Go to Post It's a twitter post. It's not a hint. - Libby K [more]
Unread 10-05-2010, 14:56
whatabouteve whatabouteve is offline
AKA: Dean Keithly
FRC #0245 (Adambots)
whatabouteve is an unknown quantity at this point
Sine and Cosine in C++
Hey i'm one of the programmers from team 245 the Adambots and we are trying to use the gyro and accelerometer together to determine distances traveled with our robot.
Since we are not expert programmers, we are wondering how to use sin and cos to find distances traveled using vectors.
Note: we just need the syntax for the use of these functions.
Unread 10-05-2010, 15:03
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
Re: Sine and Cosine in C++
float x=sin(radian);
float y=cos(radian);
from
www.cplusplus.com/reference/clibrary/cmath/sin/
and
www.cplusplus.com/reference/clibrary/cmath/cos/
*note: you may need to #include <math.h>
Watchdog.Kill();
Unread 10-05-2010, 17:03
Robototes2412's Avatar
Robototes2412 Robototes2412 is offline
1 * 4 != 14
FRC #2412 (Robototes)
Robototes2412 is on a distinguished road
you absolutely have to import math.h, unless you're using gnulibc which has math.h byitself
Unread 11-05-2010, 00:04
slavik262's Avatar
slavik262 slavik262 is offline
We do what we must because we can.
AKA: Matt Kline
FRC #0537 (Charger Robotics)
slavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to behold
Send a message via AIM to slavik262
Or you can use the C++ wrapper for math.h and do
#include <cmath>
Unread 11-05-2010, 01:50
mikets's Avatar
mikets mikets is offline
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
We used the accelerometer to determine the distance travelled by doing a double integration on acceleration. We wrote a generic accelerometer module that will give you accel/vel/distance on all three axes. Then we defined a macro called MAGNITUDE that will take the x and y vectors and gives you distance magnitude and also the macro DIR_DEGREE to calculate the heading.
#define MAGNITUDE(x,y)          sqrt(pow(x, 2) + pow(y, 2))
#define RADIANS_TO_DEGREES(n)   ((n)*180.0/PI)
// Forward is 0-radian
#define DIR_RADIANS(x,y)        (((x == 0.0) && (y == 0.0))? 0.0: atan2(x, y))
#define DIR_DEGREES(x,y)        RADIANS_TO_DEGREES(DIR_RADIANS(x, y))
Our accelerometer code can be found at
http://proj.titanrobotics.net/hg/Frc...inc/TrcAccel.h
But be careful when using the double integrator code. The accelerometer has noise, so even if the robot sits still, you may end up with an increasing velocity if you sit long enough. Our code doesn't enable the accelerometer integration until right before we need it. And it clears the integrator right before we enable it so it clears the cumulated error. It also does zero-G calibration at the beginning initialization phase to eliminate the DC offset of the accelerometer. Also be mindful on situation that if your robot gets bumped or accelerates/decelerates too fast, it could saturate the accelerometer output so to give you error on your integraton. With all those limitations in mind, it will give you decent results for a short period of time.
Unread 11-05-2010, 10:36
Does your code try to do anything to compensate for gravity when going over the bumps?
Unread 11-05-2010, 10:58
mikets's Avatar
Software Engineer
No, our code was primarily used for autonomous period. And we did not plan to go over the bump. Like I said, if you hit the bump, the impact will probably saturate the accelerometer and render the reading inaccurate. We know the limitation of the code and only use it within its limit. In any case, the accelerometer library code will give you the accel/vel/distance for all the axes. So in theory, you could take the z-axis data and do some compensation with it. But we did not do that in our main code.
Thanks to 1742 and 1209/Congrats to 2410, 935, and 1987 vhcook Thanks and/or Congrats 4 28-03-2010 15:50
Boilermaker Regional - WFFA and Volunteer Award and the Trio! Chris Fultz Thanks and/or Congrats 1 21-03-2010 14:05
Congratulations and Thank you to Team 341, 694 and 3204! AnibaS Thanks and/or Congrats 2 18-03-2010 07:40
Thank You and Congrats to Teams 20, 2079, 195, and 1124! Chris is me Thanks and/or Congrats 12 16-03-2010 09:16
Visual Basic. Using a loop to solve the cosine function. sanddrag Programming 2 10-03-2006 11:45
