Go to Post I swear, sometimes it seems like FIRST has got a room full of monkeys writing code. Maybe the monkeys should spend less time flinging fecal matter at each other and more time testing the code before posting it :-). - Kevin Watson [more]
Unread 10-05-2010, 19:10
TEE's Avatar
TEE TEE is offline
FRC #0201
TEE has a spectacular aura aboutTEE has a spectacular aura aboutTEE has a spectacular aura about
G13, G44 and Pinching Rollers
In the finals on Archimedes, 201, 33, and 148 got a G44 carrying penalty both matches. Both times, 33 had a ball in possession, and if I remember correctly, was pushed up the bump by 233 or 254 so that the ball was no longer in contact with the playing field. Both times, they released the ball (by kicking or just letting go... I can't remember) as soon as they realized they were "carrying".
Now, rule G13 (Causing Penalties) states "The actions of an ALLIANCE shall not cause an opposing ALLIANCE to violate a rule and thus incur PENALTIES. Any rule violations committed by the affected ALLIANCE shall be excused, and no PENALTIES will be assigned. ", essentially that if a robot causes another robot to break a rule, no penalty will be assigned. So, the question is, wouldn't pushing a robot with a pinching roller in such a way that caused it to carry a ball be an example of causing "an opposing alliance to violate a rule"?
(In case anyone's wondering, this is one of many times the refs disappointed me. Please don't argue; I can cite several more examples, and the reason I'm not is that they're volunteers, and they give up lots of their spare time to help us out.)
Unread 10-05-2010, 19:11
TEE's Avatar
TEE TEE is offline
FRC #0201
Re: G13, G44 and Pinching Rollers
Oh, and penalties were assigned both times.
Unread 10-05-2010, 19:38
jamie_1930's Avatar
jamie_1930 jamie_1930 is offline
FRC #2228 (Cougartech)
Team Role: Student
jamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to behold
In my opinion you're right in this case. Although on a different note, I'd prefer we not dwell on the past seeing that competition season is officially over.
Team 2228(FRC) - Drive Team Lead, Drive Coach, Mechanical Team
Team 3750(FTC) - Team Lead
2009
Team 2228(FRC) - Mechanical Team, Driver at RIT, and Hartford Regionals, and Drive coach at Ruckus
*Second Place at Ruckus
Team 3750(FTC) - Team Lead, and Drive coach at Clarkson Regional
*Second Place at Clarkson Regional
2008
Team 1930(FRC) - Worked on Mechanical, Electrical, and Programming.
Unread 10-05-2010, 20:00
Eugene Fang's Avatar
Eugene Fang Eugene Fang is offline
The Blue Alliance
Eugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond repute
We had a qualification match against 148 in Archimedes. We pushed them onto the bump so that they were obviously "carrying" the ball. There was a penalty that match but it wasn't because of that. Just wanted to share.
Eugene Fang
2010 Silicon Valley Regional Dean's List Finalist
Various FLL Teams - Student (2000-2006), Mentor (2007-2010)
FRC Team 604 - Student (2007-2010), Mentor/Remote Advisor (2011-2015)
FRC Team 1323 - Mentor/Remote Advisor (2011-2014)
The Blue Alliance | TBA GameDay | TBA Android App
Unread 10-05-2010, 20:07
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
I'm obviously not an impartial source but I was field side directly in front of 33 when they got called for one of those carrying penalties. They were not being interacted with by another robot and were not against a bump. I saw the ref signal it and I saw the ball come up off the ground a bit. It wasn't very blatant, it's not like it was 2" off the ground-but you could see it come up.
That said, it wouldn't surprise me if the same thing had occurred to us at some point as well and it got missed or was given a pass. Our roller system is designed so it's nearly physically impossible for this to happen, but sometimes weird stuff occurs.
It seemed like for the most part the attitude of the referee crew on Archimedes was to let the teams play unless there was a very clear violation. Overall I thought it was the best reffing I had seen at any event I've been to this year, and maybe over the last two years.
2001-2004: Team 100
2006-Present: Team 254
ChristopherSD's Avatar
ChristopherSD ChristopherSD is offline
FRC #0201 (FEDS 201)
Team Role: Driver
ChristopherSD has much to be proud ofChristopherSD has much to be proud ofChristopherSD has much to be proud ofChristopherSD has much to be proud ofChristopherSD has much to be proud ofChristopherSD has much to be proud ofChristopherSD has much to be proud ofChristopherSD has much to be proud of
If I read correctly, I think you're correct. I've recorded videos of every elimination round 201 was in, so I'll look those over sometime soon.
Unread 10-05-2010, 21:54
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
I thought the reffing was fantastic on Archimedes. I have no complaints about any of the calls in our run. We got beat in two very tough matches against an incredible alliance!
Unread 10-05-2010, 21:55
I don't think so.
If your robot picks the ball up off the ground, it's a penalty. Another robot pushing you up the ramp didn't cause your rollers to keep a hold of the ball.
Unread 10-05-2010, 22:01
Team Role: Driver
The reffing was indeed excellent during the elimination rounds. They did scare me after that first match of the eliminations when we thought we had lost. I was relieved when they corrected it.
Unread 11-05-2010, 19:22
sgreco's Avatar
sgreco sgreco is offline
AKA: Steven Greco
FRC #2079
sgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond repute
Originally Posted by Tom Bottiglieri View Post
I don't think so.
I agree, the reason the penalty was called was because the defending robot did not directly cause the picking up of the ball. True the ball wouldn't have been picked up if it weren't for the defence, but the mechanism caused the ball to be lifted not so much the act of the other robot pushing.
Unread 11-05-2010, 19:33
ttldomination's Avatar
Sunny
I think each year, many robots are built for intended purposes, and when the opposing alliance forces you to into a situation like that, then it is not the fault of the robot.
There are arguments for both sides, and I think that the easiest way would've been to talk to the head ref right after the match and see what really happened.
- Sunny
1648: 2013-2014
5283: 2015
Unread 12-05-2010, 10:18
"Dwell on the past" has a negative connotation that doesn't seem to reflect the tone of the original post.
Provided the discussion is civil, it is productive and useful to have such a dialog. Some good may come of it.
Unread 12-05-2010, 13:01
jspatz1's Avatar
jspatz1 jspatz1 is offline
AKA: Jeff
FRC #1986 (Team Titanium)
jspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond repute
Send a message via AIM to jspatz1
I see the use of pinching rollers this year as a high-risk, high-reward gamble for those that chose to employ them, and was sort of the elephant in the room all season. Some had the flexibility or verticle freedom to leave the ball in contact with the ground when the robot experienced small bumps or elevations. Some did not. If you chose to grip the ball, you were making a judgement that the benefits of doing so outweighed the risks of incurring penalties when your robot experienced motions that caused the ball to come out of contact with the carpet momentarily. For those that had no flexibility in their gripper, it was almost a given that at some moment in the match they would experience some motion that would cause them to technically carry the ball when bumped by another robot, when going over a small lip or bump (such as the lip in front of the bumps), when tilting slightly through their own movements, or when pushing a ball into a goal. The real question was whether the referees would catch these momentary lifts, or whether they would interpret them to be penalized lifts. In my opinion, incurring a penalty because another robot bumped you when you were gripping a ball is not the kind of situation that is being refered to in the "one robot cannot cause a penatly for another robot" rule. Significant contact between robots is expected and part of the game. If it was the nature of your gripper that such robot contact caused you to lift the ball, then that was a vulnerablility of your design and a risk you chose to take. In our case, we interpreted the carry rule as absolute, and chose to capture the ball against the carpet so that is was impossible to inadvertantly carry. But we recognize that a pinching roller was an effective and worthwhile tactic for those that did it well.
Unread 13-05-2010, 13:02
Wayne TenBrink's Avatar
Wayne TenBrink Wayne TenBrink is offline
<< (2008 Game Piece)
FRC #1918 (NC Gears)
Wayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond repute
Pardon me for veering off the original topic, but I have a related question and comment.
The question: If a "red" robot was parked on top of the bump next to the "blue" home zone, would/should they be penalized if a red robot pushed them off the bump and into the blue zone, making them the 2nd red bot in the blue zone? Is that part of normal contact or is that forcing a penalty? (For example, if my alliance is playing against 469 at the MARC and we put a robot on the bump right next to them, would we get a red card if somebody pushed that bot off the bump?)
The comment: There has been a lot of discussion about robots that are inherently capable of violating rules which are difficult for the referees to judge (2010: 3" incursion, active mechanisms above the bumper, multiple ball possession, pinching roller; 2007/2008: envelope violations, etc.). In my opinion, unless a feature or capability is specifically forbidden by either the robot rules (inspector's call) or game rules (referee's call), teams have the right to risk penalty in exchange for enhanced capability - as long as there is a legitimate/legal use for that capability. However, I think these teams should expect that referees will rule against them in the case of a close call. (For example, a robot with a wide ball collector that is posessing one ball while it "herds" another with the same device does not deserve the benefit of the doubt.)
NC Gears (Newaygo County Geeks Engineering Awesome Robotic Solutions)
FRC 1918 (Competing at St. Joseph and West MI in 2017)
FTC 6043 & 7911
Unread 13-05-2010, 17:50
jspatz1's Avatar
AKA: Jeff
Absolutely right. Everyone has the right to push the envelope, that is what sometimes separates the good robots from the great. Any penalty-capable feature is a calculated risk. You can be sure there were many momentary lifts by pinch rollers this year that were not caught by referees. Judging how far you can push a rule is a design decision we face with almost every game. Just one aspect of predicting what the gameplay will really be like.
The spread of pinching rollers this year AdamHeard General Forum 51 06-05-2010 12:44
Carrying <G44> aldaeron General Forum 26 13-01-2010 09:24
Ball Visibility (G13) dmlutz Rules/Strategy 3 20-01-2006 23:52
Regarding <G13> - placement of the tetra by the human player. Leav Rules/Strategy 7 02-02-2005 10:26
Ball Rollers archiver 2001 8 23-06-2002 23:26
