Go to Post Even as a "mentor", I am still being mentored by engineers who work with the team. - Tom Bottiglieri [more]
Unread 08-05-2010, 03:05
Chief Pride's Avatar
Chief Pride Chief Pride is offline
<3
AKA: James Kiefer
Chief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond repute
Non-Circular Gears
http://www.wimp.com/planetarygear/
Wow... Does anyone have any kind of idea as to what this type of gear could be used for?
Unread 08-05-2010, 07:27
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
Re: Non-Circular Gears
They are sometimes used as a function generator. For instance, if you used a particular geometry, you can input a constant speed, and the output it s sine wave.
Unread 08-05-2010, 12:22
glennzo glennzo is offline
AKA: Glenn
FRC #0086 (Team Resistance)
glennzo is an unknown quantity at this point
http://en.wikipedia.org/wiki/Non-circular_gear
It looks like most applications involve pumping fluids.
Non-circular gears (super oval flowmeter)
One web site mentioned high performance bicycles.
clear skies
Unread 08-05-2010, 17:32
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
They basically act as cams, but instead of having a variable, linear motion output, they have a variable, rotary motion output, So they could be used for a lot of things such as rotary kickers that speed up when the flipper is near the ground or to move an arm (the closer to horizontal it is the harder it is to turn, thus, a variable gear ratio that has a higher reduction when the arm is horizontal than when it is vertical is ideal)
Unread 08-05-2010, 19:12
Spirograph!
Unread 08-05-2010, 19:33
kgzak's Avatar
kgzak kgzak is offline
AKA: Kris
FRC #4392 (Decievers) FRC #2075 (Enigma)
kgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to behold
My dad said the one was the same principle of the Wankel Engine
http://en.wikipedia.org/wiki/Wankel_engine
Unread 09-05-2010, 02:12
KarenH's Avatar
KarenH KarenH is offline
Mrs. ChrisH
FRC #0330 (Beach 'Bots)
Team Role: Parent
KarenH has a reputation beyond reputeKarenH has a reputation beyond reputeKarenH has a reputation beyond reputeKarenH has a reputation beyond reputeKarenH has a reputation beyond reputeKarenH has a reputation beyond reputeKarenH has a reputation beyond reputeKarenH has a reputation beyond reputeKarenH has a reputation beyond reputeKarenH has a reputation beyond reputeKarenH has a reputation beyond repute
They are kinetic art.
Karen Husmann
Ex Robo-widow
Non-Classmate DS Problems ayeckley FRC Control System 12 09-02-2010 08:25
Joysticks with circular motion Tom Line Electrical 28 04-03-2009 20:07
Rules concerning manipulating circular diamond plate on a spider leg for stability Drew Rules/Strategy 3 09-01-2007 14:51
Help - G-Code Circular Motion for CNC Milling sanddrag Technical Discussion 15 18-08-2004 23:00
