Go to Post “Hey, why are those numbers showing, it must be a game hint!” Listen, please – it’s not a game hint. Our game hints typically start with something like “This is a game hint!” - Frank - pwnageNick [more]
Unread 05-05-2010, 23:06
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Electrical Connectors
Al, I think he's referring to the small powerpoles, designed to use the roll pin to hold them together. An assembled black/red pair can be zip tied together, but what keeps red and black next to each other?
We don't use super glue, instead some far weaker glue, just enough to gum up the dovetail so it doesn't come apart easily.
Woe to the team that uses the metal roll pins: They WILL come out and short power to ground, these should never be used.
Pneumatics Connectors abross Pneumatics 4 24-01-2010 23:31
Anderson Connectors!!!! cdennisxlx2 Electrical 9 06-03-2006 19:20
Connectors. ForgottenSalad Electrical 4 12-02-2006 13:35
Slip connectors (custom electrical connectors) Damian Manda Electrical 2 08-02-2003 17:53
RJ-45 connectors, DB25 connectors and the like: legal or no? Andrew Wyatt Technical Discussion 6 04-01-2002 22:53
