downloading issue
Hi i can connect to the cRIO and "download" but i don't think that it is downloading my program to the right place. when i right click the .out file and download it downloads it to the cRIO but everytime i restart the robot it deletes itself so i have come to the conclusion that i downloaded it to the RAM and thus is has a phyiscal memory dump every shutdown. can anyone fix this?
Re: downloading issue
You are using Windriver correct? And using the FIRST->Download button?
Also, how do you know it is deleting your code? Does it say "No Code"? If so, that could be a different error such as undefined symbols, AKA- A problem in your code. |
i tried first download but it had the same effect.
when i rebooted i went into the driver station and it said "no code". |
oh and i was using the simple robot template and i didnt do anything to it.
Did you set up the FIRST downloader to work with your project? Go to Window->Preferences (I think) and click on FIRST downloader. Enter your team number and locate the .out file for your project.
Have you tried FTP to it? (10.xx.yy.1 Username:FRC Password:FRC, where xx is the first two digits of your team # and yy is the last two digits.)
It is supposed to be under the "ni-rt" directory and called "FRC_UserProgram.out". Quote:
-Masoug |
#7
It's done with the Run/Debug (popcorn!) kernel task command in Windriver. WR sends it to the cRIO, which immediately loads it into memory, and runs it without saving it to a file.
| Downloading error | dnrobotics11 | C/C++ | 2 | 02-02-2009 18:52 |
| Downloading help | Lyrix | NI LabVIEW | 1 | 22-01-2009 00:39 |
| An Issue with downloading the Master Code. | Neil [Coconuts] | Programming | 6 | 07-02-2008 14:03 |
| Issue with downloading code to the 2007 RC | thefro526 | Programming | 3 | 10-02-2007 17:26 |
| downloading problems. | Dylan Gramlich | VEX | 9 | 13-12-2006 13:03 |
