Go to Post Man, Earthquakes all over the place, Volcanos and clouds of ashes, S&Ps down 25 pts! and now 1114 is first seed and going to probably pick 469... yep, id say the end of the world is near - scessama [more]
Unread 14-05-2010, 21:41
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
Re: 2011 Dewalt Supliers.
One of our team's mentors, David Edwards, has a fair amount of experience modifying the newer DeWalt planetary gearboxes for use with the Fisher-Price motors in the KoP.
Here is a thread describing the process he used during the 2010 season:
http://www.chiefdelphi.com/forums/sh...ght=new+dewalt
In life, what you give, you keep. What you fail to give, you lose forever...
Unread 14-05-2010, 22:49
JamesCH95's Avatar
JamesCH95 JamesCH95 is online now
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
I've drilled a couple of the powder metal gears with regular jobber drills, just go slow and make liberal use of coolant. Sharp drill bits go a long way and don't forget to center drill.
In my experience the DeWalt transmissions can handle far more abuse than any motor can dish out. In 2005 I made a transmission that used two FP motors, it snapped a case-hardened Thomson drive-shaft without even trying. They are capable of 50+ lb*ft of torque reliably.
Unread 14-05-2010, 23:48
AKA: Lars Kamen's Roadie
FRC #0051 (Wings of Fire)
There's a guy on these boards named Josh Murphy, who is the king of the NBD. He can turn a Dewalt into a robot gearbox in no time. Send him a PM (his user name is Josh Murphy).
Unread 15-05-2010, 02:57
Hawiian Cadder's Avatar
AKA: Isaak
FRC #0159 (Alpine Robotics)
Team Role: CAD
thank you for all the help, we order d a couple of transmissions today, and we hope to test them out before we order many more.
Unread 18-05-2010, 09:08
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
Picked up one of the toolking referb dewalts. The first thing I noticed was that the shaft that the chuck is screwed to is held into the gearcase on just a standard taper. The experience I have with taper fittings is that if you put a continuous side force on them they eventually loosen up and fall out. How do you keep this from happening on the dewalt?
Bruce
Unread 18-05-2010, 12:40
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Bruce
Like a Jacobs taper, except on the gearbox end rather than the chuck end? The old XRP (from the original NBD) used a straight (well, stepped) shaft with two opposing flats on the gearbox end.
In any event, the one year I used one of these on the robot, to avoid trying to deal with the standard shaft and an adapter for the drive sprockets, I just removed and replaced the entire output shaft with something else that interfaced with the gearbox output. (And then, because it was a weak steel, the torque promptly twisted it around until it deformed and failed. So if you go that route with an old XRP, harden the shaft—maybe some tempered O1 steel would work well.)
Maybe DeWalt switched to the taper drive in order to avoid breaking shafts?
Unread 18-05-2010, 13:26
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
+1 to the heat-treated output shaft. An alloy steel like 4130 or 4340 might work very well, and they can be heat-treated to very high strengths. Watch out for warping during heat-treatment; you may want to machine 95% of the part, heat treat it, then finish machining it if you find that the additional strength is required. Titanium (I know it's expensive) would do very well because of it's relatively high shear strength as compared to steel or aluminum. It would be a smart place to use titanium, not just to say "we used titanium."
Unread 18-05-2010, 15:46
Bruceb's Avatar
So you are saying this is something new? The old ones had a fixed shaft?
Bruce
Unread 18-05-2010, 18:18
A picture would be useful here, but I don't have any...so I'll try to explain.
The old DeWalt XRPs had a cast metal housing that slipped partially over the gearbox, and extended forward to the chuck. It contained the drive shaft, and retained it with two dissimilar ball bearings (looked like conventional ones; no angular contact or fancy stuff). We (188 in 2006) deviated from the standard NBD plan by removing the shaft, and replacing it with a different shaft that fit within the same housing, but which had a Ø0.5 in keyed shaft instead of the chuck thread and left-hand retaining screw. On the gearbox end of that shaft, we milled two opposing flats on the cylinder (so it looked something like the Ø0.375 in portion of the Globe motor shaft). Those flats interfaced with a little sintered steel coupling on the front of the gearbox, providing a positive connection that was not susceptible to small axial misalignment.
If I'm understanding you correctly, they've replaced the shaft-with-flats with a taper. That ought to work too, as long as you make sure (as we did) to let the shoulder on the shaft transmit the axial loads to the housing, so that the taper doesn't disengage.
Unread 19-05-2010, 10:12
Bruceb's Avatar
Well, maybe they didnt change it after all. The shaft, after I took it all appart, is press fit into the bearing and then trapped buy a steel ring behind it that is about .375 wide and looks for all the world like just a piece of steel tube but it only fits on the shaft one way like it has a mating taper behind the bearing.
Tristan, did you use hardened steel for the shaft that you made?
Bruce
Unread 19-05-2010, 11:28
Bruce
That's how it worked on the old drill. The retaining collar was a press fit, and though the inside may have had a taper (I never checked), the shaft itself was straight.
We didn't use hardened steel for the shafts, and that was a mistake. The steel we used (AISI 1018 first, I think, then AISI 12L14) was weak and ductile, and the torque of the drivetrain caused it to twist at the interface with the planetary gearbox after repeated back-and-forth cycling. In retrospect, we should have just used AISI O1 drill rod, and then hardened and tempered it.
Unread 19-05-2010, 12:50
Bruceb's Avatar
O.K. I'm not a machinist so how do you harden and temper drill rod after machining it? I think that is what I would like to do as the shaft on the Dewalt does not exactly fit my application.
Bruce
2011, 2012 and 2013 Champs dates KathieK Championship Event 59 05-06-2010 06:26
inventor 2011 kinghashbrown Inventor 8 05-05-2010 22:50
2992 with 5 motor 2011 Prototype Drive System 45Auto General Forum 4 22-04-2010 23:01
Championship Venue Change for 2011-2013 basicxman General Forum 2 28-03-2010 17:49
FIRST® Selects St. Louis as Site of Championship from 2011 - 2013 Andrew Schuetze Championship Event 13 19-03-2010 14:43
