Go to Post Imagination is important, but try not to use it as a substitute for actual information. - Alan Anderson [more]
Unread 11-05-2010, 21:29
Ty Tremblay's Avatar
Robotics Engineer
FRC #0319 (Big Bad Bob)
The Center Wheel
I'm designing a 6-wheel drive train and I'm debating on whether or not to drop the center wheel. I know of several teams that drop the center wheel, but I also know of several teams that don't.
Dropping the center wheel can improve the maneuverability of a robot, and can also prevent "hopping" when the robot turns. However, in my opinion, it reduces the robot's stability footprint. Unless I'm convinced otherwise by this thread, I'd like to keep all 6 wheels on the ground.
I'd really like to hear from teams that don't do dropped wheel drive trains, particularly regarding how they prevent their robots from "hopping". Teams that immediately come to mind: 254, 233, 968, 25
Unread 11-05-2010, 21:47
RyanS's Avatar
RyanS RyanS is offline
Team Captain
AKA: Power Driver
RyanS has a spectacular aura aboutRyanS has a spectacular aura about
Re: The Center Wheel
I would recommend dropping the center wheel. We have done so since 2005 excluding 2009 with varying amounts of success. Over the years, we have dialed in the drop to around .8" to .125". The only time we had trouble with dropping the center wheels was in 2008. I believe we had like 3/16 of drop that year and a very centrally located CG. We were to maneuverable to the point where the robot was tough to control.
On the Issue of stability, we have never had an issue. Maybe because we always try to keep our CG low.
Hope this helps.
-Ryan
2010 Los Angeles Finalists
2010 San Diego Regional Winners
2009 Los Angeles Regional Finalists
2008 San Diego Regional Winners
2008 FTC World Champions
Unread 11-05-2010, 21:54
mikelowry mikelowry is offline
FRC #1771 (N.G.R.)
mikelowry is a name known to allmikelowry is a name known to allmikelowry is a name known to allmikelowry is a name known to allmikelowry is a name known to allmikelowry is a name known to all
Assuming you are using 6 traction wheels, you need to drop the center wheel. The robot wont turn if you don't.
If you dont want to drop the center wheel, you can use either 2 or 4 omni wheels on the corners so that they roll instead of skidding.
2008 Xerox Creativity Award - Championships
2009 Rockwell Automation Innovation in Control award - Peachtree
2009 GM Industrial Design Award - Palmetto
2009 Palmetto Champions <1771 2415 21>
Unread 11-05-2010, 21:56
Chris is me's Avatar
AKA: Pinecone
Every one of those teams bar 25 does dropped wheels.
I actually don't know of a single other team that consistently does 6WD non dropped wheels, to give you an idea of its popularity.
Unread 11-05-2010, 21:59
DonRotolo's Avatar
Back to humble
FRC #0832
The decision to drop or not depends upon the traction of your outer 4 wheels. Less traction means less need for drop, more traction means more. Thus mikelowry's comment "Assuming you are using 6 traction wheels, you need to drop the center wheel. The robot wont turn if you don't."
Make a set of side plates that have an adjustment for center drop, get a bunch of different wheels and experiment. Best way to learn.
Unread 11-05-2010, 22:03
Robotics Engineer
Which wheels do 254 and 968 drop on their 8-wheel drivetrains?
Unread 11-05-2010, 22:06
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
The 4 center ones.
Drop your center wheels, unless you don't want to turn. 25 may not drop their wheels, but you'll find 25 teams who don't drop their centers and can't turn for every 1 team that can
2001-2004: Team 100
2006-Present: Team 254
Unread 11-05-2010, 22:33
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Don made a great suggestion (as usual), try some different things and see how it works.
And you can play engineer first, figure out what will happen using math and physics equations, then see how close your predictions are to your experimental results.
Unread 11-05-2010, 22:45
bigbeezy's Avatar
bigbeezy bigbeezy is offline
AKA: Bryan
FRC #2338 (Gear it Forward)
bigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to behold
Send a message via AIM to bigbeezy
i am 90% sure 233 drops their center wheel, just very slightly.
we have always dropped the center wheel. Depending on how far u drop it and how your CG is situated your bot will rock. I find this to be the best way to do tank drive. i personally hate the omni wheels in the corners as they make the bot far to easy to spin (from a defenders point of view). You can make a robot just a maneuverable and many times stronger by dropping the center wheel and putting real wheels on the corners.
my $0.02
Team 1592 Bionic Tigers -- Driver 2005-2008
Winner - Florida Regional 2005
Finalist - Newton Division 2007
Winner - Colorado Regional 2008
Florida State University - BS Mechanical Engineering
Team 2338 Gear it Forward -- Mentor/Drive Coach 2013-Present
Winner - Wisconsin Regional 2013
Chairman's Award - Midwest Regional 2015
Winner - Archimedes Sub-Division 2015
Chairman's Award - Midwest Regional 2016
Unread 11-05-2010, 22:50
Dhananjay T.'s Avatar
Dhananjay T. Dhananjay T. is offline
FRC #0025 (Raider Robotix)
Team Role: Student
Dhananjay T. is just really niceDhananjay T. is just really niceDhananjay T. is just really niceDhananjay T. is just really niceDhananjay T. is just really nice
We get this question all the time, with people curious about our turning. We find there to be no real use in dropping our center wheels, because if we do, at any given time, our 6 wheel drive train could just as well be a 6 wheel drive train with two wheels in the air.
I've noticed the "hopping" robots on the field, and wondered why we've never had the problem. The skyway wheels that we tread allow us to drive with 6 as well as turn great with 6. They also have a wider width then most wheels used by FRC teams.
mwtidd's Avatar
mwtidd mwtidd is offline
AKA: mike
yeah I was thinking if you did an 8-wheel with the middle wheels dropped you could form the equivalent of a square chassis. I may be wrong but I'm pretty sure the skidding come from the drive being rectangular, causing conflicting vectors.
I know its a bit off topic, but has anyone tried a square mecanum drive? If so did you see a difference?
Unread 11-05-2010, 22:52
MrForbes's Avatar
AKA: Jim
Coefficient of friction of the wheels on the carpet is one of part of the equation...normal force is another. If you have less friction, you can have more normal force, and still be able to steer as easily.
Unread 11-05-2010, 23:09
jamie_1930's Avatar
jamie_1930 jamie_1930 is offline
FRC #2228 (Cougartech)
Team Role: Student
jamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to behold
It seems like that your problem with dropping the wheel is just because you think it will decrease the robot's stability, which in my opinion it will although I don't have an answer for you on how much, but if this is your problem I say go with your instincts and keep them at the same level. Although in order to gain some of the manueverabilty that dropping allows, make your outer wheels omni wheels and have your center wheel be traction.
On a different note and this is something I think we'll be trying in the offseason is, and we stole this from SparX (1126), do a 6 wheel with a 1/8" center drop, with the center wheel be traction wheels along with one of the outer sets. While having the other end be omnis, this will change the bot in a way that if you go in one direction, so all traction wheels are touching, you have more traction to the ground, or travel in the opposite direction, with one set of traction and one set of omni wheels touching the ground, which will give you more maneuverability
Team 2228(FRC) - Drive Team Lead, Drive Coach, Mechanical Team
Team 3750(FTC) - Team Lead
2009
Team 2228(FRC) - Mechanical Team, Driver at RIT, and Hartford Regionals, and Drive coach at Ruckus
*Second Place at Ruckus
Team 3750(FTC) - Team Lead, and Drive coach at Clarkson Regional
*Second Place at Clarkson Regional
2008
Team 1930(FRC) - Worked on Mechanical, Electrical, and Programming.
Unread 11-05-2010, 23:10
DonRotolo's Avatar
Back to humble
FRC #0832
The relatively wide wheels Team 25 uses helps avoid hopping. Their siping program is a science and an art.
Unread 11-05-2010, 23:11
LLogan LLogan is offline
Head Screw Tightener/Cheerleader
AKA: Logan
FRC #1261 (Robolions)
LLogan has a spectacular aura aboutLLogan has a spectacular aura about
If you are very adamant about not dropping your center wheel, you can use outside wheels with a lesser coefficient of friction than your center wheel.
However, this will decrease your tractive force.
Adjustable Way of Dropping the Center Wheel R.C. Technical Discussion 15 06-08-2008 18:37
Lowered Center Wheel for 6 wheel drive 987HighRoller Technical Discussion 37 17-01-2007 01:21
Center to Center Distance for 2002 Chaiphua and Cluster gear sanddrag Motors 1 20-07-2005 07:36
pic: 885 Right-center wheel and drive assembly CD47-Bot Robot Showcase 2 30-04-2004 18:27
center-wheel drive Mercutio Technical Discussion 27 02-02-2004 21:19
