Go to Post If a suspicious distrustful atmosphere is created, then a suspicious distrustful reaction will occur. - JaneYoung [more]
  #46   Spotlight this post!
Unread 06-05-2010, 19:17
rogerlsmith's Avatar
rogerlsmith rogerlsmith is offline
Software Engineer
AKA: Roger Smith
FRC #3357 (COMETS)
rogerlsmith is a splendid one to beholdrogerlsmith is a splendid one to beholdrogerlsmith is a splendid one to beholdrogerlsmith is a splendid one to beholdrogerlsmith is a splendid one to beholdrogerlsmith is a splendid one to beholdrogerlsmith is a splendid one to behold
Re: Statistics on top 20 teams?
Back when this thread was started, I wasn't sure if you guys would consider 3357 a "top 20" team. We were picked by the #1 alliance of Teams 254 and 233 on Archimedes. With the help of these awesome teams, we won our division.
At any rate, I thought I'd share our statistics.
Programming:
  • We programmed in Java
  • Our code was fully threaded
  • Our autonomous blindly drove and kicked, however we had camera code that aimed. Didn't use it.
  • No problems that I know of with WPILib
  • We did download the WPILib source, didn't compile it.
  • PWM control
  • Did not use the classmate for development.
Robot Design:
  • We used the gyro and camera
  • The vision system was set up to be used both in auton & teleop. We never used it in either case.
  • In the vision system code we tweaked the PID values. It seemed to work best with the defaults.
  • Drive system was direct drive, tank control.
  • 4 Wheels, front 2 AM Plaction, rear 2 slippery plastic from KOP.
  • 4 CIM motors, 1 direct drive on each wheel.
  • Material was standard KOP C-channel
  • Ball control via pinch roller made from pool noodle.
  • Energy storage for kicker - pneumatically charged elastic.
  • We cut parts with hand tools, and some were machined via CNC mill
  • We did not hang.
The Driver Station
  • We used the standard dashboard and a modified version (not programmed by us)
  • We used an X-Box controller for drive, joystick for all kicking and pneumatics operations.
  • USB seemed to work okay.
I did not feel the classmate was fast enough, and may have caused several communication problems on field.
Roger Smith
Mentor - FRC Team 3357
COMETS - Creating Outstanding Minds, Embracing Technology & Science
Share FIRST videos, photos and experiences at FIRSTObjective.org
  #47   Spotlight this post!
Unread 06-05-2010, 19:54
Pat Fairbank's Avatar
Pat Fairbank Pat Fairbank is offline
Circuit Breaker
Pat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond repute
Send a message via MSN to Pat Fairbank
I'm not qualified to answer any of the detailed questions on their behalf, but I can share that 1114 used Java this year, and their programmers told me they were happy with it and would use it again.
Patrick Fairbank
Team 254 | Mentor (2012-)
Team 1503 | Mentor (2007-2011)
Team 296 | Alumnus (2001-2004) | Mentor (2005-2006)
patfairbank.com
its official!!!! Michigan Top 64 teams anounced! list up! roboraven15 District Events 16 30-03-2009 14:22
The top 8 teams will be....(2005) Stephen Kowski General Forum 32 12-04-2005 19:26
[OCCRA]: Top Ranking Teams Picking Alliances Lisa Perez OCCRA Q&A 1 15-11-2004 20:31
The top 8 teams will be....(2004) Jessica Boucher General Forum 20 24-03-2004 22:31
Who are your top ten teams? archiver 1999 1 23-06-2002 22:41
