Go to Post Common sense can take you a long way!!! - ClintDog [more]
Unread 15-05-2010, 02:45
Hawiian Cadder's Avatar
AKA: Isaak
FRC #0159 (Alpine Robotics)
Team Role: CAD
Re: pic: A mechanum wheel that shouldn't bump around at all.
in actuality the arm will go all the way out, and match the profile of the roller and be coated in delrin, that will slide and will make it perfect, the way i did it was to assume that each roller had to have an arc that would look exactly like a circle when viewed from 45 degrees, thus the line that defines the outer edge of that roller is an elipse with one dimension being 8, the diameter of the wheel, and the other dimension being 8/sin(45) or about 11.3, this makes the profile of the roller a perfect circle from a 45 degree angle. the rollers are just revolves with that line as the edge. the arms are .375 inch thick 7075 aluminum alloy, and according to solid works, this wheel should hold at least 200 LBS safely. the total weight of the wheel is 1.8 LBS, it is 2.6 inches wide from roller tip to roller tip, and is 8 in diameter, the axle hole will have have a hub or something to attach it to the motor. the method for manufacturing the rollers is to print off a mold on our 3d printer, then use urethane, coated in rubber. overall it should be pretty sweet.
pic: Alternate view of Mechanum wheel, with blue rollers added. Hawiian Cadder Extra Discussion 5 15-05-2010 02:23
Mechanum Wheel Rollers Stuck ienjoymycereal Technical Discussion 5 31-01-2010 22:38
pic: 342 8-wheel articulation on bump hipsterjr Extra Discussion 5 31-01-2010 11:26
pic: 662 gets a tube wrapped around the wheel gburlison Extra Discussion 10 02-04-2007 17:39
pic: SpamThingAcon Mechanum wheel system Tytus Gerrish Extra Discussion 18 12-05-2005 04:40
