Re: Downloading Parts for Inventor 2011
It seems like I got everything sorted out.
I hadn't extracted the files correctly >.< Kinda a "duh" moment for me. And yes, the madtown Cad library worked for me too. Thanks! |
Sorry if this is kinda n00bish, but are there any i-parts that come with Inventor? Like, you specify dimensions for a piece of wood and it renders it for you.
Or do you have to CAD each piece? Thaine |
Use the Content Center (your going to have to apply the properties and texture of wood manually).
This might also sound a bit n00bish (hello Thaine, lolz), but I remember downloading some kind of complete library of parts last year for inventor from an autodesk website or something.
Does anyone know of anything similar to this, and or how I can just download the entire library from http://firstcadlibrary.com/ or http://team1323.com/cad/index.html without having to download each part individually? |
Here is the location for the 2011 Autodesk Inventor KOP:
http://students.autodesk.com/?nd=kit...lter=&x=38&y=9 Acquired from this thread. You might find some of the things brought up here both relevant and interesting: http://www.chiefdelphi.com/forums/sh...ad.php?t=88678 Good Luck and Happy CADing! |
#7
Does anyone know where I can get the FTC components for Inventor? I didn't see them on the Autodesk website.
#8
FTC parts you can get from www.3dcontentcentral.com
or they are inside of SolidWorks under Design Library>SolidWorksContent>Robotics>Tetrix We have most of the parts modeled and also a robot assembly to help get you started. Otherwise I would try PTC's website for FIRST. I believe they are the official sponsors of FTC. Mrie |
#9
Autodesk sponsors FRC, so we did not create an FTC kit of parts.
As Marie has noted there are sites where you can download the FTC parts. You should be able to open/import into Inventor as parts or into an assembly. Since they may not be native Inventor parts, you may have limited editing functionality, but for the purpose of this project they should work well. |
| inventor 2011 | kinghashbrown | Inventor | 8 | 05-05-2010 22:50 |
| Championship Venue Change for 2011-2013 | basicxman | General Forum | 2 | 28-03-2010 17:49 |
| downloading directions for program | chinckley | Programming | 7 | 15-02-2009 17:12 |
| Inventor model for Kit of Parts Transmission | q_prof | Inventor | 2 | 12-02-2006 23:54 |
