Re: pic: 6 inch wheel design
Any thoughts on how you would machine that? The angles look a bit tricky, almost like something you would have to mold out of plastic.
the trick with that is getting the orientation correct when you flip it, but it would not be too bad... looks like a fun project for some students on your team to machine! |
You could still machine them, you'd just need to have the z-axis be computer controlled as well.
Not many schools have a 3 axis cnc with all axis computer controlled. maybe he does, but even still the part wouldn't come out like that, there would be a flat spot from where the taper on the spokes trailed off from the machining bit.
As for the exterior wall, it is only 3/16" thick, the extra material on the sidewalls are only 1/8" thick and are there to add side support for the treads to take some wear off of the rivets. Quote:
The smaller triangles and hub weight savings could be done with any end mill that can plunge deep enough to clear out all material left behind by the fillets on the backside of the spokes. Quote:
Thank you all for the comments and question. Keep 'em coming. |
#7
Ok, what high school a ball milling bit? If anyone responds yes I will apply to be a super senior at your school. To me it just seems that it would be easier to design it a bit simpler so in could be made easily inhouse.
anyhow my 2 cents |
#8
I have heard (though never tried) that you can mill on a router table with an all carbide bit. I don't see why something like this wouldn't work here. Obviously a router table won't help, but you can still use the bit.
#11
Ball-end mills are neither expensive nor rare. We have a set.
As for the wheel, I'd probably turn it on a lathe before I brought it to the mill. |
#12
I'd also lathe out as much of the piece as you can initially before milling it out. |
#13
I like the wide tread design, the offset spokes give it a nifty appeal.
Many schools do not have a 3 axis cnc mill. Many teams have at least 1 sponsors who has a 3 axis cnc mill. |
#14
| pic: 4 inch Wheel Render | Chris is me | Extra Discussion | 25 | 15-05-2010 18:43 |
| pic: 4 Inch Wheel Design | MWB | Extra Discussion | 43 | 06-05-2010 19:32 |
| 4 inch Wheel of Doom | R.C. | SolidWorks | 25 | 26-11-2008 23:57 |
| pic: 5 Inch Wheel | RMS11 | Extra Discussion | 24 | 18-08-2008 23:55 |
| 12 Inch Wheel Available in Several Formats | Ed Sparks | Inventor | 1 | 19-01-2004 07:12 |
