#31
Re: Using A PS3 With The cRio
Makes a system like a beagleboard more attractive, now doesn't it?
#32
Eh, IDK Beagle board seems like a good option right now, but I am not really sure how well it can process the images and stuff
#33
The Beagleboard has all kind of access to TI's video & audio CODECs under Linux. With the OMAP 3530 on the Beagleboard, you've even got a TI C6X DSP. This is one of the reasons for my low-cost Linux-based robot solution thread. But, if you hold off until next month, the Beagleboard XM will be out and it's got an Ethernet onboard. The standard Beagleboard only has USB and serial interfaces unless you want to pony up for a Zippy board. Realistically, I'd give serious consideration to one of the Gumstix Overo boards. They're based on the same OMAP processor and have more I/O options including an Ethernet via the Tobi add-on board. Check out my Linux thread for more ideas:
http://www.chiefdelphi.com/forums/sh...ad.php?t=85510 HTH, Mike |
#34
https://www-01.ibm.com/chips/techlib...3Apr09_pub.pdf
Start Reading, its very long The first couple pages are a ton of info... My mind is overwhelmed Last edited by davidthefat : 19-05-2010 at 23:35. |
#35
Not to side track this thread too much, but do you have any knowledge on when an OMAP4 board similar to the beagleboard will be out? I'm looking for a board with USB, some good RAM, flash, Linux, and Ethernet, and I'm not in that big a rush. I'd like it to have some good compute power with good floating point performance so that I can run AI and mapping on it, without killing the batteries like a real laptop or ATOM cpu would.
| How do you run the pneumatics through the CRio w/o using the Jaguars and the Spikes | brreadd | Pneumatics | 3 | 20-11-2009 15:35 |
| Using Pneumatics with the CRIO? | nighterfighter | FRC Control System | 9 | 18-10-2009 22:59 |
| Using the cRIO to control custom lights | hal_2498 | FRC Control System | 14 | 10-04-2009 07:55 |
| Using Sockets with the cRio in Wind River | C222 | C/C++ | 15 | 17-02-2009 14:10 |
| Using Standard Labview with cRIO | writchie | FRC Control System | 2 | 23-01-2009 13:44 |
