Re: Dashboard .ini file from Classmate PC
IThe DS should load fine without it, substituting factory defaults for any missing info. Can you elaborate on why you needed a copy?
Greg McKaskle |
| Question about updating "ni-rt.ini" file to use NetConsole | Randy Forgaard | General Forum | 2 | 25-02-2010 01:54 |
| dashboard problem on classmate | Jakerman3 | Programming | 3 | 03-02-2010 19:00 |
| Classmate Question: Default Path Location for Driver Dashboard | Ziaholic | FRC Control System | 4 | 25-01-2010 13:56 |
| Dashboard not appearing on classmate | railerobotics | Programming | 2 | 20-01-2010 15:42 |
| Dashboard .ini file, configuration | bayesianlogic | Technical Discussion | 1 | 20-01-2007 17:44 |
