Go to Post I have no clue. All I know is that every year the riddle in the clue has confused me but this year it is the lack of confusion that confuses me. - hallk [more]
Unread 14-05-2010, 14:12
11douglash 11douglash is offline
FRC #1072
11douglash is infamous around these parts11douglash is infamous around these parts
Weird Chain tensioner.
Hi...
I'm designing a standardized Drive Train that will hopefully be used in many subsequent years for my team.
It is a 6wd, using 35 chain.
I came across this chain tensioner: McMaster-Carr part # 5896K1, http://www.mcmaster.com/#chain-tensioners/=730zh2.
Has anyone used these before? How well do they work?
Thanks
Unread 14-05-2010, 14:15
Dave McLaughlin's Avatar
Dave McLaughlin Dave McLaughlin is offline
Dave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond repute
Re: Weird Chain tensioner.
Some people might refer to that as a floating tensioner. Many teams have used them in the past and them seem to work well in the right application.
Unread 14-05-2010, 14:23
We used them on an arm chain once and it worked well, but with a long run flexing from quick direction reversals can cause them to fall out. We added a retaining system.
Unread 14-05-2010, 14:27
Rion Atkinson's Avatar
Rion Atkinson Rion Atkinson is offline
The CAD Guy
Rion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond repute
I would also recommend using this. It works quite well, and be used in more than the way shown.
Just wondering, can I get a peak at this drive train?
-Rion
‎‎"I know not with what weapons World War III will be fought, but World War IV will be fought with sticks and stones. -Albert Einstein
Start Something
Email - rionatkinson@gmail.com
Skype - Rion.Atkinson
Unread 14-05-2010, 14:47
FRC #1072
Thank you. Yes, There would be a retaining system: the main structural supports for the DT would go straight through the floating tensioners.
Formerly Famous: Once I have it CADded, sure, i guess...
Unread 14-05-2010, 16:17
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
We've used similar floating idlers machined out of .125 Lexan for 25-pitch roller chain. As long as you pay attention and keep adjusting their position until the chain stops stretching, they work great.
Art Dutra IV
世上无难事,只怕有心人.
Unread 16-05-2010, 18:10
Wiz Wiz is offline
Wiz is infamous around these partsWiz is infamous around these parts
We actually made our own version of the AndyMark style, without the rubber band fingers, but still using the zip ties, and it worked quite well.
There is another page of chain tensioners at McM-C, with a more expensive and sophisticated variation of the AndyMark one: http://www.mcmaster.com/#chain-tensioners/=74adn5
Go to page 1022, or part number 5973K2
Unread 17-05-2010, 18:42
joeweber's Avatar
joeweber joeweber is offline
Coach team 1322
FRC #1322 (G.R.A.Y.T. Leviathons)
joeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant future
You can eliminate the need for a chain tensioner if you preassemble the sprockets and chain than measure the distance to center, than build the distance into your frame. As long as you only have two sprockets in each chain set it’s a piece of cake. This will also save some weight.
If your not dirty than you must be just watching.
Thank's to http://weberelectric.biz/
FRC Team sitehttp://team1322.org/
2004 Great Lakes Xerox Creativity Award, 2008 Web Site Excellence Award, 2010 Kettering District and Western Michigan District Excellence in Engineering award, 2011 Kettering District Gracious Professionalism Award. 2011 Ann Arbor and State Cooperation Awards.2013 Kettering Xeroc Creativity Award.2015 Escanaba Chairman's Award.2015 Kettering Spirit Award.2016 Kettering Chairman's Award
FTC Lightining Boltz 5954, Thunder Botz 7032http://team1322.org/vex.htm
Unread 17-05-2010, 21:07
artdutra04's Avatar
I've found that this only works for chain runs with a center-to-center (CTC) distance of less than about six or so inches for 25-pitch chain. If using 25-pitch roller chain with CTC distances of greater than about six inches, chain stretch becomes large enough that it can cause performance issues without a chain tensioner.
Art Dutra IV
世上无难事,只怕有心人.
Unread 17-05-2010, 21:13
M.Wong's Avatar
M.Wong M.Wong is offline
FRC #0503 (Frog Force)
M.Wong is a jewel in the roughM.Wong is a jewel in the roughM.Wong is a jewel in the rough
In the past couple of years, we have built in quite a bit of tolerance in they way we mount our transmissions and motors. We will usually have slotted holes in our chassis for mounting, allowing us to adjust for small amounts of chain stretch.
We have not determined whether or not this affects performance or autonomous.
Unread 17-05-2010, 21:17
joeweber's Avatar
Coach team 1322
That sounds good for a six wheel drive, three wheels with a motor and gears between each wheel.
" O o O o O "
Unread 18-05-2010, 07:51
Ryan Dognaux's Avatar
Ryan Dognaux Ryan Dognaux is offline
Back Home in Indiana
FRC #4329 (Lutheran Roboteers)
Ryan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond repute
Send a message via AIM to Ryan Dognaux
This can also be done if you have an extra sprocket laying around that is larger than the two sprockets that your chain is running on. We've called it the floating sprocket - it's a real quick way to tension your chain if you're in a pinch and it works surprisingly well.
Ryan Dognaux :: Last Name Pronounced 'Doane Yo'
Team 234 Alum: 2002 - 2005 :: Purdue FIRST Member: 2006 - 2009
Team 1646 Mentor: 2007 - 2009 :: Team 357 Mentor: 2009 - 2012
Team 4329 Mentor: Current
STL Off-Season Event: www.gatewayroboticschallenge.com
Unread 18-05-2010, 08:19
Enigma's puzzle's Avatar
Enigma's puzzle Enigma's puzzle is offline
Strategery
AKA: Matt Brechting
FRC #2075 (Enigma)
Enigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to behold
but usually if you plan for it and buy some "add in" masterlinks which is a half a link you can usually be close enough to make it without tensioners, and you can determine if you need them as you build the chain http://www.mcmaster.com/#chain-links/=7540yq
Unread 18-05-2010, 15:11
Triple B Triple B is offline
all hail Passmore
AKA: Mike D is FTG too
None #0233 (The Pink Team)
Triple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant future
For a drive base with skid steer & direct drive for your center wheels I would agree with "joeweber" that there is no need for chain tensioners. When the chain stretches to a length you deem too loose, then change the chains out. The tensioner may give you the illusion that your chains are in good condition when in fact the chains are still stretching you just dont know how much. Dont get me wrong, tensioners are nice but in my experience they are not always required. But I also like #25 (1/4") chain for everything.
mike d
See Ya
Unread 18-05-2010, 17:43
artdutra04's Avatar
mike d
At about $3/ft, throwing away stretched roller chain is a more expensive endeavor than installing a $0.50 chain tensioner.
Waste not, want not.
Art Dutra IV
世上无难事,只怕有心人.
pic: Chain Tensioner gorrilla Extra Discussion 13 25-01-2010 00:13
Chain Tensioner RoboGeek99 Technical Discussion 23 12-01-2009 21:16
pic: Kitbot Chain Tensioner 2 Donut Extra Discussion 13 10-12-2007 15:57
Chain tensioner usage Rhs953 Kit & Additional Hardware 3 10-02-2004 17:04
Chain Tensioner? Gabriel Technical Discussion 14 29-01-2004 09:16
