Go to Post I think the GDC just saw Inception. - ATannahill [more]
Unread 08-05-2010, 10:02
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
Re: Returning bad digital sidecar
Originally Posted by Chris Fultz View Post
We had multiple sidecar failures, and determined they were due to metal chips and shavings getting into the unit.
At first we thought it was from drilling, even though we cover the electronics. But after a few failures and replacements, we determined at least part of the problem was that our wheels were picking up material from the playing field and it was ending up in the sidecars.
Short term fix - we added "mud flaps" behind the wheels to keep debris from getting into the electronics.
Long term fix - we will not mount the sidecars so low in the frame or in areas susceptable to field debris.
That was one of the main causes of our issues as well. Mounting the sidecar at the very bottom of the frame didn't work out well.
Thank-you 294 & 67
www.bobcatrobotics.org
Wiring Digital Sidecar rsegrest Electrical 7 25-01-2010 11:25
Digital Sidecar problem Booksy FRC Control System 6 14-06-2009 05:31
Digital Sidecar problem Jon Stratis Electrical 4 27-02-2009 09:12
No RSL on Digital Sidecar shobuda999 FRC Control System 16 08-02-2009 14:28
Digital Sidecar Resistor NinJA999 Electrical 5 30-01-2009 19:53
