#31
Re: pic: Rastogi 8wd Iteration 1.2
I'm not an experienced sheet metal designer, but what CAD program is that in?
Thaine |
#32
I would add in some triangulation in the x-y plane. Other than that I think it looks solid.
What material were you planning on making it out of? |
#33
Its .09" thick sheetmetal. I'm not totally positive what grade of aluminum most teams use in their construction so right now I just had it set to 6061 T6. Anyone want to answer that? |
#34
Sheet Metal is usually 5052, John or Art can confirm that (or anyone with sheet metal knowledge). 6061 just isn't that great for bending. Btw how much does this DT weigh? -RC |
#35
(edit: Just checked the BOM at work... Turns out I was a digit off. Whooops.) Last edited by CraigHickman : 04-05-2010 at 14:27. |
#36
Every sheet metal place I've called up (now why would I be doing that? lol) uses 5052. 6061 isn't very bendable at all, apparently.
#37
KOP stuff is 5052 from AM (iirc), our other sheet metal parts were also 5052. 6061 likes to crack when it's bent parallel to the grain structure. I have also done sheet metal work with 3003 and 1100, which are very easy to bend, but weaker than 50xx aluminums.
#38
5052 is the stuff for bending, as most of you have stated. Whatever sheet metal house is helping you guys out will tell you the same thing. -Brando |
#39
Just a question: Is a sheet metal chassis lighter than an 8020 or 1/16 aluminum square tubing chassis?
Also, is there any sort of guide on building a sheet metal chassis? |
#40
As for the tube chassis, I would think that a welded 1/16" aluminum tube chassis would probably be lighter as well as a bit easier to manufacture than a sheet metal frame. Sheet metal is nice if you have the resources and if you understand how to design to its strengths, but I dont see it as the miracle construction method that a lot of people on CD seem to see it as. |
#41
Thaine |
#42
We've used 1/16 wall 1"x1" aluminum tubing with Nylon connectors for the past 4-5 years. Hopefully, we get access to our school's $2 million dollar tech shop (we've been working at a Magna Seating Facility), allowing us to experiment with sheet metal construction.
#43
... in theory. ![]() |
#44
For inexperienced and novice designers, chassis construction methods are far less important than actual design skills and features included.
You'll see crappy extuded tubing drives alongside crappy sheetmetal drives alongside great forms of both. Buuuuut, after a few years you come to realize nothing beats good 'ol 2x1 ![]() |
| pic: Sheetmetal 8wd | Akash Rastogi | Extra Discussion | 16 | 02-05-2010 15:38 |
| pic: Prototype Iteration 1 | JesseK | Extra Discussion | 5 | 17-01-2010 12:40 |
| pic: 8WD 'Suspension' Chassis Concept | JesseK | Extra Discussion | 8 | 09-12-2008 22:00 |
| pic: Concept 8wd Drivetrain | sdcantrell56 | Technical Discussion | 77 | 25-11-2008 23:05 |
