Go to Post Instead of dreading the potential alliance think of ways to impress them so they want you to be part of it! - Koko Ed [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 11-05-2010, 10:00
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
Re: Set Jaguar device number via cRIO
I think if the enumeration worked, then the other CAN communications would work. However, I don't know what would cause the enumeration to respond like this.
What does it mean when it says there's only one device on the network, and its address is 0? Why doesn't it just say there are no devices there?
-- Marshal Horn
Set computer to receive it's IP via DHCP? grosh FRC Control System 21 28-05-2010 16:33
Set Jaguar device number via cRIO kamocat FRC Control System 0 08-05-2010 20:41
CAN Jaguar code set up as a VxWorks Library taichichuan CAN 0 21-02-2010 22:16
Unable to set team number Erebos FRC Control System 4 27-01-2009 17:00
Can not set team number on DS TekClaz FRC Control System 2 23-12-2008 14:25
