Go to Post The spirit of FIRST is about learning not just about winning. - MamaSpoldi [more]
Unread 07-05-2010, 17:21
548swimmer's Avatar
548swimmer 548swimmer is offline
CAD Leader
AKA: Alec Wagner
FRC #0548 (Robostangs)
Team Role: CAD
548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of
pic: Prototype Drivetrain
Unread 07-05-2010, 17:44
Hawiian Cadder's Avatar
AKA: Isaak
FRC #0159 (Alpine Robotics)
Team Role: CAD
Re: pic: Prototype Drivetrain
looks good, however you will probably want a couple more sideways bracing to attach things to
Unread 07-05-2010, 18:08
Chris is me's Avatar
AKA: Pinecone
Why the tiny, centered wheelbase?
Unread 07-05-2010, 18:13
RMS11's Avatar
RMS11 RMS11 is offline
Safety!!!!
AKA: Rick
FRC #2415 (WiredCats)
Team Role: Driver
RMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to behold
Send a message via AIM to RMS11
The wider it is the easier it will be to turn, I believe.
2009 Peachtree Regional Champs
2009 Palmetto Regional Champs
2008 Peachtree Rookie All Star and Rookie Highest Seed
Unread 07-05-2010, 18:29
ttldomination's Avatar
Sunny
I do believe that is correct. Someone with a more sound physics base please feel free to correct me, but it all has to do with torque.
On a wide base, when the center of rotation is assumed to be between the wheels, the wheels turn on a larger radius than in this CAD. Therefore, the large radius gives the driving wheels more torque.
Although I can understand the concept. I do believe that with this kind of drive, you'd be able to turn quicker, but I think that with a 120-pound robot, you're not going to get the performance with a basic 6WD.
- Sunny
1648: 2013-2014
5283: 2015
Unread 07-05-2010, 18:31
548swimmer's Avatar
CAD Leader
AKA: Alec Wagner
Team Role: CAD
Over the summer, team 548 is planning to come up with a plethora of designs to prepare our CAD team for kickoff. Also, we will be creating a binder of "crazy ideas" to reference once we get the challenge. Anything we can come up with now will help give us a jumping off point for our final design. This drivetrain is designed for maneuverability.
This wheelbase will allow our robot to not only have a zero turn radius, but also turn much more quickly than wheels on the outside, due to the smaller arc length traveled for the same change in angle. I am anticipating extreme difficulty in the driving of this machine. If the game requires maneuverability, we'll be in great shape though.
Unread 07-05-2010, 18:35
548swimmer's Avatar
CAD Leader
AKA: Alec Wagner
Team Role: CAD
- Sunny
A wider wheelbase does give it more torque due to the increased radius. This will not be needed to turn though, because with 2 cims powering 1 wheel, we will have unlimited power (not actually, but for FIRST applications). Also, because there are omni's in the front and rear, there will be a negligible force of friction counteracting the torque.
Unread 07-05-2010, 19:00
DonRotolo's Avatar
Back to humble
FRC #0832
...until the wheel slips, at least.
Because of the moment of inertia of a relatively heavy mass swinging around a central axis with little friction (those omnis) you will find such a design difficult to control - even with a wider wheelbase.
Commenting on the sheet metal: Cut the thickness by 30% and put a 1" flange (bent inwards for both) at the top & bottom. Saves weight, adds significant rigidity. Some of the flange can be lost or reduced by the omni wheels for clearance if necessary.
To keep the assembly from racking (parallelogram), consider very thin braces from outside corners, in an X pattern. Even 1/8" wire rope would be fine, since it is in tension.
Your hole pattern could be improved. The solid pieces should all meet at stress points, not tangentially to them. See the small round 'pin' in front, 1/4 way from the left side of the image.
Nice CAD work.
Unread 07-05-2010, 19:08
Sunny
For some reason I can't figure out how to delete this post, but Don Rotolo pretty much summed it up.
1648: 2013-2014
5283: 2015
Unread 07-05-2010, 19:11
548swimmer's Avatar
CAD Leader
AKA: Alec Wagner
Team Role: CAD
Nice CAD work.
I am expecting this to be hard to control, and thats why I pulled the wheels toward the center. I figured it'd be spinning out of control untill you got the hang of it, so I should just design it for experienced drivers (hence the fast turn speed).
As for the metal, putting such a large flange on both pieces will leave a 1/2 inch gap between the side plates (only 2.5 inch spacing). I thought about just downgauging and flanging one piece (outside), but wanted to leave it simple for the first prototype CAD.
Supports: We have always been fine without any angle braces since the tubes go through a square hole in the inside plate. Would just a simple angle bracket suffice?
Lightening
Does it really matter since the piece will never be under tension/compression in the direction that the lightening will help?
As far as the CAD goes, I enjoy it, so I've gotten really good with basically teaching myself.
Unread 07-05-2010, 19:35
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
That makes it theoretically worse.
Because the diameter of the circle between the wheels is smaller, it takes less imbalance to cause it to stray to one direction.
We had a 6 wheel drive in 2008 that was flat, with 4 corner omnis and 2 center plaction wheels. It was too hard to keep it driving straight, for a second year driver, so we replaced the outer rear wheel with a kit wheel to add a little more friction sideways.
If it doesn't veer that much, you can probably fix it in software using a gyro. It has to be somewhat controllable for the software to work.
Kettering Motorsports
Unread 07-05-2010, 20:11
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Nice CAD model, but physics says this design will not work too well. Also, it looks like your design is based around BaneBots gearboxes, which I would recommend against. You may consider placing those center wheels closer to the outside of the vehicle, and powering the omni wheels as well.
Unread 07-05-2010, 21:33
Pull the wheels out to the edges. Even if you didn't realize the physics behind this, just think "if it was an advantage to pull the wheels closer together, more teams would be doing it by now." Common sense goes a long way. Also I hope you plan to drive those Omni wheels.
Other than that I can't say much since I'm not one to judge about lightening patterns and structural integrity of sheetmetal parts just yet.
Unread 07-05-2010, 23:19
LLogan LLogan is offline
Head Screw Tightener/Cheerleader
AKA: Logan
FRC #1261 (Robolions)
LLogan has a spectacular aura aboutLLogan has a spectacular aura about
I would advise you to drive the four omnis on the corners. Your tractive force is based off of the sum of the forces of friction on all of your wheels. With the design you have right now, you are essentially "wasting" the normal force on the corner wheels. Whatever weight you will have on those sections of the robot will not contribute to your pushing force, giving you less than what you would generally want.
Unread 07-05-2010, 23:23
548swimmer's Avatar
CAD Leader
AKA: Alec Wagner
Team Role: CAD
You must not have understood what I meant. With this drivetrain design and current wheel placement, it will never be terribly easy to control. With this in mind, I figured it would not make it too much worse to pull the wheels in. We also would be able to use a gyro to help keep it straight (we used one for autonomous this year).
As for the banebots, we used them this year and never had any issues. In the past we have used toughboxes, and they kept breaking. I'm not sure exactly how, but I was told not to use them, and I'm fine with that.
I have no intention of powering the omni's because with this design, there is no good way to get power out to them, short of flipping where the wheels are, which would defeat the purpose of this drive.
Team 241's Turret Prototype ontop of the Harvester Prototype Dantvman27 Robot Showcase 39 08-02-2009 22:53
pic: 499 Prototype drivetrain final layout Andrew Schuetze Extra Discussion 9 01-01-2008 21:37
pic: A drivetrain prototype idea GMAdan Extra Discussion 16 24-04-2007 16:14
1541 Prototype Drivetrain bombadier337 Technical Discussion 12 23-01-2006 08:26
Image Discuss: Team 773 Drivetrain Prototype CD47-Bot Extra Discussion 5 27-01-2003 18:46
