Go to Post Then there's the electronics, pneumatics, and all that stuff on top that will magically make the ball score billions of points. That will add up to a lot of weight. - MrForbes [more]
Unread 08-05-2010, 20:41
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
Set Jaguar device number via cRIO
EDIT: I've reposted this in the CAN forum here. Please delete this thread.
So I finally got the time to try out CAN. However, I can't seem to address my black Jaguar.
Here's the setup:
1 black jaguar, connected to cRIO via serial
1 120 ohm resistor between CAN_H and CAN_L
Here's the code I'm using:
The enumeration command returns one element with a value of 0. If I interrupt the CAN or serial communication in any way (unplugging a cable, removing the termination resistor, or removing power to the jaguar), it returns an empty array.
There's a couple documents saying that the default device number for a Jaguar is 1. Sounds like my results are a little strange.
Pressing the "user button" on the Jaguar doesn't have any effect on the return of the enumeration command.
Is there anything I'm doing wrong?
-- Marshal Horn
Routing Camera output via the cRIO taichichuan C/C++ 4 28-03-2016 11:13
Set computer to receive it's IP via DHCP? grosh FRC Control System 21 28-05-2010 16:33
CAN Jaguar code set up as a VxWorks Library taichichuan CAN 0 21-02-2010 22:16
Unable to set team number Erebos FRC Control System 4 27-01-2009 17:00
Can not set team number on DS TekClaz FRC Control System 2 23-12-2008 14:25
