Thread Tools |
Rating:
Display Modes |
Re: Small Pneumatic Tires
McMaster has a pneumatic caster tire: 2717T51 Pneumatic Wheel for Casters Gray, 6" X 2", 3/4" Axle, Ball Bearing, 200# Cap In stock at $19.27 Each It has a split rim that would require some sort of adapter or custom split rim (as mentioned above). |
We did have a custom adapter made in at least one of those years; ShaneP designed it, IIRC. |
Another good option would be skyway's 8"x 2" caster wheel (they really measure around 7.5"). They have light weight plastic hubs, 7/16 bearings, and a 4 lug bolt pattern that can be adapted to standard AM sprockets with a bit of drilling and a few standoffs. Also a wide range of tires are available with different material and tread options. I believe both 2753 and 469 used them this year (correct me if I am wrong on 469).
http://www.skywaywheels.com/products_004.htm (all the way at the bottom of the page) |
Actually, we used these this year as well as 2006... I know a few other teams that like them too. Rockstar hubs with a custom sprocket adapter...
http://www.mbs.com/productcart/pc/vi...?idCategory=43 |
| Rules for Pneumatic Tires? | team2491 | Rules/Strategy | 12 | 23-01-2010 11:15 |
| Pneumatic Tires | V3NOM813 | General Forum | 9 | 19-01-2010 17:02 |
| Help! Can we use small pneumatic cylinders from 2003? | Justin_302 | Pneumatics | 4 | 20-02-2005 13:13 |
| small pneumatic valves | technic master | Technical Discussion | 8 | 07-10-2004 19:18 |
| Wheel wear??? 6" Pneumatic tires??? | Scott358 | Technical Discussion | 11 | 29-03-2003 13:35 |
