Go to Post "Its not a glitch its a new feature, we just dont know how to use it yet" - Cuog [more]
Unread 05-05-2010, 22:54
A_Reed's Avatar
A_Reed A_Reed is offline
Lead Design Mentor
AKA: Adam Reed
FRC #0048 (Delphi E.L.I.T.E)
A_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to behold
pic: 6 inch wheel design
Unread 05-05-2010, 22:55
Edoc'sil's Avatar
Edoc'sil Edoc'sil is offline
FRC #2531
Edoc'sil has a spectacular aura aboutEdoc'sil has a spectacular aura about
Re: pic: 6 inch wheel design
Any thoughts on how you would machine that? The angles look a bit tricky, almost like something you would have to mold out of plastic.
Here lies a toppled god-
His fall was not a small one.
We did but build his pedestal,
A narrow and a tall one.
Unread 05-05-2010, 23:00
548swimmer's Avatar
548swimmer 548swimmer is offline
CAD Leader
AKA: Alec Wagner
FRC #0548 (Robostangs)
Team Role: CAD
548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of
1.3 pounds seems a little heavy. I designed some simple 6inchers without any sprocket mounts that weighed in at around .65 pounds. Also, your exterior wall looks a little thick, how thick is it?
Unread 05-05-2010, 23:13
M. Mellott's Avatar
M. Mellott M. Mellott is offline
CAD God
AKA: Mike Mellott
FRC #3193 (Falco Tech), FRC #48 (Delphi E.L.I.T.E.), FTC #9980 (FMF)
M. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud of
Looks like you could machine the front face of the 3 closest "spokes" and the back side of the other three in one pass. Flip it over and repeat the process.
The outer wall looks like it's recessed for the tread. Does your weight include the tread material, or is it just the wheel?
I like the wider tread. Very nice, Adam!
In the continuing battle between innovative engineering and the laws of physics...physics always wins.
Unread 05-05-2010, 23:22
548swimmer's Avatar
CAD Leader
AKA: Alec Wagner
Team Role: CAD
Just the wheel, but since it's just for a prototype CAD I extruded where the tread would be, so it should be about the same weight.
Unread 05-05-2010, 23:23
Jamie Kalb Jamie Kalb is offline
Jamie Kalb is a name known to allJamie Kalb is a name known to allJamie Kalb is a name known to allJamie Kalb is a name known to allJamie Kalb is a name known to allJamie Kalb is a name known to all
Pretty neat.
For the "free" wheel, if the hub is wider than the rim, you can attach a flat sprocket directly to the (nicely integrated) bolt pattern on the wheel without an extra spacer. I can't tell from the picture if it's already like that.
Team 3129 Green MacHHHHine Founder, Captain (2009-10), Alumnus, and Mentor (2011-14)
2011-13 VEX World Championship...
Unread 06-05-2010, 08:39
Borisdamole Borisdamole is offline
mercernary machinist
AKA: Taylor
FRC #0973 (most with 973)
Borisdamole is just really niceBorisdamole is just really niceBorisdamole is just really niceBorisdamole is just really niceBorisdamole is just really nice
Send a message via AIM to Borisdamole
no way.... it would be machinable, you would just have to do 2 milling operations.... it would require flipping the wheel over to machine the back half.....
the trick with that is getting the orientation correct when you flip it, but it would not be too bad...
looks like a fun project for some students on your team to machine!
OUTWORK US
Unread 06-05-2010, 10:23
Edoc'sil's Avatar
FRC #2531
It doesn't look like the spokes are flat, but it may just be distortion from the render.
Unread 06-05-2010, 10:52
548swimmer's Avatar
CAD Leader
AKA: Alec Wagner
Team Role: CAD
You could still machine them, you'd just need to have the z-axis be computer controlled as well.
Unread 06-05-2010, 12:20
Edoc'sil's Avatar
FRC #2531
Not many schools have a 3 axis cnc with all axis computer controlled. maybe he does, but even still the part wouldn't come out like that, there would be a flat spot from where the taper on the spokes trailed off from the machining bit.
Unread 06-05-2010, 14:32
A_Reed's Avatar
Lead Design Mentor
AKA: Adam Reed
1.3 lbs may seem a bit heavy, but with no realistic numbers to run through the ANSYS FEA I have designed it to be overly robust with a 'standard' .25x.25 square cross section for each spoke. Anyone want to help me out on getting some realistic benchmarks for moment loading, side loads and radial loads.
As for the exterior wall, it is only 3/16" thick, the extra material on the sidewalls are only 1/8" thick and are there to add side support for the treads to take some wear off of the rivets.
The machining process on the major spokes would use a Ball-Nose end mill for all of the major cuts. The first cut(s) would be a 1/4" deep pocket that creates the fillets to the outer wall and to the hub, the front face of the spokes would be flat as the material is taken out between the two fillets. The second series of cuts would use the same mill stopping at the backside of the rear spokes creating the same fillets. As the wheel is flipped and the machining process is repeated the square edges of the spokes and the fillets would be defined on the backside of the front spokes.
The smaller triangles and hub weight savings could be done with any end mill that can plunge deep enough to clear out all material left behind by the fillets on the backside of the spokes.
Originally Posted by Jamie Kalb View Post
Pretty neat.
No the hub is planar with the rest of the wheel on both sides currently. I will take that into consideration as a way to avoid adding extra spacers.
Thank you all for the comments and question. Keep 'em coming.
Unread 06-05-2010, 19:13
Edoc'sil's Avatar
FRC #2531
Ok, what high school a ball milling bit? If anyone responds yes I will apply to be a super senior at your school. To me it just seems that it would be easier to design it a bit simpler so in could be made easily inhouse.
anyhow my 2 cents
Unread 06-05-2010, 20:52
A_Reed's Avatar
Lead Design Mentor
AKA: Adam Reed
anyhow my 2 cents
You don't need a high end bit to cut aluminum, with the proper feed speeds and such you could use a 'cheap' bit to do the job
Unread 06-05-2010, 21:30
Dan Richardson's Avatar
Dan Richardson Dan Richardson is offline
iR3 Creative
AKA: Dan Richardson
Dan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond repute
I like the wide tread design, the offset spokes give it a nifty appeal.
anyhow my 2 cents
Many schools do not have a 3 axis cnc mill. Many teams have at least 1 sponsors who has a 3 axis cnc mill.
CO-Founder of Robot in 3 Days and the Robot in 3 Day Challenge.
Unread 06-05-2010, 22:51
548swimmer's Avatar
CAD Leader
AKA: Alec Wagner
Team Role: CAD
It may not be the most accurate method, but I just place a fixed constraint on the hole for the shaft and apply 300lbf to the rim.
pic: 4 inch Wheel Render Chris is me Extra Discussion 25 15-05-2010 18:43
pic: 4 Inch Wheel Design MWB Extra Discussion 43 06-05-2010 19:32
4 inch Wheel of Doom R.C. SolidWorks 25 26-11-2008 23:57
pic: 5 Inch Wheel RMS11 Extra Discussion 24 18-08-2008 23:55
12 Inch Wheel Available in Several Formats Ed Sparks Inventor 1 19-01-2004 07:12
