Go to Post I want to use some of that mass-less rod in our robot - saves weight. - ebarker [more]
  #61   Spotlight this post!
Unread 03-05-2010, 19:07
Joining the 900 Meme Team
FRC #0079
Re: Regarding The cRio
Originally Posted by davidthefat View Post
The max for arduino is 9600 baud rate
No it isn't. http://www.arduino.cc/en/Serial/Begin I've run mine at 115200 and it works fine.
  #62   Spotlight this post!
Unread 03-05-2010, 19:12
theprgramerdude theprgramerdude is offline
WPI Freshman
AKA: Alex
FRC #2503 (Warrior Robotics)
theprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud of
Isn't that still a seriously low level of bandwidth?
I guess knowing what you are passing back and forth, it might only have to come down to raw, simple data that gets proccessed, and the results are passed back just as simply, but still...
  #63   Spotlight this post!
Unread 03-05-2010, 19:19
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
LULZ I was looking at http://arduino.cc/en/Reference/SoftwareSerial
  #64   Spotlight this post!
Unread 03-05-2010, 20:12
biojae's Avatar
biojae biojae is offline
Likes Omni drives :)
AKA: Justin Stocking
FTC #5011 (BOT SQUAD) && FTC#72(Garage bots)&& FRC#0399 (Eagle Robotics)
biojae is a jewel in the roughbiojae is a jewel in the roughbiojae is a jewel in the rough
If you are seriously considering an arduino, then why don't you use one of the ethernet shields?
http://www.adafruit.com/index.php?main_page=product_info&cPath=17_21&produ cts_id=83
http://www.sparkfun.com/commerce/pro...oducts_id=9026
that would leave the serial port on the cRio open, and dwould allow a network switch to combine several on the robot.
The sparkfun shield communicates over SPI, which theoretically has a higher bandwidth then the serial comms that it is replacing
FTC Team 72 - No site
FRC Team 399 - http://www.team399.org
2010 Rockwell Collins Innovation in Control Award - (Use of the CAN bus, among other reasons) Phoenix, Arizona!
  #65   Spotlight this post!
Unread 04-05-2010, 19:26
WPI Freshman
AKA: Alex
Don't other electronics, such as the Jaguars, use BIOS batteries?
  #66   Spotlight this post!
Unread 04-05-2010, 20:06
biojae's Avatar
No, only the compactRio has a bios battery for its real time clock.
I have a picture of the insides of a jaguar which i will edit my post to attach (can't find it right now)
  #67   Spotlight this post!
Unread 04-05-2010, 20:24
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
There are cheaper alternate to the Arduino, the mbed, has CAN, Ethernet, file system and serial all built in at $50 only bad side id teh compiler is only online
Reimaging the cRio Issues there are no cRio devices on the subnet Stuart FRC Control System 2 25-02-2009 23:41
Question about Rules regarding the cRIO tbd FRC Control System 1 08-02-2009 12:52
What are the rules regarding joysticks, etc. for the Operator Interface? itay_ms Rules/Strategy 1 17-01-2007 12:16
An excellent discussion on #firstrobotics regarding Vex and the future of the US sanddrag General Forum 18 25-03-2006 17:56
Regarding <G13> - placement of the tetra by the human player. Leav Rules/Strategy 7 02-02-2005 10:26
