Re: pic: 3 Hour Chassis + 2 Hours
There's a chain reduction, so direct driving the center wheel isn't possible without a gearing change.
Good point, but in the previous thread on this topic the OP mentioned making custom gearboxes.
Or on the back side of that wheel the sprocket is smaller than all the others and after looking at the AndyMark website the smallest sprocket (#25 I am assuming) is 32 tooth and the sprocket on the toughbox output shaft is still 16 that means the overall reduction is 25.5:1 and the top speed is 4.57ft/s From what I know your average single speed robot is ~9ft/s which would cause me to thing there is some sort of difference in the toughbox or the extra chain reduction can be removed and supplemented with one of the many gearing options AndyMark has for sale. After going back to the old thread I see that your wanting to get ~12ft/s which you can do by using the Toughbox with the optional 9.87:1 and direct drive which would give you ~11.82 ft/s Last edited by Jeff 801 : 11-05-2010 at 17:48. Reason: More info |
You could consider a 1x1 bar of 80/20 insead of what you have for the cross pieces. The ends can be tapped for a 1/4 20 bolt and you can just bolt it to the outer plate. This also leaves you a lot of flexibilty on the inside as far as mounting other components.
I think it would work nicely in a prototype like this. My team actually used a very similar frame to this this year, aluminum side plates, cross beams extending to the outer plate, toughbox transmission etc...Anyway the 80/20 worked nicely for us on the cross braces. |
80/20 is unneccessary if your team CADs well, because you can plan all of your cuts ahead of time. 80/20 can be nice if your team likes to make it up as you go and constantly be taking off and adding parts. (not that you can't do it with other materials, just 80/20 makes it easy). I would still recommend it for a prototype though. |
#7
Not really, 80/20 weighs almost exactly the same as 1/8" wall 1" square tubing.
#8
For the hollow tube in general, you're right. But for the specific hollow tube called for, 80/20 will be heavier. Comment on the cross-braces: I'm not quite sure I'd trust a 1/16" wall for that application in that pattern. Change the pattern, and you'll probably be fine--but run the analysis just to make sure. |
#9
(These numbers are what SolidWorks is telling me). You can pocket 1x1 tubing, but you can't pocket 80/20 so that could be included in the weight tradeoff. Last edited by sgreco : 11-05-2010 at 19:46. |
#10
i would recommend the use of C channel instead of square pipe, it can be just as strong if oriented correctly, and it is lighter as well as easier to attached.
#11
That 9.87:1 Toughbox seems interesting, but if we're going to buy more Toughboxes, we might as well just make our own (lighter) gearboxes. I just threw the Toughboxes in the CAD in the event that the team wanted to save money and use the Toughboxes we already have. |
#12
I'm all for custom gearboxes, but if you want to keep it simple, you have a lot of options. |
#13
Running 12fps without shifting and using roughtop tread will lead to a lot of current issues as well as iffy acceleration.
| pic: 3 Hour Drivetrain | Ty Tremblay | Extra Discussion | 8 | 11-05-2010 16:47 |
| pic: How many hours at robotics to get to this point? | samir13k | Extra Discussion | 8 | 26-02-2009 08:50 |
| pic: Spam Drive Team After Hours | GateRunner | Extra Discussion | 19 | 08-04-2005 17:11 |
| pic: 11 hours from ship (1002) | Jonz0r | Robot Showcase | 4 | 24-02-2005 18:35 |
| One hour Chassis? | Josh Hambright | Technical Discussion | 23 | 07-02-2003 10:08 |
