.
pic: Sheetmetal 8wd Akash Rastogi Extra Discussion 16 02-05-2010 15:38
pic: Prototype Iteration 1 JesseK Extra Discussion 5 17-01-2010 12:40
pic: 8WD 'Suspension' Chassis Concept JesseK Extra Discussion 8 09-12-2008 22:00
pic: Concept 8wd Drivetrain sdcantrell56 Technical Discussion 77 25-11-2008 23:05
