Go to Post Don't give up on others. I believe in killing grumps with a smile! - maltz1881 [more]
Unread 10-05-2010, 19:07
cybiko123's Avatar
cybiko123 cybiko123 is offline
Roving Mentor
no team (Illinois FIRST)
cybiko123 is an unknown quantity at this point
Question Compressor works in teleop but not autonomous?
Hi,
We're having some issues with our compressor in autonomous. compressor.start(); doesn't seem to do anything, but all other code in autonomous works fine, and compressor.start(); works in teleop.
Are we doing something wrong?
Unread 10-05-2010, 20:40
buildmaster5000 buildmaster5000 is offline
Trying to program the swerve drive
AKA: Alex
FRC #2421 (Rolling Thunder Robotics)
buildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud ofbuildmaster5000 has much to be proud of
Re: Compressor works in teleop but not autonomous?
what we did was put the compressor.start(); line in robotInit() and it worked all the time
-Alex
2010 Washington DC Regional: Engineering Excellence Award
Unread 11-05-2010, 00:15
biojae's Avatar
biojae biojae is offline
Likes Omni drives :)
AKA: Justin Stocking
FTC #5011 (BOT SQUAD) && FTC#72(Garage bots)&& FRC#0399 (Eagle Robotics)
biojae is a jewel in the roughbiojae is a jewel in the roughbiojae is a jewel in the rough
compressor.start() won't start the compressor every time you call it.
It is designed to be called once for every time you stop it.
(it defaults to off)
When you call start, a semaphore is set to true.
This flag is checked twice a second by another thread, and if enabled (from the semaphore) and enabled (from the driver station) and the pressure switch pulls the IO pin to ground it sets the compressor's spike to turn on forward.
The line
c->Enabled()
is the semaphore that is set by calling start (and stop)
This is the thread that turns on and off the compressor (In C++, the Java version is very similar):
static void compressorChecker(Compressor *c)
         while (1)
                 if (c->Enabled())
                        c->SetRelayValue( c->GetPressureSwitchValue() == 0 ? Relay::kOn : Relay::kOff );
                 else
                         c->SetRelayValue(Relay::kOff);
                 Wait(0.5);
This starts right after creating the compressor object.
You only need to call start once in the program.
FTC Team 72 - No site
FRC Team 399 - http://www.team399.org
2010 Rockwell Collins Innovation in Control Award - (Use of the CAN bus, among other reasons) Phoenix, Arizona!
Unread 11-05-2010, 13:55
cybiko123's Avatar
Roving Mentor
Hi,
@biojae: We know that compressor.start(); is meant to be called once. The problem is, it doesn't do anything (even with pressure at zero).
In other words, it's not starting even when it should (and again, the compressor works in teleop without an issue).
@buildmaster5000: We're using SimpleRobotTemplate, so we don't have robotInit(). We'll try robotMain() and see what it does.
Updated LabVIEW and Compressor no longer works HansJ NI LabVIEW 1 18-02-2010 10:00
Camera tracking code not working in our own program, but works in CircleTrackerDemo TPNigl Programming 3 31-01-2010 19:40
Labview Autonomous AND Teleop Two-Face Programming 1 14-02-2009 18:33
Cam works but RC won't LightWaves1636 Programming 9 03-02-2006 13:15
New to C but not to basic, need help on autonomous cdennisxlx2 Programming 4 02-02-2005 03:38
