Go to Post And the rest of the team helped them, encouraged them, and made a big deal about how awesome it was that we were competing for the Chairman's Award. - Carolyn_Grace [more]
Unread 30-04-2010, 13:52
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Re: pic: 4 inch Wheel Render
Originally Posted by NickE View Post
If you have a hex broach and an arbor press, it will be much cheaper than $15/wheel to get the hexagonal hole.
A 1/2" hex broach is only like $200 on McMaster, so if you plan on making more than 13 hex broached parts, its probably worth it. (A 6wd live axle would require 16: 6 wheels, 10 sprockets.)
If you're tight on money and like working with your hands, you can make your own hex broach for 'soft' materials like plastic or aluminum. All you need is an old HSS end mill, a lathe, and a precision grinder. It'll work good enough for FRC-style applications.
Art Dutra IV
世上无难事,只怕有心人.
Unread 30-04-2010, 14:00
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
If you've got SW2010 with all the options, try running an FEA on it and what sort of loading it might see and what benefits/sacrifices are required to make it out of different materials. Solidworks Sim is butt-simple to use, very robust, and gives reasonably accurate answers.
For example, if you make it out of 7075 it could weigh significantly less than if it's made out of 6061T6 because of the strength advantage of 7075. What about 2024?
Could you make it out of steel and weld it to an output shaft? Drilling a round hole is easier than broaching, and a welded shaft can be incredibly strong. You could use an alloy steel like 4340 or 4130 that has a strength/weight ratio that's better than most aluminums. I know it's harder to machine, but you might need fewer spokes for the same strength, so there would be less machining required.
I'd do these just as a exercise in SW (think about setting up different configurations for the same model too) but if you like where it's going don't be afraid to break out of the typical FIRST rut of "pretty machined aluminum everything".
Edit: also, the rendering looks really nice :-)
Unread 30-04-2010, 15:32
viking's Avatar
viking viking is offline
Viking Robotics
AKA: Robert Dudek
FRC #1777 (Viking Robotics)
viking will become famous soon enoughviking will become famous soon enough
I have to comment about those "silly tutorials and guides", all good 3d modelers cannot go a day without having to look something up and watch a tutorial. It is not a sign of weakness, but a sign of "knowing when to ask for help".
Viking Robotics Team #1777
2006 FRC Colorado Regional Rookie Inspiration
2007 FRC Greater KC Regional Daimler Chrysler Spirit
2007 FVC St Louis Connect Award
2009 FRC Greater KC Best Website Award
Unread 30-04-2010, 20:41
Hey Art,
Could you elaborate on the proper way to do this? Sounds very interesting. Thanks.
Unread 30-04-2010, 22:30
artdutra04's Avatar
Originally Posted by Akash Rastogi View Post
Hey Art,
My roommate did this to broach some aluminum parts for a combat robot he was working on.
What you do is take an old HSS end mill, and cut off the cutter portion of it, leaving just the shank. Then mount this in a collet in a lathe with cut off end of the end mill sticking into the lathe, with the original end sticking out. Crank turn on the lathe, and then hold a Dremel with a cutoff tool perpendicular to the end of the end mill, and slowly turn the entire end of the end mill into a concave dimple.
Then get a large piece of steel hex stock, mount it in the lathe, and bore a through hole the same diameter as the end mill. Mount this piece of hex stock in a milling machine and drill/tap holes for set screws to hold against the flats of the HSS end mill shank.
Then mount the HSS end mill shank into the hex stock, and make sure the set screws are against the flats of the end mill, with the dimpled end sticking out. Then go over to the precision grinder and stick and steel hex stock on it, and activate the magnets to keep it in place. Now use the precision grinder, which should have a XZ table. Slowly start grinding down a flat into the HSS end mill. Once you've started this, deactivate the magnets, turn the steel hex stock by 60 degrees onto the adjacent face, and again grind down a small amount.
Don't adjust the Z-distance until you've done all six faces; it helps to mark one with a Sharpie/some mark, to make sure the hex stays true. Keep going, grinding down all six faces, then readjusting the Z, and then again grind down all six faces until you reach the correct size hex you desire. Now you have a homemade HSS hex broach. To use, simply first bore a round hole to the diameter you want in a lathe, then mount the HSS hex broach in a lathe and use then force the homemade hex broach through the round hole (while the lathe is stationary of course).
It might take an hour to make your own hex broach, but for broke college students, it sure beat spenting $$$ to buy one.
Art Dutra IV
世上无难事,只怕有心人.
Unread 01-05-2010, 13:43
Chris is me's Avatar
AKA: Pinecone
I know, I'm just lazy.
I'll probably fire up those tutorials and guides today, before I work on stuff a little more ambitious.
I ran an FEA on the wheel and it tells me it's more than strong enough for the peak side load this wheel would have as is (safety factor of 10 or something). I probably did something wrong with the FEA.
Unread 01-05-2010, 13:52
Jstack14 Jstack14 is offline
Team Role: CAD
Jstack14 is infamous around these parts
My suggestions, most of which have been said, are to make a tread groove and i would suggest two rivits at the start and end of the tread and two in the middle.
Unread 01-05-2010, 18:50
mike263's Avatar
mike263 mike263 is offline
FRC #0263 (AFTERSHOCK)
mike263 is on a distinguished road
Send a message via AIM to mike263
That's the same design we used last year for our gyro for stearing only difference was we had a hole for key and round shaft instead of hex
Unread 02-05-2010, 21:58
ChristopherSD's Avatar
ChristopherSD ChristopherSD is offline
FRC #0201 (FEDS 201)
Team Role: Driver
ChristopherSD has much to be proud ofChristopherSD has much to be proud ofChristopherSD has much to be proud ofChristopherSD has much to be proud ofChristopherSD has much to be proud ofChristopherSD has much to be proud ofChristopherSD has much to be proud ofChristopherSD has much to be proud of
I could only dream of getting PhotoView 360 to cooperate...
Unread 15-05-2010, 12:00
Rion Atkinson's Avatar
Rion Atkinson Rion Atkinson is offline
The CAD Guy
Rion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond repute
What do you mean? I never have a problem with it...
‎‎"I know not with what weapons World War III will be fought, but World War IV will be fought with sticks and stones. -Albert Einstein
Start Something
Email - rionatkinson@gmail.com
Skype - Rion.Atkinson
Unread 15-05-2010, 18:43
AKA: Pinecone
Same here. I have a mid range workstation provided by RPI and it works without a hitch. Solidworks is more likely to crash my graphics drivers...
4 inch Wheel of Doom R.C. SolidWorks 25 26-11-2008 23:57
pic: 5 Inch Wheel RMS11 Extra Discussion 24 18-08-2008 23:55
Going over 6 inch step with 12 inch wheels Joe P Technical Discussion 25 12-04-2004 11:15
pic: 1083 Render CD47-Bot Robot Showcase 9 19-02-2004 19:00
12 Inch Wheel Available in Several Formats Ed Sparks Inventor 1 19-01-2004 07:12
