Go to Post "The reason we struggle with insecurity is because we compare our behind-the-scenes with everyone else's highlight reel." - davidthefat [more]
Unread 05-05-2010, 19:23
Rdeckj Rdeckj is offline
FRC #2075
Rdeckj is an unknown quantity at this point
Use of pop-rivets?
Hey, guys. Just wondering how many of your teams out there use pop rivets extensively (or at all) Looking at other bots, i noticed other teams dont use them nearly as much as we do. Just seeing what everyone else does, im not build team, so im not really involved with why we do what we do in some regards.
Unread 05-05-2010, 20:05
M.Wong's Avatar
M.Wong M.Wong is offline
FRC #0503 (Frog Force)
M.Wong is a jewel in the roughM.Wong is a jewel in the roughM.Wong is a jewel in the rough
Re: Use of pop-rivets?
We really only use them on IFI wheels. Other than that, we really don't. We've found that replacing a rivet takes longer than a bolt, and rivets aren't quite as forgiving when replacing.
Unread 05-05-2010, 20:10
Aren_Hill's Avatar
Build Nifty Things
I know a few people who will argue you to the death on that one.
If you want to see rivets, check out a 1501,217,148,33 machine
A guy who likes robots.
Unread 05-05-2010, 20:12
David Brinza's Avatar
David Brinza David Brinza is offline
Lead Mentor, Lead Robot Inspector
FRC #0980 (ThunderBots)
David Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond repute
We like to use them with sheet metal and lexan portions of our robot. It's easy to drill them out if we need to replace the hardware. As you know, they're quick and easy to install and rivets won't rattle loose like screws do.
"There's never enough time to do it right, but always time to do it over."
2003 AZ: Semifinals, Motorola Quality; SoCal: Q-finals, Xerox Creativity; IRI: Q-finals
2004 AZ: Semifinals, GM Industrial Design; SoCal: Winners, Leadership in Controls; Championship: Galileo #2 seed, Q-finals; IRI: Champions
2005 AZ: #1 Seed, Xerox Creativity; SoCal: Finalist, RadioShack Controls; SVR: Winners, Delphi "Driving Tomorrow's Technologies"; Championship: Archimedes Semifinals; IRI: Finalist
2007 LA: Finalist; San Diego: Q-finals; CalGames: Finalist || 2008 San Diego: Q-finals; LA: Winners; CalGames: Finalist || 2009 LA: Semifinals; Las Vegas: Q-finals; IRI: #1 Seed, Finalist
2010 AZ: Motorola Quality; LA: Finalist || 2011 SD: Q-finals; LA: Q-finals || 2013 LA: Xerox Creativity, WFFA, Dean's List Finalist || 2014 IE: Q-finals, LA: Finalist, Dean's List Finalist
2016 Ventura: Q-finals, WFFA, Engineering Inspiration
Unread 05-05-2010, 20:13
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
We use lots of rivets, as we do a lot with sheet metal. Lots.
Kettering Motorsports
Unread 05-05-2010, 21:22
TEE's Avatar
TEE TEE is offline
FRC #0201
TEE has a spectacular aura aboutTEE has a spectacular aura aboutTEE has a spectacular aura about
We used pop rivets this year for our wheel mounts, and they worked fine for us.
Edit: The mounts were bolted on, we riveted additional supports on
Unread 05-05-2010, 21:37
M.Wong's Avatar
Sorry I should have elaborated. My team uses 1/16" thick 1"x1" aluminum tubing in most of our applications (we haven't quite reached a point where we use sheet metal). Our style of robot building works well with bolts, and I don't really see us changing (unless we start using sheet metal more extensively).
Unread 05-05-2010, 21:42
IzzieB IzzieB is offline
coPresident
FRC #0971 (Spartan Robotics)
Team Role: Student
IzzieB is an unknown quantity at this point
They're really useful for little things like spacers, lexan, etc.
Unread 05-05-2010, 21:47
jamie_1930's Avatar
jamie_1930 jamie_1930 is offline
FRC #2228 (Cougartech)
Team Role: Student
jamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to behold
In the past two years the only reason we've used pop rivets for is to rivet strips of wegetop to aluminum tube, to make rollers
Team 2228(FRC) - Drive Team Lead, Drive Coach, Mechanical Team
Team 3750(FTC) - Team Lead
2009
Team 2228(FRC) - Mechanical Team, Driver at RIT, and Hartford Regionals, and Drive coach at Ruckus
*Second Place at Ruckus
Team 3750(FTC) - Team Lead, and Drive coach at Clarkson Regional
*Second Place at Clarkson Regional
2008
Team 1930(FRC) - Worked on Mechanical, Electrical, and Programming.
Unread 05-05-2010, 21:48
rahilm's Avatar
rahilm rahilm is offline
AKA: Rahil Mehta
FRC #0668 (The Apes of Wrath)
rahilm has a spectacular aura aboutrahilm has a spectacular aura about
We didn't use rivets much this year, but that was almost our entire hardware for Lunacy. Our robot that year was pretty much just 1/8" and 1/16" stock metals (angle, tube, etc.) and they work really well. Replacing them (which we rarely had to do) was pretty quick and easy.
Team 668 - Apes of Wrath - 2008-2011
Team 668 - Apes of Wrath - 2011-Present (Mentor)
Unread 05-05-2010, 21:49
Dave McLaughlin's Avatar
Dave McLaughlin Dave McLaughlin is offline
Dave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond repute
My old team used them in 2009 for mounting our bumpers and to build a camera mount/Lexan cover support. You can see them here, in the CAD model from that year.
Unread 05-05-2010, 22:08
ihaveamustache ihaveamustache is offline
FRC #0469 (Las Guerrillas)
Team Role: Student
ihaveamustache is on a distinguished road
My team uses rivets almost exclusively on our robot. I can't think of any system on the 'bot in which you wouldn't find a single rivet.
Unread 05-05-2010, 22:37
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
This year we did not have a lot as we used 80-20 which required special fasteners, but in previous years they were used in most of the robot. They are nice because they are light, but use too many of a large size and you might as well use a bolt and they need to be drilled out. Overall they are better than bolts and highly recommend them on most parts unless you want a strong connection that will not break and stay in place under extreme forces.
1058 PVC Pirates 2016 - xxxx
Unread 05-05-2010, 22:41
Jamie Kalb Jamie Kalb is offline
Jamie Kalb is a name known to allJamie Kalb is a name known to allJamie Kalb is a name known to allJamie Kalb is a name known to allJamie Kalb is a name known to allJamie Kalb is a name known to all
What kind of spacer would you secure with a rivet?
Team 3129 Green MacHHHHine Founder, Captain (2009-10), Alumnus, and Mentor (2011-14)
2011-13 VEX World Championship...
Unread 05-05-2010, 22:54
DonRotolo's Avatar
Back to humble
FRC #0832
We use pop rivets of varying sizes everywhere. Only items which must use a bolt (such as an axle) get screw threads, everything else is a rivet.
RIVETS FOR TRACTION WHEELS eshteyn General Forum 4 04-01-2008 16:38
Count the Rivets! Wayne Doenges Championship Event 23 17-04-2007 18:35
nits (rivets) question aviv_levy0 Rules/Strategy 4 07-02-2007 18:12
Soda, Pop, Soda-Pop or Tonic MattK Chit-Chat 33 03-07-2004 01:14
