Go to Post I am used to politicians getting up and being blowhards. - Steve W [more]
Unread 08-05-2010, 23:51
548swimmer's Avatar
548swimmer 548swimmer is offline
CAD Leader
AKA: Alec Wagner
FRC #0548 (Robostangs)
Team Role: CAD
548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of
pic: Prototype Drivetrain v2
Unread 08-05-2010, 23:54
Dave McLaughlin's Avatar
Dave McLaughlin Dave McLaughlin is offline
Dave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond repute
Re: pic: Prototype Drivetrain v2
I would recommend powering all of the wheels that will be in contact with the ground, including the Omni wheels. In addition to that, are you planning on using the custom traction wheels shown in this model? If so, do the spokes require 3D contouring?
Unread 08-05-2010, 23:58
548swimmer's Avatar
CAD Leader
AKA: Alec Wagner
Team Role: CAD
I'm not sure how to power the omni's when they're in a suspension. We may use the custom wheels, the spokes are flat, no fillet's into the rim.
Unread 09-05-2010, 01:03
Eugene Fang's Avatar
Eugene Fang Eugene Fang is offline
The Blue Alliance
Eugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond repute
What, may I ask, is the point of the suspension?
Eugene Fang
2010 Silicon Valley Regional Dean's List Finalist
Various FLL Teams - Student (2000-2006), Mentor (2007-2010)
FRC Team 604 - Student (2007-2010), Mentor/Remote Advisor (2011-2015)
FRC Team 1323 - Mentor/Remote Advisor (2011-2014)
The Blue Alliance | TBA GameDay | TBA Android App
Unread 09-05-2010, 01:21
kgzak's Avatar
kgzak kgzak is offline
AKA: Kris
FRC #4392 (Decievers) FRC #2075 (Enigma)
kgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to behold
could you possibly design a suspension that could keep a chain tensioned? Possible have it move around a point that would have the chain stay tensioned as it goes up and down?
Or could you have a chain tensioner that keeps a chain tensioned by use of springs and have the springs that hold the chain tensioned be easier to compress/expand than the spring or whatever you are using to make the wheels have suspension.
I am trying to design a suspension for our robot next year but the wheels would be powered in one way or another I don't see a point in having a suspension if you are not going to power the wheels. What is the reason behind having a suspension on unpowered wheels?
Unread 09-05-2010, 01:30
gyaniv's Avatar
gyaniv gyaniv is offline
AKA: Gutman Yaniv
FRC #2230 (General Angels)
gyaniv has a spectacular aura aboutgyaniv has a spectacular aura about
Why exactly do you need suspension?
Wouldn't it be much easier to lower the center wheels by about 1/8" and power the other wheels with chain? or just going flat 6WD?
FRC Team 2230 - Student - 2009-2011
FRC Team 2230 & 4406 - Mentor - 2012
FRC Team 2230 - Mentor - 2013-present
"A mentor's job is to understand what the students are trying to make, and bend the laws of physics to make that happen"
Unread 09-05-2010, 01:46
548swimmer's Avatar
CAD Leader
AKA: Alec Wagner
Team Role: CAD
The suspension is there to improve handling, much like a rocker, only smoother.
I was thinking about widening the carriage for the suspension and putting a dual sprocket with a bearing on the dead axle that is the pivot point. Then run chain to the omni.
Unread 09-05-2010, 01:51
The Blue Alliance
The point of using omnis is to avoid needing to "rock." I don't get how it would be smoother to have it rock AND have omnis.
And if you want it to rock, why don't you just drop the center and forget about the suspension?
If you want to still have the suspension, you could either do what you suggested or make the suspension go up and down along an arc with radius equal to the distance between the front and middle wheels, so the chain has a constant distance.
Eugene Fang
Unread 09-05-2010, 01:54
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Have you encountered a deficiency in the handling of a rigid (non suspended) drive?
Unread 09-05-2010, 02:00
548swimmer's Avatar
CAD Leader
AKA: Alec Wagner
Team Role: CAD
How can I make the carriages pivot around the center axel?
There is currently no rock at rest. Once you begin moving the suspension absorbs any jarring movements like sudden stops or turns, making it handle more smoothly.
Unread 09-05-2010, 02:08
The Blue Alliance
As sanddrag said, have you had any problems with a rigid drive? How much are you planning to have it rock? Too little rock and it would be practically the same as a rigid drive, and too much rock might affect accuracy of manipulating the game object due to uncontrollable front/back rocking.
Don't get me wrong, I think your idea is really cool. It's just the matter of seeing if all the effort to get it to work is worth it, and if the benefits are true benefits.
Eugene Fang
Unread 09-05-2010, 02:11
The Blue Alliance
I don't know if this would work structurally, but you could cut slots and make a block that rides in the slot.
The other option would to be have a long arm pivoting on the center axle, but that might be too heavy/bulky for practicality.
Eugene Fang
Unread 09-05-2010, 02:16
548swimmer's Avatar
CAD Leader
AKA: Alec Wagner
Team Role: CAD
We haven't had any issues with handling, but why not investagate this in the off season.
With springs tensioning the suspension, it will rock only as far as it needs to. Using a diff. eq. we can figure out the specs on the spring. Ideally, at rest, the spring keeps the wheels exactaly level. Once the robot starts moving and the CG "shifts" the springs will expand cushioning any sudden blow (like a rapid acceleration). Additionally, if this robot starts to get flipped, all wheels can stay on the ground providing some traction. The front ones would lift off the most, increasing the Fn on the rear and center
That still leaves the problem of chain runs though. I'm not sure a slot would have low enough friction, plus the exterior has to be smooth for the bumpers.
My religion is physics, it can explain everything.
WINNER -- 2011 Waterford District
District Chairman's -- 2011 Waterford District
Finalist -- 2011 Ann Arbor District
State Chairman's -- 2011 Michigan State Championship
Quarter-finalist -- 2011 Galileo
2011 Championship -- Highest Ranking Score
Unread 09-05-2010, 02:56
How about this: Run the chain so that it is long enough to handle the longest dimension, and stick a couple of McMaster part 5896K1 in there as tensioners. That should help keep the chain tensioned correctly, if you don't have too big of difference between longest and shortest chain runs.
Unread 09-05-2010, 03:04
548swimmer's Avatar
CAD Leader
AKA: Alec Wagner
Team Role: CAD
We use 25 chain though, so that won't work. I guess we could always make our own...
Do you have any experience with whether or not these fall out or how they work? I don't see how they could tension in a situation like this.
pic: Prototype Drivetrain 548swimmer Extra Discussion 38 09-05-2010 21:14
pic: 499 Prototype drivetrain final layout Andrew Schuetze Extra Discussion 9 01-01-2008 21:37
pic: A drivetrain prototype idea GMAdan Extra Discussion 16 24-04-2007 16:14
1541 Prototype Drivetrain bombadier337 Technical Discussion 12 23-01-2006 08:26
Image Discuss: Team 773 Drivetrain Prototype CD47-Bot Extra Discussion 5 27-01-2003 18:46
