Go to Post I would say FIRST is quite an addiction.............but one of the BEST addictions you'll ever have. - RoboMadi [more]
Unread 11-05-2010, 13:42
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
AndyMark Mecanum Wheel tests
All,
We at AndyMark have started a study regarding AndyMark Mecanum-style wheels. We are testing these wheels with regard to the factors listed below. While there are some commonly-accepted rules of thumb regarding Mecanum wheels, we are conducting tests to see if they are actually true.
Here are our current tests:
1. Weight limit of new design of 8" AndyMark Mecanum wheels: Our initial tests show that these wheels can each handle 120 pounds each easily, thanks to our new roller axle design.
2. Pushing power of 8" Mecanum Wheels vs. 8" 2010 Kit wheels (on carpet)
3. Distance traveled of a drive system with 8" Mecanum Wheels (using a 3 second auto-mode) vs. 8" 2010 Kit wheels
4. Pushing power and distance traveled of the system with 8" Mecanum Wheels while strafing sideways, using the same values of input with the automode, but with appropriate wheel direction changes to allow for sideways movement (thanks, Joe Blay)
These tests will be done with a lightweight drive base (~80 pounds), a medium weight drive base (~150 pounds), and a heavy drive base (~230 pounds). We will also vary the cleanliness of the rubber surface on the wheels to see how that effects the testing.
What other tests would you like to see?
If you would like to request a reasonable test, you can either send me a PM or post your request in this thread.
In other news... we are currently in the middle of a redesign for our 6" Mecanum wheel. While we will still offer our current 6" wheels, we are working on a heavy-duty version, due to be out by mid-July.
Thank you,
Andy B.
Unread 11-05-2010, 14:01
Dave McLaughlin's Avatar
Dave McLaughlin Dave McLaughlin is offline
Dave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond repute
Re: AndyMark Mecanum Wheel tests
Will the new version have a locking option?
Unread 11-05-2010, 14:05
jblay's Avatar
jblay jblay is offline
Here comes StuyPulse
AKA: Joe Blay
FRC #0694 (StuyPulse)
jblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond repute
Figure out pushing ability and speed when strafing. Essentially what you already plan to do just with strafing.
It's pronounced StighPulse like HighPulse
2016 Curie Champions
2016 New York City Champions
2016 New York City Engineering Inspiration
2015 New York City Finalists
2013 New York City Champions
2012 Connecticut Chairman's
2011 Connecticut Chairman's
2010 Connecticut Chairman's
2010 New York City Champions
2008 New York City Engineering Inspiration
2007 New York City Finalists
2006 New York City Finalists
2005 New York City Chairman's
2003 New York City Champions
2002 New York City Engineering Inspiration
2001 New York City Finalists
No
Unread 11-05-2010, 14:06
Excellent input. I will add this to my list on the original post.
Andy
Unread 11-05-2010, 14:13
rutzman rutzman is online now
AKA: Ryan
FRC #2614 (MARS)
rutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant future
We'd like to know if you can use different rollers to trade off on traction vs power efficiency, i.e., can you swap in some sticky rollers and what affects will that have?
Unread 11-05-2010, 14:23
What effect would a cantilevered load have on all of the above tests? (i.e., a mecanum robot with an arm extended it with a load) Anyone thinking about using an arm with mecanum wheels would probably want to know that.
Also, would the effect change if the arm was off the side for some reason?
I don't think it would be too hard to test this--a 5-10 lb known weight at a known distance from the frame, bolted on, should work easily.
Unread 11-05-2010, 14:46
foote stepped in
AKA: E. Foote
FRC #0868
Maximum RPM? Some other destructive spin tests?
How long does it take to wear the treads down until they become unusable (vrs kit wheels and some carpet or sand paper?)
Could get messy.
Be Healthy. Never Stop Learning. Say It Like It Is. Own It.
Like our values? Flexware Innovation is looking for Automation Engineers. Check us out!
Unread 11-05-2010, 15:22
Jared Russell's Avatar
Jared Russell Jared Russell is online now
Taking a year (mostly) off
Top speed (100% throttle) with:
1. 8" mecanum wheels (forward/backward)
2. 8" mecanum wheels (strafing left/right)
3. 8" kit wheels
All with the same chassis weight, number of motors, and gear ratio.
Your pushing test will determine how much torque is lost (if any) due to the mecanum geometry - this test would answer the same question about speed.
Unread 11-05-2010, 17:24
Lil' Lavery Lil' Lavery is online now
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
The same 3 second auto tests as mentioned before, but with rotation instead of linear distance.
Unread 11-05-2010, 17:33
Chris is me's Avatar
AKA: Pinecone
Running all the tests with a rigid chassis, and then the same tests with a flexible chassis / passive suspension?
Unread 11-05-2010, 17:46
theprgramerdude theprgramerdude is offline
WPI Freshman
AKA: Alex
FRC #2503 (Warrior Robotics)
theprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud of
Could get messy.
I too would like too see this, as we demo the robot in the off season on various non-carpet surfaces, and were wondering how much we could put the wheels through without worrying about trashing the rubber. I personally know from other experiences that the hard starts and stops that can happen with a robot can be more than some driving components can handle.
It's always an option for us to replace the wheels with KOP rubbers for demos, but it's much more exciting to show off the sideways motion.
Unread 11-05-2010, 18:05
wilmo's Avatar
wilmo wilmo is offline
FRC #0868 (TechHOUNDS)
wilmo will become famous soon enough
Mr. Baker,
I would suggest a shock load test, much like the robot going over the bumps this year. This is were we incurred most of the damage to our AM Mecanums this year.
Thank you for including the roller-cleanliness variable. We ended up wiping down each roller with a lacquer remover before each match, especially at regionals with very dirty floors (KC, Purdue).
Thanks,
Adam Wilmes
Unread 11-05-2010, 18:07
Nadav Zingerman Nadav Zingerman is offline
FRC #2230
Nadav Zingerman is a splendid one to beholdNadav Zingerman is a splendid one to beholdNadav Zingerman is a splendid one to beholdNadav Zingerman is a splendid one to beholdNadav Zingerman is a splendid one to beholdNadav Zingerman is a splendid one to beholdNadav Zingerman is a splendid one to behold
I'd like to see a comparison of X-configuration vs. diamond-configuration Meccanum.
Unread 11-05-2010, 18:56
foote stepped in
AKA: E. Foote
FRC #0868
you mean able to turn versus unable to turn?
Mecanum wheel size Mr. A Technical Discussion 7 18-01-2010 08:58
AndyMark 10" Mecanum Wheels ChuckDickerson General Forum 7 31-12-2008 12:54
Trouble: AndyMark Mecanum wheels bbr4d3r Technical Discussion 6 28-01-2008 20:27
AndyMark Mecanum whytheheckme Technical Discussion 5 27-01-2007 23:57
pic: AndyMark Mecanum Wheels Madison Technical Discussion 13 09-10-2006 00:29
