Go to Post A person is not defined by what mistakes they make, but more so by what they do after they realize their mistake. - Andy Baker [more]
Unread 11-05-2010, 22:10
DonRotolo's Avatar
Back to humble
FRC #0832
Re: AndyMark Mecanum Wheel tests
Originally Posted by wilmo View Post
I would suggest a shock load test
I second that.
For methodology, a drop from a fixed height with increasing weight, or a drop from an increasing height with a fixed weight. In my mind (empirically) I think your heavy bot, lifted 24 inches at one end and then dropped onto nominal playing surface would be adequate. See if it survives X drop cycles. X could be around 50-100.
Second suggestion: roller wear on macadam or smooth concrete (I am thinking parade duty here - can it go a mile?)
Don
Unread 11-05-2010, 22:47
CraigHickman
Posts: n/a
I'm curious as to the possibility of using your Mecanums in a situation where accurate odometery is required. For example, on a 50 pound robot, driving forward 10 feet at 1m/s, how much "slip" is encountered on a standard linoleum floor? The application wouldn't be FIRST, but a robot designed for SLAM (Simultaneous Localization And Mapping). Mecanums may not even be feasible for the part, but having some number of slip during normal operation would help.
Unread 11-05-2010, 22:55
pfreivald's Avatar
AKA: Patrick Freivald
While generally happy with the 6" AM mecanum wheels this year, we did have some problems with robustness and had to replace two wheels at Championship.
As such, I am particularly interested in any tests that demonstrate how much abuse they can (and cannot) take -- the drop test is a great idea. How about stress from FIRST-speed ramming (both head-on and from the side?)
Small deformations caused the rollers to rub and effected performance (not a ton, but some) on the 6" wheels. I'm not sure if this was/is an issue with the 8" wheels.
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 12-05-2010, 01:31
mcf747 mcf747 is offline
AKA: Matthew Forman
FRC #0190 (Team 190)
mcf747 has much to be proud ofmcf747 has much to be proud ofmcf747 has much to be proud ofmcf747 has much to be proud ofmcf747 has much to be proud ofmcf747 has much to be proud ofmcf747 has much to be proud ofmcf747 has much to be proud of
We has huge issues with deformation and rubbing of the 8" wheels. We were disappointed that theses weren't a bit tougher, good to hear the new design is, but I guess it is to be expected with the large amount of shock loads this year.
Matthew Forman
Team 1515
Unread 12-05-2010, 07:42
camtunkpa camtunkpa is offline
it's like shooting fish in a barrel
AKA: Cliff Mock
FRC #0222 (Tigertrons)
camtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond repute
To add to all the suggestions, the roughest thing on the field I saw this year was the "1/2" bump" on both sides of the ramps. I saw this bump even bend some aluminum AM omni wheels. So maybe some sideways testing on a 1/2" hard bump or something similar.
"Engineering is making the impossible happen"
"We are here to create, not merely survive" - unknown fortune cookie
"If you don't push the envelope you're just spinning your wheels"
Unread 12-05-2010, 09:13
PVCMike PVCMike is offline
AKA: Mike Jr.
FRC #1058 (PVC Pirates)
PVCMike has a spectacular aura aboutPVCMike has a spectacular aura aboutPVCMike has a spectacular aura about
Matthew Forman
Team 1515[/quote]
We also had serious issues with deformation of out 8" wheels and ended up going through 2 sets of 4 (which ends up getting pretty pricey.) The problem we were having is that the wheel plates were curling over (we assume from side load) and binding the rollers.
I would like to see some tests involving side load on the wheels, the sort of stress the wheel would see when being pushed from the side.
Mike Jr.
Team 1058 Mentor
Coming up on year 15 with the PVC Pirates!: www.team1058.com
https://www.thebluealliance.com/team/1058
Unread 12-05-2010, 13:34
Hadi379's Avatar
Hadi379 Hadi379 is online now
FRC #0379
Hadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to behold
Our main concern was the robustness of the side plates. We used the 8" wheels and noticed the same thing as the above post. Some of our rollers would get pinched between the two side plates and prevent the rollers from freely spinning.
Unread 12-05-2010, 20:00
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
Rigolith
(just in case)
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
Unread 12-05-2010, 20:37
Stephen Kowski's Avatar
BSEE, MSEE, JD
AKA: employed
Originally Posted by Andy Baker View Post
2. Pushing power of 8" Mecanum Wheels vs. 8" 2010 Kit wheels (on carpet)
how about the same test while stapling some roughtop or wedgetop to the kit wheels, many teams use this, your company sells wheels with roughtop/wedgetop in mind....i think it would be a good piece of information to have
are you videotaping these tests? I think that would be good in addition to written results
Unread 12-05-2010, 23:29
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
MythcanumBusters.
Unread 13-05-2010, 07:49
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (Red Pride Robotics)
I'd like a study performed on the correct pronunciation of mecanum. I've heard "MECK-ken-nem" and "muh-CAN-um" from very reputable sources. Which is right?
Hi!
Unread 13-05-2010, 07:57
foote stepped in
AKA: E. Foote
FRC #0868
jester drive.
Be Healthy. Never Stop Learning. Say It Like It Is. Own It.
Like our values? Flexware Innovation is looking for Automation Engineers. Check us out!
Mecanum wheel size Mr. A Technical Discussion 7 18-01-2010 08:58
AndyMark 10" Mecanum Wheels ChuckDickerson General Forum 7 31-12-2008 12:54
Trouble: AndyMark Mecanum wheels bbr4d3r Technical Discussion 6 28-01-2008 20:27
AndyMark Mecanum whytheheckme Technical Discussion 5 27-01-2007 23:57
pic: AndyMark Mecanum Wheels Madison Technical Discussion 13 09-10-2006 00:29
