Go to Post It's official: we've run out of things to talk about. - Jessica Boucher [more]
Unread 14-05-2010, 00:05
Hawiian Cadder's Avatar
AKA: Isaak
FRC #0159 (Alpine Robotics)
Team Role: CAD
pic: Alternate view of Mechanum wheel, with blue rollers added.
Unread 14-05-2010, 00:06
NickE's Avatar
NickE NickE is offline
_
Re: pic: Alternate view of Mechanum wheel, with blue rollers added.
How do you plan to manufacture those hubs? It looks like they may be almost impossible to make without a 5 axis CNC mill.
Also, you might consider a hex bore instead of the keyed bore. It's very nice not having to worry about lost keys.
Unread 14-05-2010, 00:29
AKA: Isaak
Team Role: CAD
we have a miniature 5 axis CNC mill, i also was contemplating making the hub and arms separately, when bolting the hubs in. we may make them out of delrin or lexan instead of aluminum to save weight, the rollers will be printed on a 3d printer, then coated in rubber.
Unread 14-05-2010, 13:17
Dave McLaughlin's Avatar
Dave McLaughlin Dave McLaughlin is offline
Dave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond repute
What is the diameter of the wheel? Is there any reason in particular that you decided to go with 7 rollers?
Unread 14-05-2010, 14:52
sgreco's Avatar
sgreco sgreco is offline
AKA: Steven Greco
FRC #2079
sgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond repute
It looks like a cool idea to play with.
If you go ahead and make these be sure to post them on CD.
Looks great though.
(off topic, when you take a picture of CAD model, you don't have to take a screen shot, just go to save as and select jpeg as the type of file...that way you don't get all the junk around the model, you just get the model).
Unread 15-05-2010, 02:23
AKA: Isaak
Team Role: CAD
thank you, the diameter is 8, and i chose 7 because of the roller diameter, there will be bearings inside the rollers and i wanted them to be large enough to fit the bearings. i have the cheap hacked version of solid works from the stimulus package so i dont have any screen shot tools.
Mechanum Wheel Rollers Stuck ienjoymycereal Technical Discussion 5 31-01-2010 22:38
pic: Cyber Blue Swerve Chassis - Rear View Chris Fultz Extra Discussion 33 07-12-2009 21:56
pic: Holomonic (Bottom View) with Large Omni-Directional Wheel Kit nonother Extra Discussion 9 16-05-2007 00:26
pic: Planetary Wheel - Exploded View 4 Matt Krass Extra Discussion 5 23-06-2005 23:56
pic: SpamThingAcon Mechanum wheel system Tytus Gerrish Extra Discussion 18 12-05-2005 04:40
