Go to Post I looked at it and originally thought it was a crazy idea... then I looked at it again and it still sounds like a crazy idea. But crazy ideas tend to produce some excellent results. - Yipyapper [more]
Unread 14-05-2010, 11:33
yarden.saa's Avatar
yarden.saa yarden.saa is offline
Yarden Saad
AKA: Yarden Saad
FRC #3339 (BumbleB)
yarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond repute
Robot Base
Hello guys,
After successful rookie year to my team, I am looking for a simple base to next year robot.
I have some ideas for the base but I can't implement the all idea because it missing some solutions.
I thought of a 6/8 wheels drive base. the main wheels are lower than the other wheels by half centimeter.
The problem to implement it is that I don't want to use chains, it's an headache. But how otherwise I can connect the wheels to the motors.
I saw many sketch at Chief-Delphi but I haven't seen yet a solution to my idea.
If you have any ideas to make it work, I will be happy to hear about it.
Thanks,
Yarden
2016 - Curie Sub-division Winners, Regional Winners
2015 - Carson Sub-division Winners, Regional Winners
2012 - 3339 Captain and Dean's List Finalist
Unread 14-05-2010, 11:42
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Re: Robot Base
You could do:
-Timing belts
-V-Belts
-Lots of idler gears
-Friction drive through and idler wheel
-Use 1 motor+transmission on each wheel in 6wd (4 cims + 2 fisher price)
-Drive shafts + bevel/helical gears
-4-bar linkage between the wheels (think locomotive)
Just a couple ideas, I'm sure some are better than others.
Unread 14-05-2010, 11:46
David Brinza's Avatar
David Brinza David Brinza is offline
Lead Mentor, Lead Robot Inspector
FRC #0980 (ThunderBots)
David Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond repute
Re: Robot Base
You can use timing belts instead of chains in your drive train.
As an example, I've attached a photo of our robot for Breakaway.
"There's never enough time to do it right, but always time to do it over."
2003 AZ: Semifinals, Motorola Quality; SoCal: Q-finals, Xerox Creativity; IRI: Q-finals
2004 AZ: Semifinals, GM Industrial Design; SoCal: Winners, Leadership in Controls; Championship: Galileo #2 seed, Q-finals; IRI: Champions
2005 AZ: #1 Seed, Xerox Creativity; SoCal: Finalist, RadioShack Controls; SVR: Winners, Delphi "Driving Tomorrow's Technologies"; Championship: Archimedes Semifinals; IRI: Finalist
2007 LA: Finalist; San Diego: Q-finals; CalGames: Finalist || 2008 San Diego: Q-finals; LA: Winners; CalGames: Finalist || 2009 LA: Semifinals; Las Vegas: Q-finals; IRI: #1 Seed, Finalist
2010 AZ: Motorola Quality; LA: Finalist || 2011 SD: Q-finals; LA: Q-finals || 2013 LA: Xerox Creativity, WFFA, Dean's List Finalist || 2014 IE: Q-finals, LA: Finalist, Dean's List Finalist
2016 Ventura: Q-finals, WFFA, Engineering Inspiration
Unread 14-05-2010, 11:59
Joining the 900 Meme Team
FRC #0079
Re: Robot Base
Originally Posted by yarden.saa View Post
Hello guys,
Thanks,
Yarden
What sort of problems have you run into with chains? I know in the last couple years I have never had a problem with a properly tensioned chain and am very curious what sort of problems can arise.
As for a possible solution. http://www.chiefdelphi.com/media/photos/26312 Expensive, heavy, but no chain.
Unread 14-05-2010, 13:30
yarden.saa's Avatar
Yarden Saad
AKA: Yarden Saad
FRC #3339 (BumbleB)
Re: Robot Base
because unknown reason after a while the chains are longer than they were and not always the chains fit ecsactly, if you remove one link it is too much short, if you add one link it is too much long and some times half a ling is not helping.
I liked the idea of timing belts but where can I get it and its sprockets?
Unread 14-05-2010, 13:32
Re: Robot Base
Gates provides some in the KOP.
There are also a number of ways to tension chain. One of the favorite ways is to get a cylindrical block of delrin and mount it by the ends, using an off-center screw or bolt. Rotate to tension the chain.
Unread 14-05-2010, 13:40
Eugene Fang's Avatar
Eugene Fang Eugene Fang is offline
The Blue Alliance
Eugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond repute
Re: Robot Base
What you need is a good chain tensioner design. Depending on what size chain you use (#25 or #35) will dictate how good your tensioner needs to be. Generally 35 chain is more forgiving if you have some slack, 25 is less so.
If you still want to move away from chain, AndyMark has a product they're working on that doesn't require chain. It may give you some ideas.
http://www.facebook.com/photo.php?pi...d=183701158229
Eugene Fang
2010 Silicon Valley Regional Dean's List Finalist
Various FLL Teams - Student (2000-2006), Mentor (2007-2010)
FRC Team 604 - Student (2007-2010), Mentor/Remote Advisor (2011-2015)
FRC Team 1323 - Mentor/Remote Advisor (2011-2014)
The Blue Alliance | TBA GameDay | TBA Android App
Unread 14-05-2010, 15:34
jspatz1's Avatar
jspatz1 jspatz1 is offline
AKA: Jeff
FRC #1986 (Team Titanium)
jspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond repute
Send a message via AIM to jspatz1
Re: Robot Base
To rehash a very over-discussed topic.....I never quite understand the desire to eliminate chains. They are one of the simplest, most economical, and most proven and reliable drive methods available. Properly assembled, they provide flexible shaft locations, adjustable length, easy repair, readily available sprockets and components, and guaranteed non-slip service. How many trillions of reliable bicycle-hours have run on roller chains? I suspect most of the "troubles" teams experience with chains are due to improper allignement, tensioning, or other implementation errors. Learning to use them well is often easier, and cheaper, than switching to a more exotic drive method.
Unread 14-05-2010, 15:50
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
Re: Robot Base
^+1
Unread 14-05-2010, 21:02
Edoc'sil's Avatar
Edoc'sil Edoc'sil is offline
FRC #2531
Edoc'sil has a spectacular aura aboutEdoc'sil has a spectacular aura about
Re: Robot Base
Originally Posted by jspatz1 View Post
To rehash a very over-discussed topic.....I never quite understand the desire to eliminate chains. They are one of the simplest, most economical, and most proven and reliable drive methods available. Properly assembled, they provide flexible shaft locations, adjustable length, easy repair, readily available sprockets and components, and guaranteed non-slip service. How many trillions of reliable bicycle-hours have run on roller chains? I suspect most of the "troubles" teams experience with chains are due to improper alignment, tensioning, or other implementation errors. Learning to use them well is often easier, and cheaper, than switching to a more exotic drive method.
QFT, by the way if you have a hard time aligning chains and getting them to work, forget about exotic drives, especially belt systems.
Here lies a toppled god-
His fall was not a small one.
We did but build his pedestal,
A narrow and a tall one.
Unread 15-05-2010, 12:36
yarden.saa's Avatar
Yarden Saad
AKA: Yarden Saad
FRC #3339 (BumbleB)
Re: Robot Base
Do anyone one if andymark idea is going to be sold in their shop?
The idea is very smart and helps to solove my problem.
Unread 15-05-2010, 12:40
gyaniv's Avatar
gyaniv gyaniv is offline
AKA: Gutman Yaniv
FRC #2230 (General Angels)
gyaniv has a spectacular aura aboutgyaniv has a spectacular aura about
Re: Robot Base
They stated that they are going to start selling those tubes by the start of June or something... so i guess yes... they cost 295$ or something so i don't think that it is worth it since there are some better and cheaper methods...
FRC Team 2230 - Student - 2009-2011
FRC Team 2230 & 4406 - Mentor - 2012
FRC Team 2230 - Mentor - 2013-present
"A mentor's job is to understand what the students are trying to make, and bend the laws of physics to make that happen"
Unread 15-05-2010, 13:47
Arefin Bari's Avatar
AKA: Ari
FRC #0108 (SigmaC@T)
Re: Robot Base
For some teams that may be a very good option since a lot of teams in FIRST uses the AM transmissions where each of them cost more than $300. If teams who don't have a machine-shop have access to these components, it would make their life much easier leading them to concentrate on their manipulator. I would also be interested in your "better and cheaper" methods considering time and labor. Please post your viable methods. Thank you.
Unread 15-05-2010, 13:59
gyaniv's Avatar
AKA: Gutman Yaniv
Re: Robot Base
First of all you get 2 Toughboxes in the KoP so it is no biggies to build a tank drive from 4 to even 10 or more wheels without much cost.... what is called kitbot...
Other methods are if you have a good sponsor or supplier that can get you some good gear components for free or cheap. For example one of our mentors this year was able to get us some planetary gears for the drivetrain for free so it is better and cheaper...
In my opinion this "tube" wouldn't be much helpful and cheaper for teams because one will cost 295$, you need 2 on the robot so it is more then 600$ with the shipping, and don't forget that you need different chassis for those "tubes" so it will cost more and it can easily get to 700 or even 800$ just the drivetrain, and it is without wheels... and the 2 wheels cost 295$... go figure how much the other configurations gonna cost....
Toughbox costs 88$ so even if you want to go with mecanum and all 4 gearboxes are toughboxes then it is still cheaper since you get the chassis and 2 gearboxes in the KoP and all you have to buy is the mecanum wheels and 2 toughboxes that cost 176$ excluding the wheels
Unread 15-05-2010, 14:20
AKA: Ari
Re: Robot Base
I still don't understand your "better and cheaper" solution. I have used tubes for the last 4 seasons and NEVER had any problems with it. Also, two 2 speed transmission from AndyMark is 360x2 = 720 bucks. The "tubes" are still cheaper (but yes it of course depends on the game in order for a team to decide what kind of drive train they would want to use).
Seems like we are taking over this thread. If you would like to continue this discussion, feel free to pm me.
Circle base vs. Rectangle base Pelicano234 Technical Discussion 13 15-01-2008 16:49
pic: 2Train Robot take home base Rich Wong Extra Discussion 8 31-07-2007 10:22
pic: RoboDawgs Team 288 Base & Sides of Robot # 2 drhall Robot Showcase 3 14-02-2007 12:18
pic: 932 Robot base Caleb A. Robot Showcase 5 07-02-2006 21:39
#d model of the robot base Damelvin 3D Animation and Competition 2 10-02-2005 18:50
