Go to Post If this photo doesn't tell us why a photographer is important to a team, I don't know what will. - JaneYoung [more]
  #46   Spotlight this post!
Unread 02-05-2010, 10:30
Josh Fox Josh Fox is offline
Detroiter
AKA: Foxy
FRC #0027 (Team RUSH)
Josh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud of
Re: The spread of pinching rollers this year
Originally Posted by ExTexan View Post
I'm guilty as charged for calling a fair amount of carrying penalties, but like all my calls, I call 'em as I see 'em and try to be consistent. As all the refs do I believe.
I agree with Ike, thanks for keeping us honest!
Team RUSH Alumnus and Mentor, Mechanical Engineer
  #47   Spotlight this post!
Unread 05-05-2010, 15:27
FoleyEngineer's Avatar
FoleyEngineer FoleyEngineer is offline
AKA: John Crombe
FRC #0910 (Foley Freeze)
FoleyEngineer has a reputation beyond reputeFoleyEngineer has a reputation beyond reputeFoleyEngineer has a reputation beyond reputeFoleyEngineer has a reputation beyond reputeFoleyEngineer has a reputation beyond reputeFoleyEngineer has a reputation beyond reputeFoleyEngineer has a reputation beyond reputeFoleyEngineer has a reputation beyond reputeFoleyEngineer has a reputation beyond reputeFoleyEngineer has a reputation beyond reputeFoleyEngineer has a reputation beyond repute
Originally Posted by IKE View Post
You are missing 910. They had my favorite as they had the highest surface speed on the top roller of any of the teams I talked to. This allowed them to acquire the ball at a run while most of us had to take it at a walk. In general, on a collector, a top roller that engages a ball to the floor should have a surface speed equal to or greater than 2x the robot traveling speed. Our original top-spin roller was a 10 FPS surface speed which corresponded with our 5 FPS low gear. Our pincher was somewhere between 1-2 FPS SS. I think 910 managed a system with around 8 FPS SS on their roller.
Hi Ike,
Actually, our roller runs at over 20 ft/sec so that when we're driving full bore at 10 FPS we can grab a ball on the fly with no "bounce-back". If we reverse it at that speed it actually is quite a nice kicker! In fact, our autonomous simply does that - reverses the roller to full speed, we drive about 2 feet into the ball in front of us and it spins the ball up to a high enough speed to run it right up the ramp into the goal!
John
2014 Buckeye Champions - thanks 846 & 639, Troy Champions - thanks 33 & 5193, Imagery, Entrepreneurship & Industrial Design Awards
2013 Kettering Champions - thanks 70 & 862, Three Imagery Awards
2012 Western Mich Finalist - thanks 1918 & 85
2011 Trav. City Web Site, Troy Xerox, Mich State Semi Finalist & Judges Awards
2010 Kettering Champion - thanks 67 & 70, Kettering Rockwell Innovation 2010 Troy Finalists - thanks 33 & 288, and Rockwell Innovation
2009 Kettering QF, Detroit Finalists Detroit Creativity Award, Troy Semi-Finalists Troy Creativity Award
2008 WMRI Finalists - thanks 1243 and 904, 2008 Kettering Champion - thanks 67, 1075 and 2619
2008 IRI Judges Award Winner, Great Lakes Finalists - thanks 66 & 217, Western Mich
2007 Curie Division Champions - thanks 330 & 1270
  #48   Spotlight this post!
Unread 05-05-2010, 20:50
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
Originally Posted by FoleyEngineer View Post
Hi Ike,
Actually, our roller runs at over 20 ft/sec so that when we're driving full bore at 10 FPS we can grab a ball on the fly with no "bounce-back". ...
John
Wow, an that is why it was my favorite collector this year.
  #49   Spotlight this post!
Unread 06-05-2010, 07:50
Jared Russell's Avatar
Taking a year (mostly) off
Can somebody explain the physics behind the "intake must run at >=2x robot speed" assertion? I've heard this before, and even designed with it in mind, but only now do I stop to think about it.
Intuitively, I don't see why running at >1x robot speed wouldn't work?
  #50   Spotlight this post!
Unread 06-05-2010, 08:09
I'm guessing it may have come from the fact that the tangential velocity, with respect to the ground, of the top of a wheel, is twice the velocity of the vehicle to which it is connected.
So the reasoning goes: the roller must turn at 2x robot speed in order to keep the ball from escaping when backing up.
But that reasoning is flawed. The tangential velocity of the top of the wheel with respect to the robot is the same as the velocity of the robot.
There may be other reasons for the 2x number.
  #51   Spotlight this post!
Unread 06-05-2010, 08:28
IKE's Avatar
IKE IKE is offline
AKA: Isaac Rife
no team (N/A)
If you draw a ball and imagine it rolling at 1 m/s. At any moment in time, the bottom of the ball is stationary (in contact with the ground). The middle of the ball is traveling at 1 m/s. This means the top of the ball is at 2 m/s.
With a collector that touches the ball, it is the same. If the collector has the same surface speed as the robot is traveling, it will want to puch the ball forward as it draws it in. If the surfaces speed is 2x or greater, it will draw the ball into the robot. This is best seen with the backspin collectors when they are backing up. If the surface speed is 2 m/s, the robot will loose contact when its back-up speed is greater than 1 m/s. The ball still has some momentum and will continue towards the bot if the bot stops.
Normally the collectors suck the balls into some sort of feeder system. This year, there is a 3" intrusion rule. High speed collectors impart a lot of energy into the ball. This energy can cause a bounce when the ball hits its backstop. Some teams fixed this by moving from a top-spin to a lower point along the side of the ball. This reduced the rearward momentum, but induced higher normal forces between the ball and the carpet. This meant that you needed more power to keep the ball backspinning. The solutions for that were either a clutching mechanism (so that the ball did not backspin of which 1918 was extremely creative), more powerful motor, or larger ratio which meant slower surface speed. The topspin systems often used some sort of cushioned backstop to absorb the extra kinetic energy, or would have a cushioned roller mount (our original topspin, backspin system) with a lower idler roller.
With the high surface speed that 910 has, I imagine the had lots of testing with the ball rebounding out of the machine. It looks like they found a very interesting solution of compliant yet slick material. Again why that was my favorite collector this year.
If you need some diagrams, I can throw together another Powerpoint. I have a few decks of slides from our collector studies. I would have posted it up, but felt kind of silly saying, "Yeah, we did all this engineering to get this one design which was sort of OK, but then went with a design we ruled out in week 2 because we saw it was better in a video".
  #52   Spotlight this post!
Unread 06-05-2010, 12:44
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
I'm curious to hear who had the design idea initially, and who added it later, and if so, who did they copy/get inspiration from?
Carnegie Melon. Your design sounds like something that Carnegie Melon developed for the Robocup.
This is the year... Rich Kressly General Forum 45 01-01-2014 02:01
Am I the only one who LOVED the seeding system this year? Chris is me General Forum 95 23-04-2010 15:33
Is this the only "Flop-bot" this year? David Brinza Technical Discussion 15 13-04-2008 14:45
This year at the Nationals archiver 2000 1 23-06-2002 22:23
Anyone dislike the way the comp this year is scored? Greg Perkins Regional Competitions 11 08-04-2002 19:30
