Go to Post Antimatter.. It will help us in the never ending quest to build the bot under the weight limit. - Elgin Clock [more]
Unread 12-05-2010, 12:56
RMS11's Avatar
RMS11 RMS11 is offline
Safety!!!!
AKA: Rick
FRC #2415 (WiredCats)
Team Role: Driver
RMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to behold
Send a message via AIM to RMS11
pic: 4in Wheel CAD
Unread 12-05-2010, 12:58
Rion Atkinson's Avatar
Rion Atkinson Rion Atkinson is offline
The CAD Guy
Rion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond repute
Re: pic: 4in Wheel CAD
Looks really nice! I may have to make a sheet metal wheel now...
Anybody know how well this thing would hold up in use?
Do you have a picture without the sprocket on there?
‎‎"I know not with what weapons World War III will be fought, but World War IV will be fought with sticks and stones. -Albert Einstein
Start Something
Email - rionatkinson@gmail.com
Skype - Rion.Atkinson
Unread 12-05-2010, 14:37
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Press in threaded inserts wouldn't be easy to assemble IMO, and it seems to me that they would spin in the delrin as the bolts are tightened up. It also looks like you have a lot of fasteners not in the model, which will add on a bit of weight.
Maybe think about how you can make the sprocket integral to the structure of the wheel. I would skip on delrin as a wheel material entirely.
What sort of fabrication capabilities are available to you? Perhaps there is a way to take advantage of something unconventional.
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
This design is similar in many ways to one of our wheel design revisions. Take a look here to see what I mean:
http://www.chiefdelphi.com/media/photos/31102
http://www.chiefdelphi.com/media/photos/31104
http://www.chiefdelphi.com/media/photos/31105
We have been happy with our .190" thick side plates that we pocket for a press fit to align everything. You may want to consider this.
Thank-you 294 & 67
www.bobcatrobotics.org
Unread 12-05-2010, 20:51
RMS11's Avatar
Safety!!!!
AKA: Rick
Team Role: Driver
Why do you shy away from delrin? This year, we found it easy to machine. We made our wheels out of it this year. As for the threaded inserts, how would you recommend attaching the side plates instead? I was looking for a way to avoid bolting all the way through, adding much unnecessary weight. This year we used standoffs, but that was expensive. Aluminum bolts would make it even lighter, if we could find a good option. I do like the idea of making the sprocket have more of a structural use.
Here is a picture without the sprocket attached:
Peter, could you elaborate on how this press fit worked? It sounds like a great idea and a way to avoid welding with aluminum. The tube you mentioned, did you just buy an aluminum tube from mcmaster? How were the tolerances? How did you keep the inside part from slipping?
2009 Peachtree Regional Champs
2009 Palmetto Regional Champs
2008 Peachtree Rookie All Star and Rookie Highest Seed
Unread 13-05-2010, 00:38
Chris is me's Avatar
AKA: Pinecone
Why not tap the delrin and put short screws on each side? Would that make any sense?
Unread 13-05-2010, 00:41
rahilm's Avatar
rahilm rahilm is online now
AKA: Rahil Mehta
FRC #0668 (The Apes of Wrath)
rahilm has a spectacular aura aboutrahilm has a spectacular aura about
I would guess its because it would be too easy to strip the treads?
Team 668 - Apes of Wrath - 2008-2011
Team 668 - Apes of Wrath - 2011-Present (Mentor)
Unread 13-05-2010, 00:54
Hawiian Cadder's Avatar
AKA: Isaak
FRC #0159 (Alpine Robotics)
Team Role: CAD
delrin doesn't handle threads well, if i were doing that i would just get a nice bolt and run it through the whole thing, another way to do it would be rivets, but that would be a pain.
Unread 13-05-2010, 02:18
M. Mellott's Avatar
M. Mellott M. Mellott is offline
CAD God
AKA: Mike Mellott
FRC #3193 (Falco Tech), FRC #48 (Delphi E.L.I.T.E.), FTC #9980 (FMF)
M. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud of
Are there spacers between the sprockets and outer plates? I can't tell and didn't want to assume. You'll definitely need these if they're not already there.
While the design looks great, it's going to be difficult to get those sharp corners in the plate. Are these being cut out with a water jet? If not, you may need to add blends to the design for your cutter.
Also, since total price is a design factor, with a 4" dia. x 1" thick disc of Delrin costing between $15-$20, are you really saving money?
In the continuing battle between innovative engineering and the laws of physics...physics always wins.
Unread 13-05-2010, 03:07
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Originally Posted by M. Mellott View Post
A
A waterjet isn't needed, a laser would work as well. Where did you get $15-20 bucks pricing for delrin that size? I checked McMaster which is usually more expensive than local places.
www.mcmaster.com -> 8497K533
Pretty sure that is what he wanted and it comes out to $66 a foot and about $5.50 per inch. Excluding tax and shipping.
-RC
R.C.
MadTown Robotics Team 1323
Unread 13-05-2010, 03:46
M. Mellott's Avatar
CAD God
AKA: Mike Mellott
-RC
Yes, you're right, a laser cutter could work, but since they're not very common, lasers didn't even cross my mind. Also, I tend to avoid sharp points in cutouts as they concentrate stress (thought they probably won't be an issue here).
I checked McMaster as well for my prices (p/n 99866K22 - $18.84 for a 1" thick piece). I assumed nothing with what he wanted to do, hence I pointed out the material cost and my question. Of course, you'll need more than 1" of material if you're going to slice it from a larger rod (loosing the blade thickness) then making sure both faces are properly squared off. You are correct that it will be cheaper than $15-$20 per wheel if he gets a foot or more, but the question is still valid.
Unread 13-05-2010, 08:37
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
4" diameter 6061 is a little over $5/inch on McMaster. Making a 1-piece wheel will be the lightest, simplest option. No threaded inserts, no delrin, no multi-piece wheels, no big bolts.
If you were to keep within the budget of $15-$20/wheel you could just about use 2024 or 7075 aluminum for your wheel.
Unread 13-05-2010, 08:48
We bought 4" outer diameter 1/8" wall tubing from McMaster, then when it arrived we measured the actual OD. We then made our machine program that put the relief cut in the plates .002" over that OD, and the tube essentially presses into the plates giving good concentric alignment of all pieces. We actually weld the plates to the tube in our case, but the alignment is the important part.
Thank-you 294 & 67
Unread 13-05-2010, 08:58
RMS11's Avatar
Safety!!!!
AKA: Rick
Team Role: Driver
Yes, we would use a plasma cutter to cut the outside plates and a mill to cut the inside plastic. We dont have the machining capabilities to make a wheel from a block of aluminum, would take over 4 hours per wheel probably. For this design, we can make each wheel for about $25-30. This is significantly less than our wheels from this year. If we had the ability to weld, we would probably do something more like what Peter mentioned above. We would actually make these out of a rectangular block of delrin. We do not have access to a lathe currently, or else I would like to at least try a 1 piece wheel. And yes, the spacer is considered in the weight. It is made of 1/4" aluminum.
Unread 13-05-2010, 10:25
Andrew Y.'s Avatar
Andrew Y. Andrew Y. is offline
FunYun
AKA: Andrew Yun
FRC #2415
Andrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud of
what RMS means is he spent $1000 on wheel material last season HAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHA
http://www.chiefdelphi.com/media/photos/35717?
so he is finding ways to make custom wheels cheaper. $30 sounds great to me at this point. Also, there are some cheaper off the shelf wheels out there but we have had bad luck with them. Hopefully we can get a few different wheels designed this summer and try em out!
pic: New wheel CAD CraigHickman Extra Discussion 9 02-01-2008 20:29
pic: New wheel CAD CraigHickman Extra Discussion 4 08-09-2007 01:29
Mecanum Wheel CAD file or Drawing Leav Technical Discussion 2 17-01-2006 06:35
pic: Team 759 CAD pic (almost finished) oljomo Extra Discussion 6 01-03-2005 16:31
pic: Chantilly Academy's 4 Wheel Drive 4 Wheel Steering!!!! jskene Robot Showcase 25 18-02-2005 20:24
