Help with PSoC board programming please
can any one please show me how to program a PSoC board with a switch
or give me a sample code?? Quote:
Re: Help with PSoC board programming please
http://www.virtualroadside.com/WPILi...r_station.html
I have linked the relevant API documents. You can use DriverStation::GetDigitalIn([number]) to get the value of the switch. And PLEASE try to take a little more time writing your posts in the future. |
The GetDigitalIn would be somewhere in your Teleop loop (before you need the data of course)
what data?
The value of the switch...
#7
how do you make the PSoC board communicate with the driver station, i plugged it in but the driver station says:
Did you follow the steps in section 2.11 of the control system manual for configuring the I/O module?
#9
(sorry for so much questions, but im just learning) Last edited by krudeboy51 : 05-05-2010 at 16:33. |
#10
Does the I/O light turn green in the Diagnostcs window?
Make sure you have the latest update to the DS software (1.2 I believe). You may need to uninstall and reinstall the Cypress software through the updater |
#11
yes, it turns green now on the driver station, but im wondering, do i have to introduce it to the code in class and public, or just go ahead in teleoperated and put "DriverStation::GetDigitalIn"??
#12
To use the DriverStation functions, you have to create a DriverStation pointer and set it with DriverStation::GetInstance(). You can then use GetDigitalIn only on the first 8 pins. The DS must also be set to Compatible I/O mode (through I/O screen). If you want to use any of the advanced functionality available through the PSoC board, the system is a bit different (will show with code)
Using DriverStation Code:
public:
DriverStation *ds;
MyRobot() {
ds = DriverStation::GetInstance()
Teleop() {
switch = ds->GetDigitalIn(1);
Teleop() {
DriverStationEnhancedIO& dsio = DriverStation::GetInstance()->GetEnhancedIO();
switch = dsio.GetDigital(1);
#13
for the first one, would the operator code look like this:
void operator control
switch (ds->GetDigitalIn(1));
motor->Set(0.0);
Wait(1.0);
motor->Set(0.0);
and i tried the enhanced io but it gives me a warning that "dsio" is a unused varible Last edited by krudeboy51 : 06-05-2010 at 17:30. |
#14
switch is a bool variable. Did you declare it? dsio being unused is an effect of the = error because the compiler doesn't recognize that line as valid, so no go on using it.
Also, the logic on your version is bad. My version was writing the value of the digital in to a variable. Yours is using that value in a switch statement, which is used when you have different values to run between (a fancy if statement pretty much). Additionally, you are ending the switch without any code because of the ; at the end of the line. You then go onto write a block of code that will execute on every loop. Plus you throw a wait in there. not good. It will compile, but most likely will not run. This is what I think you want: Code:
void OperatorControl() {
DriverStationEnhancedIO &dsio = DriverStation::GetInstance()->GetEnhancedIO();
// moar code
if (dsio.GetDigital(1)) {
motor->Set(1.0);
Wait(1.0);
motor->Set(0.0);
If you absolutely need the 1 second run of the motor, I suggest you export the code for this to another task and communicate via a class variable |
#15
Remember that switch is a reserved word in C++. Don't try to use it for a variable name.
| Help with PSoC board wiring please | krudeboy51 | Electrical | 1 | 04-05-2010 16:17 |
| Attaching Psoc Board to breadboard | nickcvet89 | FRC Control System | 2 | 10-03-2010 12:27 |
| Windows "Malfunctioning USB Device" error with Psoc IO Board | WarrenPW | FRC Control System | 2 | 11-02-2010 18:53 |
| Wiring Switches to the PSoC board | Raj1977 | Electrical | 13 | 07-02-2010 23:24 |
| Help with programming new controllers, please. | Oumonkey | Programming | 6 | 30-11-2006 21:53 |
