Go to Post "Uh-oh, it's in crazy mode again. Hit the button!" - StephLee [more]
Unread 14-05-2010, 06:43
Hawiian Cadder's Avatar
AKA: Isaak
FRC #0159 (Alpine Robotics)
Team Role: CAD
pic: A mechanum wheel that shouldn't bump around at all.
Unread 14-05-2010, 06:44
Chris is me's Avatar
AKA: Pinecone
Re: pic: A mechanum wheel that shouldn't bump around at all.
Have you ran various mecanum wheels and encountered "bumping" problems? What improvement will eliminating this "bumping" give?
Unread 14-05-2010, 10:42
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
There are various nominal benefits, such as more reliable traction and an accelerometer with much less noise. No single benefit stands out, but it's always fun to ponder new designs that address even the small issues in order to perhaps come up with a much better design.
This is good work for creating a nice round profile. However, the hardest part is in the mounting of the rollers; a single plate that forms the middle of a "T" may or may not be enough to support the cantilevered stresses from the rollers. 357 may be able to give some insight there. Additionally, the mounting of the rollers will inevitably create some sort of gap when mounted in the center -- i.e. each roller as shown is not possible. In reality each roller is more like two roller halves, split in the center where the mount goes.
Combining the two dominant Mecanum designs into a hybrid design may be a better solution. A hybrid design has 3 rollers with 2 thin mount plates; the two rollers on the outside look like rounded cones and are cantilevered whereas the roller in the middle looks more like a bulging omni wheel roller (or a squished donut).
GitHub
Unread 14-05-2010, 14:55
Nadav Zingerman Nadav Zingerman is offline
FRC #2230
Nadav Zingerman is a splendid one to beholdNadav Zingerman is a splendid one to beholdNadav Zingerman is a splendid one to beholdNadav Zingerman is a splendid one to beholdNadav Zingerman is a splendid one to beholdNadav Zingerman is a splendid one to beholdNadav Zingerman is a splendid one to behold
Do those elliptical things actually roll (how?), or are they fixed in relation to the wheel?
Unread 14-05-2010, 15:09
EricH EricH is online now
They would roll. That's the way a mecanum wheel works--the rollers (the elliptical things) roll to alter the vectors the wheel is putting out. There would be an axle down the middle to allow them to roll; I don't see it here yet.
Unread 14-05-2010, 15:36
Brandon Holley's Avatar
Like the segway mecanum wheel??
-Brando
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 14-05-2010, 18:57
,4lex S.'s Avatar
,4lex S. ,4lex S. is offline
University Mentor
AKA: Alex Strong
FRC #2702 (REBotics)
,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of
I have been thinking about how you did this, and I have to say, you have me stumped. How did you design the 3D wheel with that perfectly circular side profile?
University of Waterloo Mechanical Engineering Class of 2014- 2B School Term
University of Waterloo Formula SAE Race Team 2010-Eternity
FRC 2702: REBotics 2011 Mentor ::: FRC 1006: Fast Eddie Robotics 2005-2009 Alumni ::: FLL 4050: 2004 Alumni
Unread 15-05-2010, 02:45
AKA: Isaak
Team Role: CAD
in actuality the arm will go all the way out, and match the profile of the roller and be coated in delrin, that will slide and will make it perfect, the way i did it was to assume that each roller had to have an arc that would look exactly like a circle when viewed from 45 degrees, thus the line that defines the outer edge of that roller is an elipse with one dimension being 8, the diameter of the wheel, and the other dimension being 8/sin(45) or about 11.3, this makes the profile of the roller a perfect circle from a 45 degree angle. the rollers are just revolves with that line as the edge. the arms are .375 inch thick 7075 aluminum alloy, and according to solid works, this wheel should hold at least 200 LBS safely. the total weight of the wheel is 1.8 LBS, it is 2.6 inches wide from roller tip to roller tip, and is 8 in diameter, the axle hole will have have a hub or something to attach it to the motor. the method for manufacturing the rollers is to print off a mold on our 3d printer, then use urethane, coated in rubber. overall it should be pretty sweet.
Unread 15-05-2010, 12:02
KRUNCH DUDE's Avatar
KRUNCH DUDE KRUNCH DUDE is offline
AKA: Erik
FRC #0079 (KRUNCH)
KRUNCH DUDE is a jewel in the roughKRUNCH DUDE is a jewel in the roughKRUNCH DUDE is a jewel in the rough
Send a message via AIM to KRUNCH DUDE
These wheels remind me of Airtrax wheels, did you get the idea from them? I would like to see a nice set of mechanum wheels for FIRST.
Unread 15-05-2010, 23:09
Hi Brandon,
Could you provide a link that shows the rest of this picture? I am curious to see the rest of the platform.
Unread 15-05-2010, 23:28
That's the Segway RMP 400 Omni.
Unread 15-05-2010, 23:36
Thanks Alan.
Looks like the wheels in the picture Brandon linked to are mounted incorrectly.
Unread 18-05-2010, 17:52
exprg:melonhead's Avatar
exprg:melonhead exprg:melonhead is offline
The Teamless/ Travelling Mentor
AKA: Justin Sticht
FRC #3278 (Qwerty)
exprg:melonhead has a spectacular aura aboutexprg:melonhead has a spectacular aura aboutexprg:melonhead has a spectacular aura about
hmmm... this wheel sure does look pretty, but does it run that way too? the side wheels (or whatever the technical term for them may be) look as if they are at a very harsh angle. now, i'm just a programmer, but isn't the ideal angle 45 degrees?
Unread 18-05-2010, 18:00
There is no "ideal" angle.
Many mecanum wheels have rollers at 45 degrees. This makes the kinematic (and dynamic) analysis easier. The forward and inverse kinematic matrix transformations are simple, with no trig functions or square roots.
Making the angle smaller than 45 degrees (angle between roller axis and plane of the wheel) improves forward/reverse traction but reduces strafing traction, and vice versa.
So there is no one ideal angle. It depends on the application.
Unread 18-05-2010, 18:02
Rion Atkinson's Avatar
Rion Atkinson Rion Atkinson is offline
The CAD Guy
Rion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond repute
You can buy some from AndyMark.
‎‎"I know not with what weapons World War III will be fought, but World War IV will be fought with sticks and stones. -Albert Einstein
Start Something
Email - rionatkinson@gmail.com
Skype - Rion.Atkinson
pic: Alternate view of Mechanum wheel, with blue rollers added. Hawiian Cadder Extra Discussion 5 15-05-2010 02:23
Mechanum Wheel Rollers Stuck ienjoymycereal Technical Discussion 5 31-01-2010 22:38
pic: 342 8-wheel articulation on bump hipsterjr Extra Discussion 5 31-01-2010 11:26
pic: 662 gets a tube wrapped around the wheel gburlison Extra Discussion 10 02-04-2007 17:39
pic: SpamThingAcon Mechanum wheel system Tytus Gerrish Extra Discussion 18 12-05-2005 04:40
