Go to Post Sorry- therefore IOU 1 Battery- you can collect it on I-95 about 1 mile south of exit 13A in the center lane...... (ps- of course that battery is "free of charge") - Wayne C. [more]
  #31   Spotlight this post!
Unread 09-05-2010, 22:17
Re: pic: Prototype Drivetrain v2
Originally Posted by 548swimmer View Post
Yeah, I realized that after I posted. How would these work in this situation? If they tension, how do you get them in? Do they allow for the variable chain lengths?
Note that they're rubber. You put them into the chain like a sprocket. If you're careful about it, you can arrange for them to be slightly compressed (which you couldn't do with a normal sprocket) when the suspension is at "neutral" position (where it would normally be while sitting there, and the longest distance/flattest chain). Then it would force the chain to "shorten" when it got the chance, like when the suspension moved.
  #32   Spotlight this post!
Unread 09-05-2010, 22:19
Hawiian Cadder's Avatar
AKA: Isaak
FRC #0159 (Alpine Robotics)
Team Role: CAD
woah, if that only weighs 30 lbs then something is wrong, a cim in a 1-12 bane bots gear box weighs 12 lbs, there is no way 2 cims and the whole rest of that is under 6 lbs
  #33   Spotlight this post!
Unread 09-05-2010, 22:25
548swimmer's Avatar
548swimmer 548swimmer is offline
CAD Leader
AKA: Alec Wagner
FRC #0548 (Robostangs)
Team Role: CAD
548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of
I'll check my materials tomorrow. Thanks for catching that.
There is also a new post with the tensioning solution for you guys to look at.
My religion is physics, it can explain everything.
WINNER -- 2011 Waterford District
District Chairman's -- 2011 Waterford District
Finalist -- 2011 Ann Arbor District
State Chairman's -- 2011 Michigan State Championship
Quarter-finalist -- 2011 Galileo
2011 Championship -- Highest Ranking Score
  #34   Spotlight this post!
Unread 09-05-2010, 23:30
Jack Jones Jack Jones is offline
Retired
Jack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond repute
I'm not sure how to power the omni's when they're in a suspension.
Lengthen the omni wheel swing arms and pivot them on the center drive axels. That way the distance between centers remains constant as the arms rotate. Use slot mounted dead axels on the omnis to tension the chains.
Confucius say: Man who think physics is religion must sit in own pew.
This message is hidden because Jack Jones is on your ignore list.
  #35   Spotlight this post!
Unread 09-05-2010, 23:40
548swimmer's Avatar
CAD Leader
AKA: Alec Wagner
Team Role: CAD
Physics explains more than Christianity, but let's not get into that.
http://www.chiefdelphi.com/media/photos/35715?
Already got the tensioning down. I prayed to the physics gods, and they answered!!
  #36   Spotlight this post!
Unread 10-05-2010, 00:26
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
Better yet, remove the suspension as it is a solution to a nonexistent problem and greatly complicates things as well as adds more points of failure. There is a lot to be said for simple well thought out designs. Look at any drivetrain from 254/968 for inspiration
Mentor 2415
  #37   Spotlight this post!
Unread 10-05-2010, 00:33
548swimmer's Avatar
CAD Leader
AKA: Alec Wagner
Team Role: CAD
  #38   Spotlight this post!
Unread 10-05-2010, 00:34
548swimmer's Avatar
CAD Leader
AKA: Alec Wagner
Team Role: CAD
I got everything working smoothly in the latest version. Check it out.
  #39   Spotlight this post!
Unread 10-05-2010, 00:35
548swimmer's Avatar
CAD Leader
AKA: Alec Wagner
Team Role: CAD
There is no good way for 2 arms to mount on one axle evenly though.
  #40   Spotlight this post!
Unread 10-05-2010, 06:26
Retired
If you say so.
  #41   Spotlight this post!
Unread 10-05-2010, 11:01
548swimmer's Avatar
CAD Leader
AKA: Alec Wagner
Team Role: CAD
If you say so.
I do not see a goo way to accomplish this. If you have any ideas as to how this would work, please let me know because I am eager to expand my knowledge.
  #42   Spotlight this post!
Unread 10-05-2010, 21:16
You could do a dovetail mount. It would take some machining, but it would probably work. Something like the image below (= is the axle).
__ __
  #43   Spotlight this post!
Unread 10-05-2010, 22:24
548swimmer's Avatar
CAD Leader
AKA: Alec Wagner
Team Role: CAD
__ __
I'm not sure how a dovetail mount would work here. Could you do a quick mock-up in mspaint or an equivalent? I also believe I solved he problem with v2.1. Thanks for the idea, I can't wait till I fully understand it!
  #44   Spotlight this post!
Unread 10-05-2010, 23:29
*curses at VB's not putting spaces in right*
If you've ever seen a dovetail joint, it should be fairly simple to figure out. Look at a standard door hinge; that's a fairly common dovetail application. Now replace the pin with an axle, and the screw plates with swing arms. You'd need to change the geometry and check the stresses, but that's pretty simple to do.
  #45   Spotlight this post!
Unread 10-05-2010, 23:45
548swimmer's Avatar
CAD Leader
AKA: Alec Wagner
Team Role: CAD
Door hinges aren't dovetails, are they? I always thought dovetails looked like this:
/_\ or \_/-\_/-\_/ with the dashed part cutout and bottom line at the top
pic: Prototype Drivetrain 548swimmer Extra Discussion 38 09-05-2010 21:14
pic: 499 Prototype drivetrain final layout Andrew Schuetze Extra Discussion 9 01-01-2008 21:37
pic: A drivetrain prototype idea GMAdan Extra Discussion 16 24-04-2007 16:14
1541 Prototype Drivetrain bombadier337 Technical Discussion 12 23-01-2006 08:26
Image Discuss: Team 773 Drivetrain Prototype CD47-Bot Extra Discussion 5 27-01-2003 18:46
